Old 08-17-2018, 08:06 AM   #197
Breadman
Breadman's Avatar
Drives: 2017 BRZ w/PP
Originally Posted by SuperTom View Post
Nice.
I just got finished with Zach last week. No dyno results but I'm very happy with the smoothness and pull and the exhaust is even more refined. Took 7 revisions on 93 octane to get right. And yes Zach is very quick turn around usually 24-48hrs later. Not weeks and months with other tuners
yeah hes awesome. he did mine and he was always waiting on me. would recommend
The Following User Says Thank You to Breadman For This Useful Post:
FastWhite (08-20-2018)
Old 08-19-2018, 07:57 PM   #198
smg1138
smg1138's Avatar
Drives: 2013 Raven FR-S
Just curious, how do other 4-2-1 headers compare to the Ace 350? Are the Tomei and HKS EL headers pretty close or is it just a total blowout? These are super nice but the cost is kind of prohibitive for a NA solution IMHO. I'm currently using the JDL UEL catless headers, but have been thinking about changing to a 4-2-1 EL.
smg1138 is offline   Reply With Quote
Old 08-19-2018, 08:16 PM   #199
cjd
cjd's Avatar
Drives: 2017 BRZ
Only other in the same game was Nameless. Ace 350 pulls harder below 3500 for sure, and dynos show why. Withholding judgement on the top end till I get things sorted (finally getting my 3" front pipe, and discovered 2 of 3 studs missing at the header/overpipe flange on my Ace)
The Following User Says Thank You to cjd For This Useful Post:
smg1138 (08-19-2018)
Old 08-19-2018, 09:03 PM   #200
RJasonKlein
RJasonKlein's Avatar
Drives: 2013 Scion FR-S 10 Series
I had the same issue with two of the three flange bolts going missing after about 3,000 miles. I wish that I had taken photos of the solution I ‘engineered’, but it basically involved replacing the original bolts with slightly longer 304 stainless steel hex-cap bolts torqued to spec with a jam nut applied on the other side of the nut that’s welded to the backside of the flange. Problem solved.
RJasonKlein is offline   Reply With Quote
The Following User Says Thank You to RJasonKlein For This Useful Post:
cjd (08-19-2018)
Old 08-19-2018, 09:16 PM   #201
cjd
cjd's Avatar
Drives: 2017 BRZ
I used socket head bolts. Will carry spares and check it a bunch till I'm confident it holds. May have to get some lock washers or longer bolts and nuts like you've done. Good to hear its not just me. I checked after a couple good heat cycles, but suspect this happened somewhere during the first autocross.
I tried locking nuts against each other on the studs to get some grip when installing but was hesitant to go too tight since they were copper. I tightened till the nuts started turning.
Old 08-19-2018, 09:47 PM   #202
bfrank1972
Drives: 2013 FR-S Argento
There's others that are good, i.e. Ptuning, JDL, P&L. I have a 4-1 catted P&L header (bought used for $400ish) that made a big difference in power. ACE is probably the best, but it's not the only game in town - there are other great options for way less investment.
The Following 2 Users Say Thank You to bfrank1972 For This Useful Post:
JBezugs (08-22-2018), smg1138 (08-20-2018)
Old 09-28-2018, 10:48 AM   #203
n0thing
Drives: Subaru BRZ
Say you buy the ACE A350, Ecutek cable + license and the Delicious Ace tune, do you just flash this "OTS" tune like you do with OFT and that's it? Do you still need to perform pulls on the street and tune over the air for a "street tune". Or does this have to be done at a local dyno?
n0thing is offline   Reply With Quote
Old 09-28-2018, 11:00 AM   #204
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
I'm sure the base tune is "safe" but many send data logs to get the most out of their tune.
MS, CSCS, TSAC-F, CPT
Old 09-28-2018, 11:01 AM   #205
stlgrym3
I just finished Delicious tuning on my ACE350+Delicious Tuning flex fuel kit. Haven’t gotten a chance to get a real dyno yet but my butt dyno definitely saying this setup delivers. The difference is especially noticeable in low and midrange.
stlgrym3 is offline   Reply With Quote
The Following User Says Thank You to stlgrym3 For This Useful Post:
justinco (09-28-2018)
Old 09-28-2018, 11:01 AM   #206
J1Avs
Drives: 2018 BRZ tS
JDL is working on a 4-2-1 Long Tube EL header also...sounds like they are putting the final touches on it, and the gains have been looking very positive against their Catless UEL
J1Avs is offline   Reply With Quote
Old 09-28-2018, 12:36 PM   #207
justinco
btr.life
justinco's Avatar
Drives: 2022 GR86
You absolutely do street tuning, and that is sufficient. Dyno tuning is optional and might net additional (small) gains, but not necessary.
justinco is offline   Reply With Quote
The Following 2 Users Say Thank You to justinco For This Useful Post:
CSG Mike (09-28-2018), n0thing (09-28-2018)
Old 09-28-2018, 01:03 PM   #208
SuperTom
SuperTom's Avatar
Drives: C5, GT-86, '24 Colorado TrailBoss
The initial tune given is mainly to test for safety to make sure there are no issues, leaks ect. The pulls on the street are what is used to fine tune to your particular setup to get the most out of it. He will do it until its perfect
SuperTom is offline   Reply With Quote
The Following 2 Users Say Thank You to SuperTom For This Useful Post:
Old 09-28-2018, 02:41 PM   #209
CSG Mike
CSG Mike's Avatar
The tune is dialed in based on logs you send back. While the logging is not mandatory, it is highly encouraged to get the most out of your setup. The revisions are not an upsell; they are included! Likewise, all hardware is also included, not an upsell, and an overpipe is also included (and mandatory!).
This is a premium header, that while offered at a premium price, also comes with premium performance, and premium support.
The Following 3 Users Say Thank You to CSG Mike For This Useful Post:
justinco (09-28-2018), n0thing (09-28-2018), Tristor (09-28-2018)
Old 09-28-2018, 03:47 PM   #210
n0thing
Drives: Subaru BRZ
Does CSG offer such package? I only see one for CS400 and that doesn't include Ecutek itself.
My Nameless header dyno results (results to follow) Simply_the_best Engine, Exhaust, Transmission 39 06-28-2016 04:09 PM
Australian Dyno Dyno Results Shiv@Openflash Software Tuning 11 07-22-2015 04:57 AM
86 Dyno results Anban AFRICA 18 01-14-2014 06:54 AM
Dyno Compilation - dyno testing results and recommendations Illusive Engine, Exhaust, Transmission 82 02-08-2013 07:00 PM
