Old 08-16-2018, 07:29 PM   #1
squelchy451
Drives: Pending
Is the clutch easy, or at least predictable?
Hi. Selling my Mazda3 soon, and one of the gripes I had about the car was that the clutch was numb, unpredictable, and hence very difficult to drive smoothly.
I don't want to put up with that in a slow FWD car. However, I am willing to put up with a bit of discomfort for a car like BRZ. It's hard to get a feel for the clutch through a short test drive, and many users on the Mazda3 forums had similar complaints while major reviews did not.
Which is why I ask you here--is the clutch on the BRZ easy to drive with, or at least predictable enough for you to drive smoothly?
squelchy451 is offline   Reply With Quote
Old 08-16-2018, 07:32 PM   #2
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
Yes.
Just take a test drive. Better than me trying to explain to you.
Old 08-16-2018, 07:39 PM   #3
BigFatFlip
sleep, drive, eat, repeat
BigFatFlip's Avatar
Drives: '13 BRZ, '12 Outback
It's a very light clutch imho, at least compared to other vehicles I've owned. It's relatively communicative, which makes it easy to drive smooth. My only gripe is the weirdly high engagement point (feels to me almost at the very top) but you very quickly get used to it.
The Following User Says Thank You to BigFatFlip For This Useful Post:
humfrz (08-16-2018)
Old 08-16-2018, 07:58 PM   #4
D-rek07
As long as you learn where the engagement point is, as BigFatLip discussed, it's easy.
D-rek07 is offline   Reply With Quote
The Following User Says Thank You to D-rek07 For This Useful Post:
humfrz (08-16-2018)
Old 08-16-2018, 07:58 PM   #5
Snake
Drives: ADM Toyota 86 GT
Compared to my previous car (s) it is light, numb and difficult to drive smoothly. It also doesn't help that if you breathe on the throttle it's bouncing off the limiter.
Even after owning this car since 2012 every now and then I'll accidentally rev it up to 3k and slip the clutch too much.
I find it's more the throttle and clutch relationship that makes it difficult more than the clutch itself though.
Sent from my RNE-L02 using Tapatalk
Snake is offline   Reply With Quote
The Following User Says Thank You to Snake For This Useful Post:
jcw99 (08-16-2018)
Old 08-16-2018, 07:59 PM   #6
churchx
churchx's Avatar
Drives: 2014 GT86
Clutch bite point is adjustable. Lightness .. as it partially comes from spring in pedal assembly, has cons aswell, as harder to feel bite point. Then again, that's modable aswell.
Regarding pedals in twins i'd do: replace with mtec's or remove completely clutch assist spring, adjust dead travel a bit less (but not overdoing it, as it's easy to miss very slight clutch drag), and add Velox's/Verus's accelerator pedal spacer, to ease heal & toe (from what i've heard, might be less needed on RHD).
Old 08-16-2018, 08:35 PM   #7
Stock clutch is like driving with a condom. Can't feel shit. Easily fixed. Leave the assist spring installed. If you care enough to ask, this mod will be your first.
Old 08-16-2018, 08:37 PM   #8
Trueweltall
Trueweltall's Avatar
Drives: 2016 Subaru BRZ
I happen to own a 2018 Mazda 3 so I can give you some direct experience. The clutch in the BRZ has a lot more feeling compared to the Mazda 3, it also has a shorter travel too. Pushing the clutch all the way in on the Mazda 3 just feels like it goes forever. The shifter is also more direct feeling than the Mazda 3, probably because its RWD and not FWD, so you don't have 8 feet of clutch cable to manipulate the gears. The steering in my Mazda 3 is a lot more vague than the BRZ, even more so after installing stiffer steering rack bushings.
My advice is to drive in your bare feet to get a good feeling for the clutch engagement and then add shoes in the mix. I live in Florida so it's easy to kick the flipflops off and then drive around.
Trueweltall is offline   Reply With Quote
The Following User Says Thank You to Trueweltall For This Useful Post:
Tcoat (08-16-2018)
Old 08-16-2018, 09:14 PM   #9
StraightOuttaCanadaEh
Wes
Nope. Still can't shift smoothly after 35k km.
Instagram: @gt86ws
Old 08-16-2018, 10:02 PM   #10
You know the old saying - if you keep doing the same thing over and over again and expect different results -
wparsons (08-17-2018)
Old 08-16-2018, 10:03 PM   #11
Yep, I second (or third) that ..
Old 08-16-2018, 10:06 PM   #12
Wes
I just gave up at some point. I have no idea where it engages or where to get back on the throttle. There is no feel and no communication through the pedal. Sometimes it works, but I don't know why or how. It's accidental. I have found no consistent way.
Instagram: @gt86ws
Old 08-16-2018, 10:09 PM   #13
Of course you can't "feel shit", when you put a size 16 foot, hooked to a 75 pound leg, down on the poor little clutch -
Old 08-16-2018, 10:38 PM   #14
I'm telling you. Do my clutch mod. You will fall in love with your car all over again.
DIY - Easy clutch grab adjustment (~10 mins) Koji_Online DIY (Do-It-Yourself) Guides 745 11-09-2022 01:44 AM
EZCarLift Easy car lift portable super easy car lift bren5279 Mechanical Maintenance and Tools 16 09-11-2015 02:57 PM
Easy Clutch Grab Adjustment frsfreak Southern California 2 03-28-2014 05:13 AM
Anyway easy way to fix this? FRSure Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 22 01-06-2014 10:54 PM
Any (easy) way to stiffen up the feel of the clutch? Partial Stall Engine, Exhaust, Transmission 41 07-19-2012 03:17 PM
