#29 |
Airborne at your service
Drives: '17 BRZ Series.Yellow
#30 |
Drives: MR2, Sliver BRZ
I took a look at the 2013-16 cars on the tis website. And it seems that the cluster is part of the immmo system for turn key cars. Let me get a copy of the manual for immo settings. But it seems that if you can get a brand new cluster who hasn't been been programmed then a very simple procedure with techstream should allow it to get programmed on a turn key. Now, not sure how this would be with a used cluster .. if once the key gets programmed into the cluster it can't be deleted or reprogrammed. Or if it's difficult to do so. Or if it stores this is virtual "key" in a eeprom in the cluster (Which means a new one can be purchased and clone the "virgin" flash) or if it's internal the the main processor IC in the cluster itself.
#31 | |
Drives: 1949 UFO
#32 |
TIS - TOYOTA 2017-2019 86 Repair Manual (RM2760U) IMMO reg.pdf
seems that push start will work just fine! but if you want to do it with a turn key then buy a new cluster and do the above procedure. Does anyone know were we could but these clusters btw? or even the non GR ones but still have the screen? trying to get the brz part number for mine but cant seem to find it. or anyone have one to sell? i have the resistor values and the two pins needed to add to the cluster. if you want to use the steering wheel for the buttons you will need also the clock spring and any extra pins associated with them. |
#33 | |
Drives: pearl white eighty six
Plug and play for the 2013 push start model? No modification to the harness? |
#34 | |
Drives: FT86
Yes plug and play on a push button start, but you will be stuck on the defaut display unless you sort out the steering wheel switches or alternative switches to control the displays Last edited by steve99; 09-10-2018 at 07:04 PM. |
| The Following User Says Thank You to steve99 For This Useful Post: | pearlhatchiroku (09-10-2018) |
#35 | |
So if one would also get the kouki steering wheel switches, it should work? Last edited by pearlhatchiroku; 09-10-2018 at 11:59 AM. |
#36 |
Drives: BRZ Limited; GR86
I have the cluster working on my car and it's plug and play on the push start vehicles. you will need a steering wheel, clock spring, and instrumental cluster harness off a 2017 to be able to use the menus. The default screen shows you miles to empty, mpg, current mpg. It also shows your trip monitors.
| The Following User Says Thank You to shaynek For This Useful Post: | pearlhatchiroku (09-10-2018) |
#37 | |
im working on a way to add buttons without wiring harness, new airbag, new clockspring, new instrument cluster wiring harness.. etc... here is the link if you guys are interested. http://www.ft86club.com/forums/showthread.php?t=129867
Always looking to tinker with something..
| The Following 3 Users Say Thank You to geraldjust For This Useful Post: |
#38 | |
#39 | |
Oh and yeah i managed to mile correct it. does require a eeprom reader and to take the cluster apart.
| The Following User Says Thank You to geraldjust For This Useful Post: | shaynek (09-11-2018) |
#40 |
AT Pleb
Drives: 2014 FR-S Monogram (Firestorm Red)
Would this be the one I would purchase for my FR-S?
https://parts.olathetoyota.com/oem-p...ItMGwtaDQtZ2Fz
Knowledge is knowing that a tomato is a fruit. Wisdom is not putting it in a fruit salad. |
#41 | |
#42 | |
AT Pleb
question: do you have a rough idea of how much you're going to charge for the controller to cycle through the display? question 2: what would I have to buy to be able to update the odometer?
| 2017 Limited Gauge Cluster | halleffect | Electronics | Audio | NAV | Infotainment | 26 | 10-22-2020 07:32 PM |
| Help! Is there anyway to change the 2017 cluster start up image? | slashlee | DIY (Do-It-Yourself) Guides | 2 | 11-17-2018 05:36 PM |
| Any Mid-Year 2017 86 Special Edition? | Borchert97 | Scion FR-S / Toyota 86 GT86 General Forum | 42 | 03-14-2017 07:43 AM |
| 2017 Limited Gauge Cluster | halleffect | Cosmetic Modification (Interior/Exterior/Lighting) | 0 | 01-16-2017 03:55 AM |
| 2017 gauge cluster | Drakiv | Cosmetic Modification (Interior/Exterior/Lighting) | 2 | 11-14-2016 11:32 PM |
