Old 08-15-2018, 12:14 AM   #15
N1rve
N1rve's Avatar
Drives: 2019 BMW ///M4
Originally Posted by ls1ac View Post
These are huge brakes for a street car with lots of cooling. It will be very difficult to get them up to proper operating temperature on the street. Might suggest a street pad for daily and save those pads for track.
Still think a check of install is in order to determine miss aligned pad.
Some track pads make a grinding noise when cold, but a check of surfaces for a rub is in order.
So re-checked the install and everything is nice and tight. I think the bracket might be a little off which is a QC issue for Wilwood.
Drove it some more and did some more hard braking. At low speeds below 30 MPH, I can slightly feel the rotor grooves in the brake pedal.
At higher speeds 75-60, when I lightly brake, the car shudders but as I apply more pressure, the car does not shudder anymore. I think it's because the pad is lightly getting caught in the slots in the rotors and causing this issue. Maybe more time with it, it will wear the slots some more.
Car still pulls to the right for some reason. Might be an issue with the caliper not having equal pressure on all 4 corners.
N1rve
Old 08-15-2018, 12:17 AM   #16
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Still doesn't sound right. I can feel the rotors through the pedal, but the car itself does not shudder. Do you have a bunch of pad stuck to the rotors from previous bed in attempts?
NoHaveMSG is online now   Reply With Quote
Old 08-15-2018, 01:35 AM   #17
N1rve
N1rve's Avatar
Not that I can see or feel from touching it.
N1rve
Old 08-18-2018, 02:24 PM   #18
N1rve
N1rve's Avatar
Update: Had the installer check out the install. Everything is installed correctly, but it seems like the rotors aren't balanced causing the vibration at high speeds. Will contact Wilwood on Monday.
N1rve
The Following User Says Thank You to N1rve For This Useful Post:
Stang70Fastback (08-18-2018)
Old 08-18-2018, 02:29 PM   #19
Stang70Fastback
A.K.A. Starlord
Stang70Fastback's Avatar
Drives: 2015 Series.Blue
Thanks for following-up! I wish more people would do that...
Check out my blog, read all about my BRZ adventures, and oogle my sweet cell-phone photos!
You can also find me on Instagram, and on Facebook.
Stang70Fastback is offline   Reply With Quote
Old 09-04-2018, 11:28 PM   #20
N1rve
N1rve's Avatar
So my vendor (installer/mechanic) has been going back and forth with Wilwood asking for replacement rotor rings or any other possibility without removing the rotors from the car and shipping it them and leaving the car out of commission for a few days and they are saying no. They are asking for the rotors to be shipped to be measured for run out or whatever. I think as a vendor like Wilwood, they should be fine with cross shipping rotors. Especially if it's vendor to vendor and not vendor to customer directly.
I convinced my vendor/installer to resurface the rotors and hopefully that would fix the issue. Going to attempt this Saturday. Ugh, cmon Wilwood...is it that difficult to ship your vendor a set of spare rotors to trouble shoot?
So far my experience with Wilwood support..... terrible. I don't know if Brembo, StopTech or AP Racing would have a better support line if it's vendor to vendor.
N1rve
Troubleshooting Idle bfsnail Forced Induction 3 12-03-2016 06:05 PM
BRZ DRL Troubleshooting MaximaZero Issues | Warranty | Recalls / TSB 2 11-17-2015 04:31 AM
Troubleshooting with a KW c38 pgranberg11 Forced Induction 7 10-13-2015 08:05 AM
Need troubleshooting help. Camop82 Scion FR-S / Toyota 86 GT86 General Forum 6 10-14-2013 02:16 AM
Start up troubleshooting. Gost Other Vehicles & General Automotive Discussions 12 01-09-2011 06:45 PM
