#197 | |
Drives: 2017 BRZ w/PP
yeah hes awesome. he did mine and he was always waiting on me. would recommend |
| The Following User Says Thank You to Breadman For This Useful Post: | FastWhite (08-20-2018) |
#198 |
Drives: 2013 Raven FR-S
Just curious, how do other 4-2-1 headers compare to the Ace 350? Are the Tomei and HKS EL headers pretty close or is it just a total blowout? These are super nice but the cost is kind of prohibitive for a NA solution IMHO. I'm currently using the JDL UEL catless headers, but have been thinking about changing to a 4-2-1 EL.
#199 | |
Drives: 2017 BRZ
Only other in the same game was Nameless. Ace 350 pulls harder below 3500 for sure, and dynos show why. Withholding judgement on the top end till I get things sorted (finally getting my 3" front pipe, and discovered 2 of 3 studs missing at the header/overpipe flange on my Ace)
| The Following User Says Thank You to cjd For This Useful Post: | smg1138 (08-19-2018) |
#200 |
Drives: 2013 Scion FR-S 10 Series
I had the same issue with two of the three flange bolts going missing after about 3,000 miles. I wish that I had taken photos of the solution I ‘engineered’, but it basically involved replacing the original bolts with slightly longer 304 stainless steel hex-cap bolts torqued to spec with a jam nut applied on the other side of the nut that’s welded to the backside of the flange. Problem solved.
| The Following User Says Thank You to RJasonKlein For This Useful Post: | cjd (08-19-2018) |
#201 | |
Drives: 2017 BRZ
I tried locking nuts against each other on the studs to get some grip when installing but was hesitant to go too tight since they were copper. I tightened till the nuts started turning.
#202 |
Drives: 2013 FR-S Argento
There's others that are good, i.e. Ptuning, JDL, P&L. I have a 4-1 catted P&L header (bought used for $400ish) that made a big difference in power. ACE is probably the best, but it's not the only game in town - there are other great options for way less investment.
#203 |
Drives: Subaru BRZ
Say you buy the ACE A350, Ecutek cable + license and the Delicious Ace tune, do you just flash this "OTS" tune like you do with OFT and that's it? Do you still need to perform pulls on the street and tune over the air for a "street tune". Or does this have to be done at a local dyno?
#204 | |
Airborne at your service
Drives: '17 BRZ Series.Yellow
#205 |
I just finished Delicious tuning on my ACE350+Delicious Tuning flex fuel kit. Haven’t gotten a chance to get a real dyno yet but my butt dyno definitely saying this setup delivers. The difference is especially noticeable in low and midrange.
| The Following User Says Thank You to stlgrym3 For This Useful Post: | justinco (09-28-2018) |
#206 | |
Drives: 2018 BRZ tS
#207 | |
btr.life
Drives: 2022 GR86
#208 | |
Drives: C5, GT-86, '24 Colorado TrailBoss
The initial tune given is mainly to test for safety to make sure there are no issues, leaks ect. The pulls on the street are what is used to fine tune to your particular setup to get the most out of it. He will do it until its perfect
#209 | |
This is a premium header, that while offered at a premium price, also comes with premium performance, and premium support. |
#210 | |
Drives: Subaru BRZ
| My Nameless header dyno results (results to follow) | Simply_the_best | Engine, Exhaust, Transmission | 39 | 06-28-2016 04:09 PM |
| Australian Dyno Dyno Results | Shiv@Openflash | Software Tuning | 11 | 07-22-2015 04:57 AM |
| 86 Dyno results | Anban | AFRICA | 18 | 01-14-2014 06:54 AM |
| Dyno Compilation - dyno testing results and recommendations | Illusive | Engine, Exhaust, Transmission | 82 | 02-08-2013 07:00 PM |
