Old 07-12-2012, 03:55 PM   #15
Sandman3zb
Drives: 2013 Raven FRS
here is the clearance.
Sandman3zb is offline   Reply With Quote
The Following 2 Users Say Thank You to Sandman3zb For This Useful Post:
Yamaha_R6 (12-04-2014)
Old 07-12-2012, 10:53 PM   #16
spiller
Drives: JZA70 Supra, Lancer Evo 5, 86 GTS
Originally Posted by staycrushing View Post
stiff shock/spring = stiff tire
soft shock/spring = soft tire
otherwise... well youll see what i mean.
you should not be giving out advice with theories like this.
spiller is offline   Reply With Quote
The Following User Says Thank You to spiller For This Useful Post:
denkigrve (07-12-2012)
Old 07-13-2012, 01:47 AM   #17
jedichimp
OG <FR-S'less> Member
jedichimp's Avatar
Drives: yes
^^ that's enough
Flickr // SarapBuhay
merrill.joes@gmail.com
panda cheez
Old 07-13-2012, 11:00 AM   #18
Sandman3zb
i couldnt even fit my pinky in between that gap....haha twss
Old 07-13-2012, 04:15 PM   #19
staycrushing
staycrushing's Avatar
Drives: A Hot Mess
please shine forth your infinite knowledge
one of the first people to ruin the frs.
staycrushing is offline   Reply With Quote
Old 07-16-2012, 06:24 PM   #20
RWD-boxer
RWD-boxer's Avatar
Drives: Black
Best sized rims yet....would like wider tires but I still like
RWD-boxer is offline   Reply With Quote
Old 07-18-2012, 10:07 AM   #21
Element Tuning
Drives: Hydra EMS Powered FRS Raven Black
Interesting on the front clearance as my 18x9.5 et 38 basically touched the front spring perch. You seem to have more clearnce but i needed a 5mm spacer.
After installing our race BC suspension there is plenty of clearance and i was able to remove the spacer.
Element Tuning is offline   Reply With Quote
Old 07-25-2012, 10:49 PM   #22
Sandman3zb
I couldnt even fit my pinky between them. Did you run a stretch tire on your rims? If not then yea id think it would touch.
Old 09-18-2012, 03:09 AM   #23
ngabdala
Vortech Supercharged
Drives: WRB BRZ 6MT LTD
What size lug nuts ? 12x1.5 or 12.125
Powered by Vortech, ECS Tuning, and JDL Auto Design
ngabdala is offline   Reply With Quote
Old 09-18-2012, 08:08 AM   #24
Sandman3zb
Im not sure but i used the stock lugs. So whatever they are I guess.
Old 01-09-2013, 11:36 PM   #25
dnjshin0bi
dnjshin0bi's Avatar
Drives: 86 GTS (PW) Manual
Rota GRIDS 18x9.5 +38 all round
Hello all this is my set of rims as mentioned in title in gloss black.
Tyres are 245/35/18 all around.
cheers!
dnjshin0bi is offline   Reply With Quote
The Following User Says Thank You to dnjshin0bi For This Useful Post:
dem00n (01-10-2013)
Old 01-09-2013, 11:41 PM   #26
shu5892001
Ontario's FT86
Drives: 2016 Lexus GS-F
Looks nice, I am buying a similar square setup, What are you lowered on? Any fitment issues/fender modifications?
shu5892001 is offline   Reply With Quote
The Following User Says Thank You to shu5892001 For This Useful Post:
dnjshin0bi (01-10-2013)
Old 01-09-2013, 11:45 PM   #27
dnjshin0bi
dnjshin0bi's Avatar
Thank-you!
BC coilovers, in that photo, my rears were lower than the fronts. i'd scrub lightly when i hit a big dip but i raised it abit now and its fine no rubbing issues at all.
hope that helps.
shu5892001 (01-10-2013)
Old 01-09-2013, 11:53 PM   #28
dem00n
Member of the year - 2016
dem00n's Avatar
Drives: Scion FRS
Attachment 24929
cheers!
...Does that dude in the pink have one leg?
Loving your set up...i wonder how it would go all white.
What tires you running?
The Following User Says Thank You to dem00n For This Useful Post:
Wheel Directory: Rota Grid 18x8.5 +44 / 18x9.5 +38 CoRi J Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 119 04-26-2019 10:42 PM
Wheel Directory: Yoshihara Design DY-37C 18x9.0 +35 yoshiharadesign Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 105 11-28-2017 05:27 PM
Wheel Directory: Work Emotion CR Ultimate "Kiwami" 18x9.5 +30 RavSpec Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 179 11-20-2015 01:12 AM
Wheel Directory: SSR SP1 18x9 +38 FreedE Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 77 03-05-2014 02:06 PM
17x9 +35 front .... 18x9.5 +38 rear kinryu Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 06-30-2012 03:19 AM
