Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > FT86CLUB Shared Forum > Regional Forums > AUSTRALIA
AUSTRALIA Australia and New Zealand
Old 07-12-2012, 11:30 PM   #15
nix
nix's Avatar
Drives: AVO BRZ
Coyote +36 would open up a lot of options for you and is still legal. If I go 8s I will go +30 most likely.
nix is offline   Reply With Quote
Old 07-12-2012, 11:34 PM   #16
Mr.Ferret
3D Artist
Drives: 2015 White GT86 MT
Im looking at getting some 17" Volk's eventually with bridgestone R002's and some form of lowering, better coilovers etc. Im i think i want to keep all the sizes about the same, im more after performance but im not really sure, im a bit new to this. Thoughts?
Mr.Ferret is offline   Reply With Quote
Old 07-12-2012, 11:38 PM   #17
Nafe
Nafe's Avatar
Drives: Mt Fuji Red 86 GT
a 17x9 +40 won't stickout at the rear at all, and it's unlikely that it will stick out much, if any, at the front...
tye size and rim width fitment is an intersting tyre... If you use basic maths a 205 should be on a 8in... 8in is 200mm and a 205 tyre is 205mm
Nafe is offline   Reply With Quote
Old 07-12-2012, 11:40 PM   #18
Type[R]+
Type[R]+'s Avatar
Drives: Lexus IS-F
Originally Posted by coyote View Post
Those 245/40R17s in the picture should really go onto an 8.5" or 9" rim. You can have both though ... a 17x9 CE28N weighs 6.7kg. It would look great and be 100% functional, but costs a bomb.
A Weds 17x9 only weighs about 400g more, but Weds USA did their special BRZ fitment as a +40. That'll poke out slightly on the rear and a mile at the front, so fail ... and that's one of the better ones!
I don't blame the retailers, they are just catering for what the market is asking for. I just can't believe there isn't a market for some nice, light, affordable 17x9 +45ish (that is, LEGAL) wheels.
I agree for rim size for that tyre, but those tyres he chose are 25lb each too don't forget...
Not blaming the market, WRX's have been out for 20 years now, not like this fitment is new....
Type[R]+ is offline   Reply With Quote
Old 07-12-2012, 11:41 PM   #19
coyote
coyote's Avatar
Drives: Slowly
Originally Posted by Nafe View Post
I was originally wanting 9’s, but I am also thinking 8.5’s might be a good option.. 8.5 +25 or +30 with 215/45/17’s J
They would both be illegal in Qld due to the track increase. let alone how far they'd protrude from the bodywork.
What are the specs of the car in that picture?
coyote is offline   Reply With Quote
Old 07-12-2012, 11:44 PM   #20
nix
nix's Avatar
Drives: AVO BRZ
Also since people brought it up, the difference in tyre weight from 225 to 255 is less than a kg due to profile. You could run 18x9.5 and 255 with overall less unsprung than stock with the right wheels if you wanted to (not the kiwami).
I like the idea of lw 17s for track days but for my daily set I'll look at lw 18x8 or 9 with 225/235s.
Old 07-12-2012, 11:45 PM   #21
coyote
coyote's Avatar
Drives: Slowly
I didn't forget that, but things like R1Rs and Pilot Super Sports weigh significantly less.
The Following User Says Thank You to coyote For This Useful Post:
Type[R]+ (07-12-2012)
Old 07-12-2012, 11:49 PM   #22
nix
nix's Avatar
Drives: AVO BRZ
17x8+36 And stretched 215/45
Link
Old 07-12-2012, 11:49 PM   #23
coyote
coyote's Avatar
Drives: Slowly
You could, if someone made the right wheels.
An 18x9.5 Forgestar F14 weighs less than a stock 17x7. They aren't expensive either ;-)
Old 07-12-2012, 11:50 PM   #24
JDMC
JDMC's Avatar
Drives: JDMC
the problem with wide wheels in high offset:
1. is you will end up hitting suspension strut inside (depending on the car model)
2. cars that use this wide normally will end up getting the brakes upgraded (thats at least in japan) and will not work wih high offset
3. it is not cheap to make wheels and only a small market will buy this high offset unfortunately. work wheels for examples discontinued a lot of high offset wheels simply because no one buys them
you are right in the sense retailer and manufacturer will sell what the market demands.
JDMC is offline   Reply With Quote
Old 07-12-2012, 11:53 PM   #25
Type[R]+
Type[R]+'s Avatar
Drives: Lexus IS-F
Weight difference does depend on brand, model, etc.
Interestingly, I can save 2-3kg per tyre on the IS-F (same sizes), just by going to Michelin PSS from my Bridgestone RE050A's. That's huge! Worth paying attention to the weights!
The Following User Says Thank You to Type[R]+ For This Useful Post:
coyote (07-13-2012)
Old 07-12-2012, 11:55 PM   #26
coyote
coyote's Avatar
Drives: Slowly
Link
Thanks Nix, but I want to use at least a 245 on at least a 9.
Front of that car is borderline too, even with skinny wheels and stretched tyres.
Old 07-13-2012, 12:00 AM   #27
nix
nix's Avatar
Drives: AVO BRZ
Ah right sorry, confused myself with your talk of legalities, as 235s are max legal tyre for 86 in SA.
Hmm I see plenty of space, remember its measured from widest part of the arch flare.
Old 07-13-2012, 12:06 AM   #28
nix
nix's Avatar
Drives: AVO BRZ
Yes my point though take the same brand/model and increasing width doesn't always mean adding much weight. And yes that is HUGE.
Which 18" wheels will weigh the same or less than the stock wheels? mickey177 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 32 05-16-2013 03:07 PM
[FYI] Street Legal Info Calidrifter Southern California 7 06-29-2012 02:02 PM
Forgestar wheels, great wheels at great prices!!!! IslandImportPerformance Wheels and Tires 0 06-15-2012 05:03 PM
Max legal interest rate? UriarteMD Scion FR-S / Toyota 86 GT86 General Forum 40 03-12-2012 01:50 PM
O.Z. Wheels Zaku Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 25 02-28-2012 03:21 AM
