Old 04-07-2018, 06:23 PM   #43
RavioliG
Poor Adult Male
RavioliG's Avatar
Drives: 2013 Subaru BRZ
Originally Posted by TOLM View Post
I have a 2017 brz and i like the pre 2017 front bumpers way better ((
TRADE ME THEN
RavioliG is offline   Reply With Quote
Old 04-30-2018, 12:57 PM   #44
tweedbean
tweedbean's Avatar
Drives: White GT86
Is there a gap around the headlights when doing this swap? Or is it a perfect fit?
tweedbean is offline   Reply With Quote
Old 08-20-2018, 02:14 PM   #45
TheBRZsKnees
TheBRZsKnees's Avatar
Drives: 2014 BRZ
So if you go with the 2017 fog lights, can this be done without any cutting or modification? Curious if I could do the swap in my apartment carport with minimal tools lol.
Shout out to OP for the walkthrough, and for recommending a good place for paint in the PNW.
Edit: Those stock fog lights aint cheap! The Winjet ones seem like a good alternative though.
TheBRZsKnees is offline   Reply With Quote
Old 08-20-2018, 03:54 PM   #46
malubawla
poor man's evora
malubawla's Avatar
Drives: Turbod BRZ
you can reuse your factory fogs in the 2017 bumper swap. just need to attach with one bolt and one ziptie
malubawla is offline   Reply With Quote
The Following 2 Users Say Thank You to malubawla For This Useful Post:
B T (11-12-2018), TheBRZsKnees (08-22-2018)
Old 08-22-2018, 12:44 PM   #47
TheBRZsKnees
Drives: 2014 BRZ
After taking a closer look at this thread, it looks like people are using the pre-facelift DRLs, not the fog lights
But it looks like you did the swap and were actually able to fit your pre-facelift fogs?
Old 08-22-2018, 04:54 PM   #48
malubawla
poor man's evora
malubawla's Avatar
Drives: Turbod BRZ
no gap as long as you use the headlight bracket from the 2017
Old 08-22-2018, 04:56 PM   #49
malubawla
poor man's evora
malubawla's Avatar
Drives: Turbod BRZ
sure was, held with one bolt and one ziptie, rotated slightly. even has my 2013 front lip on
The Following User Says Thank You to malubawla For This Useful Post:
TheBRZsKnees (08-25-2018)
Old 08-23-2018, 01:41 PM   #50
Byeezus10
Drives: 2015 Scion FRS
Bumper Swap
Car looks amazing man! Do you know if the swap would work with a 2015 FRS? Not sure how different bolts and how lights were setup. Thanks!
Byeezus10 is offline   Reply With Quote
Old 08-25-2018, 01:12 PM   #51
malubawla
poor man's evora
malubawla's Avatar
Drives: Turbod BRZ
pmed..
Old 11-12-2018, 11:59 AM   #52
B T
Drives: 15 BRZ, 2003 MR2, '70 Elky, 06 TBSS
So using the 2015 brackets isn't going to work? Thought I saw they had the same part number.
57707CA181
57707CA191
B T is offline   Reply With Quote
Old 03-08-2019, 11:53 AM   #53
ChicagoNole
Drives: 2014 FR-S
I just did the 2017 bumper on my 2014 FRS and its not fitting too well in the corners.
I bought the bumper bracket set, part #s 57707CA040 57707CA050 , but...and maybe I didn't look too closely, they seemed to be the same ones already on my car so I returned them.
In the post you have these 2 parts:
57707CA180
57707CA190
Are these the parts that run under the headlight area? When I go to buy them online, all of the websites say there is a new part available: 57707CA181 and 57707CA191.. does anyone know if those will work or do I need to find the old ones?
ChicagoNole is offline   Reply With Quote
Old 04-25-2019, 03:29 AM   #54
blown
Drives: ft86
anyone know if the olm drl works with the oem plugs for 13 brz drl?
http://www.ft86speedfactory.com/olm-...l#.XMFhMOhKiHt
blown is offline   Reply With Quote
Old 05-15-2019, 12:00 AM   #55
bobmcboberston
Drives: 2014 BRZ
It does not, it comes with an add a fuse and both wires are already connected.
bobmcboberston is offline   Reply With Quote
Old 05-29-2019, 01:12 AM   #56
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
Already connected to a plug that doesn’t match the 13 drls?
Is it a simple two wire in and out? I am curious if the Drls can be wired up the same even if the plugs don’t match and if they work with the DD Always On system.
Greetings Earthlings - 2017 86 Bumper Swap! SquadRon Scion FR-S / Toyota 86 GT86 General Forum 70 10-26-2018 04:04 AM
2017 BRZ Front bumper swap BRZoomTX Cosmetic Modification (Interior/Exterior/Lighting) 16 06-01-2018 02:55 PM
2017 Headlights and Bumper on '13-'16 BRZ Conversion mushyho Cosmetic Modification (Interior/Exterior/Lighting) 29 01-27-2017 01:39 AM
2017 front bumper Jmk91 Cosmetic Modification (Interior/Exterior/Lighting) 19 12-13-2016 01:15 PM
NorCal-Scion FRS front bumper for sale(Toyota FT86 Modellista front bumper with lips) unicorn86 Northern California 0 02-13-2016 04:10 PM
