Old 08-14-2018, 10:54 PM   #1
Nurnburger
Drives: World Rally Blue
Fitment Issues: 17x9+35 wheels with 245/40 tires
Hey! I've been searching through these forums for a while, but finally decided to post as I've run into some problems with my new wheel/tire setup.
I've got WedSport TC105N 17x9 +35 wheels with Continental ExtremeContact Sport 245/40/17 tires, and they are rubbing badly on my front struts. It's clear that they are in contact all the time, as there's a nice groove in each tire and there are rubber bits sprayed everywhere inside, as you can seen in the picture.
I have a stock suspension, and I thought I had researched this setup thoroughly. There are many threads (like this one and this one) which suggest it should be fine. People have pictures showing clearance and are talking about running fatter tires and less offset without rubbing issues.
So my question is what did I miss?
Things I have checked:
Wheels stamped with the right offset
Tires are the ones I ordered. (They measure tread at 9 1/2" and widest at 10 1/4")
Alignment report from the the previous owner has the front camber at 0-0.5 negative, though it's pretty dated
Also, I had been planning to use the OEM camber bolt solution to get a degree of negative camber up front, but this has thrown a wrench in those plans.
Nurnburger is offline   Reply With Quote
Old 08-14-2018, 11:12 PM   #2
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
That top strut bolt is a camber bolt, I bet it has more then that -.5 that is says. With my 245's on 17X9 +38 57dr's they would almost touch with camber bolts.
Try to loosen the strut bolts and turn that upper one and see if it rocks the knuckle out.
strat61caster (08-17-2018)
Old 08-15-2018, 02:04 AM   #3
NLSP
NLSP's Avatar
Drives: 2014 Ultramarine FR-S
I've had the same specs on stock suspension before with no issues. The issue is that you added negative camber with that camber bolt, which brings the top of the wheel/tire closer to the strut. If you switch it back to the stock bolt (and have zero camber), you should be fine.
Old 08-15-2018, 02:18 AM   #4
NARFALICIOUS
NARFALICIOUS's Avatar
Drives: 88 Supra 1JZ, 16 FRS, 25 GR Corolla
Damn this is crazy because I just bought the exact same setup for wheel/tire, but I'm on TRD Springs, never been aligned.
Hope I don't run into the same issue. I've also read those threads and thought it'd be okay.
Mine aren't mounted yet.
@Nurnburger - is it just the fronts? Rears okay?
Everyone else - Would a 3 or 5mm spacer work? or do you think a 0 degree alignment would be okay? HOw much clearance should it be at 0 degrees? No issues on compression either?
NARFALICIOUS
Noob Poster
1988 | 2016
NARFALICIOUS is offline   Reply With Quote
Old 08-15-2018, 02:20 AM   #5
Nurnburger
Y'all are totally right!
It seems to be an SPC camber bolt set to full negative. My understanding is that those are basically the same as Whitelines? Per their manual, you're only supposed to set it full positive/negative (1.5 deg), not in between. I assume that's so the load only goes directly into the cam, instead of trying to turn it.
I had been looking for about 1 degree negative anyway. Any chance that would clear, or will I have to go basically zero camber to get this to clear?
An alignment shop could adjust the ones I have to that setting, but it would likely violate the instructions. Otherwise, I go with the OEM camber bolt, which I set myself and then have an alignment shop check?
Old 08-15-2018, 02:23 AM   #6
Nurnburger
Yes, the rears are fine.
Old 08-15-2018, 07:24 AM   #7
churchx
churchx's Avatar
Drives: 2014 GT86
Nurnburger: where does that manual says that one is supposed to use camberbolts only at extreme positions of their adjustment ranges? It's only that it has approximate range of + or - 1.5dg, and that tabbed washer & bolt should be initially put at one or another position for positive or negative adjustment, but then fine-tune by turning bolt itself for needed value. "NOTE: Cam bolt and washer must be fitted in the horizontal plane only" AND "7. Perform camber adjustment by rotating bolt to desired position."
wparsons (08-17-2018)
Old 08-15-2018, 10:19 AM   #8
pinoy_dorifto
Tuloy po kayo!
Drives: 2019 Toyota 86 TRD SE
Oh wow! I’m actually on the same boat as you are, well almost. Just bought a used set of rpf1 17x9+45 with 245/40r17 re71r. I know there would be clearance issues with the +45 and read that a 3mm would clear the spring seat. So I got a set of 3mm spacers and it rubs like yours, lol. Current set up is trd spring with oem camber bolt at -1.5 camber. I also just bought spc camber bolts hoping for -2.5 camber for the track ��. I was thingking of 10mm spacer would do the job, After seeing this, I guess it won’t. Only option for us is to get velox/ft86 camber plate so we can clear the wheels with less camber on the bolts and get desired camber from the camber plate OR coilovers wich is very expensive.
I.G. @mytoy86
pinoy_dorifto is offline   Reply With Quote
Old 08-15-2018, 10:37 AM   #9
Nurnburger
churchx: It was that NOTE that confused me. It makes sense that you should be able to adjust it to the desired setting, as that's kind of the point.
Old 08-15-2018, 11:15 AM   #10
pinoy_dorifto
Tuloy po kayo!
Try to put the camber bolt on the bottom and the oem bolt on the top?
I.G. @mytoy86
Old 08-15-2018, 12:08 PM   #11
Nurnburger
Assuming the current setup is 1.5 degrees ish, dialing it back to my desired 1 deg probably won't give me the clearance that I need. I think I'm gonna get 3mm spacers, which should allow a little bit of wiggle room to get close to the desired setup.
Now I have to figure out whether or not that strut needs to be replaced first, as it seems to be covered in oil....
Old 08-15-2018, 12:17 PM   #12
Turbo
Drives: FR-S Turbo
Are you positive those are +35 offset? Could they be +40s or +45s ?
I was running 17x9 +35 Form 1 RPF1's with 255/40R17 RS4s on the stock suspension and didn't rub anywhere.
Turbo is offline   Reply With Quote
The Following User Says Thank You to Turbo For This Useful Post:
Old 08-15-2018, 12:29 PM   #13
Code Monkey
Drives: Subaru BRZ
Looks like they are +45.
Code Monkey is offline   Reply With Quote
Old 08-15-2018, 01:02 PM   #14
gtpvette
Drives: 2015 FRS - FFR GTM
I run 6UL's 17x9 +40 on stock suspension,,, it was really tight so I opted for a 3MM spacer.
2015 FR-S - One Day I'll Finish The Swap
gtpvette is offline   Reply With Quote
WTB: 17x9 wheels and tires, +42-46 offset luchadorjose Want-To-Buy Requests 2 05-02-2017 03:39 PM
17x9 TR Motorsports wheels with conti tires APEXIT53 Brakes, Suspension, Chassis 3 03-27-2017 11:17 AM
Looking for 17x9 Autocross Track wheels and tires paintdude258 Want-To-Buy Requests 2 03-17-2016 07:30 PM
Any rubbing issues with 17x9.5 +40 wheels and 255/40/17 tires? Eazy-V Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 14 11-02-2014 09:42 PM
