Old 08-11-2018, 02:47 PM   #1
N1rve
N1rve's Avatar
Drives: 2019 BMW ///M4
Big Brake Kit Troubleshooting help.
Hi Folks with Wilwood BBK or BBKs, need your help troubleshooting an issue.
I got Wilwood 6Pot front and 4 Pot rear Drilled and Slotted rotors with B10 pads installed last weekend. Brakes were also bled, converted from DOT 3 OEM Fluid to DOT 4 ATE.
Been driving them with 100 miles on them and in the pedal, since brand new, I've experienced rumbling and vibration in the pedal and in the car.
When I lightly brake from 65 -> 40, the entire car vibrates like the brakes are catching on the slots on the rotors. There is pulsating in the brake pedal. The car pulls slightly right while braking.
From 40-30, there is still vibration in the car chassis but not as much as from 65-40. There is also a pulsating feel in the pedal like I am hitting ABS but I am not hitting ABS. The car pulls slightly right while braking.
From 30-0, it the brakes feel like normal brakes, smooth.
Thing's I've tried so far:
1) Re-Bed Brakes by doing stops from 30-5, 40-5, 50-5, 65 - 5 and coasting to cool the brakes off.
2) Inspected the brakes, I have noticed that the front driver side inner pad slightly sticks out 1/2mm while the outer pad is completely flush. Checked Passenger Front Side and both pads are flush.
3) Noticed that the wheels now sit on the brake hat and not the actual hub anymore. Wheels are 18X9.5 +38 Work Emotion Kiwami with 255 35 R18 MPS4. I don't have hub rings since I've read that once the wheels are torqued with lug nuts, the clamping force of the lug nuts do the work while the hub ring just goes along for the ride.
4) Considering re-bleeding the brakes. I doubt there is an air bubble since the brake pedal is very stiff and there is no brake fade.
5) Lug nuts have been retorqued many times from inspecting.
6) No leaks of brake fluid, brake fluid level is the same.
Is this vibration going to go away after more mileage? Or did Wilwood send me some non-true rotors? Possibility of a brake piston not returning or uneven brake pressure from the pistons? Ideas of how to check that?
N1rve
Old 08-11-2018, 03:26 PM   #2
ls1ac
ls1ac's Avatar
check to find out why one pad is different.
bed by going 70-5 in 3 sec. ie at ABS limit. several times to get things warmed up.
big brakes are meant for hard stopping.
Old 08-12-2018, 03:50 AM   #3
N1rve
N1rve's Avatar
So I tried this, the vibration went away slightly but the brakes started to make a grinding noise. It's not a brake squeal at all...? Went away as soon as the brakes cooled down. Still getting some vibrations.
N1rve
Old 08-12-2018, 10:03 PM   #4
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
Not sure what you mean by "sitting on the brakes hat" means but wheels and breaks should not touch at all. If your wheels are hitting the your brakes that's your problem.
Try buying some spacers if it does hit. You can buy cheap-o's at any auto parts store.
As far as the hub rings, it does help.
Old 08-12-2018, 10:04 PM   #5
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
Are you able to go on the side with extended pad and dissassemble the caliper and make sure the pad is seated properly?
Old 08-12-2018, 10:50 PM   #6
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
The "hat" is what is commonly referenced as the inner part of a two piece rotor.
OP.
Double check that assembly is correct, then go and bed the brakes in hard. at least 10 stops from 70-30, then drive around without touching the brakes for 10-15 minutes. You get some slight pulsation from the slotted rotors, but any more then that is not normal.
I had a similar issue when I first went BBK, it takes a lot more heat to bed them in then the stock brakes.
Old 08-12-2018, 11:10 PM   #7
N1rve
N1rve's Avatar
For two piece rotors there is a "hat" which is the part where you put it on the hub. The contact piece of where the actual brake pads meet and contact the rotor, is replaceable.
Yes, the pad is seated correctly, even try to hit the bracket to push it closer to the rotor. Might be a QC issue with Wilwood.
OP.
I will try to bed them in....with higher speeds and more times.
N1rve
Old 08-12-2018, 11:21 PM   #8
FRSBRZGT86FAN
I know you'd like to fix this DIY, but you could also find a shop close to you that handles wilwood and brembo BBK installs to look at it and find the issue just in case the bedding process doesn't work out. It's very possible you could accidentally wear something incorrectly if it's got a QA issue.
https://www.wilwood.com/Tech/Index
https://www.wilwood.com/TechTip/TechContact
Old 08-12-2018, 11:43 PM   #9
Mr.ac
Mr.ac's Avatar
Drives: BRZ Premium
Ah. Brake hat got me confused, should have wrote as rotor hat.
Old 08-12-2018, 11:53 PM   #10
Stang70Fastback
A.K.A. Starlord
Stang70Fastback's Avatar
Drives: 2015 Series.Blue
You mention an ABS-like pulsing in the brake pedal when the car pulls to one side. Are you sure you didn't damage one of the ABS/wheel speed sensor wires, or rings during the install somehow? It almost sounds like you're having ABS issues when braking from higher speeds.
You aren't getting any lights on the dash, are you? You might want to pull your ABS fuse(s) and try braking without it just to see if that has any effect on the pulsing pedal and the pulling to one side. I know you said that the whole car was ALSO shaking, which ABS shouldn't cause, but it doesn't hurt to rule out any ABS issues.
Check out my blog, read all about my BRZ adventures, and oogle my sweet cell-phone photos!
You can also find me on Instagram, and on Facebook.
Stang70Fastback is offline   Reply With Quote
Old 08-13-2018, 01:05 PM   #11
N1rve
N1rve's Avatar
I don't have any ABS lights on the dash. If I brake harder, then I can feel additional pulsating through the pedal.
I did do some more hard braking and it seemed to help a little bit in terms of vibration, but light braking still vibrates really bad.
N1rve
Old 08-13-2018, 02:20 PM   #12
Stang70Fastback
A.K.A. Starlord
Ah ok. That sounds like it's just mechanical vibration from the brakes, then. Have you identified what is causing one pad to sit differently from the rest?
Old 08-13-2018, 03:51 PM   #13
N1rve
N1rve's Avatar
I'm pretty sure it's the bracket. But it's only 1/2mm so I dont think that would make a huge difference?
N1rve
Old 08-13-2018, 09:11 PM   #14
ls1ac
ls1ac's Avatar
These are huge brakes for a street car with lots of cooling. It will be very difficult to get them up to proper operating temperature on the street. Might suggest a street pad for daily and save those pads for track.
Still think a check of install is in order to determine miss aligned pad.
Some track pads make a grinding noise when cold, but a check of surfaces for a rub is in order.
Troubleshooting Idle bfsnail Forced Induction 3 12-03-2016 05:05 PM
BRZ DRL Troubleshooting MaximaZero Issues | Warranty | Recalls / TSB 2 11-17-2015 03:31 AM
Troubleshooting with a KW c38 pgranberg11 Forced Induction 7 10-13-2015 07:05 AM
Need troubleshooting help. Camop82 Scion FR-S / Toyota 86 GT86 General Forum 6 10-14-2013 01:16 AM
Start up troubleshooting. Gost Other Vehicles & General Automotive Discussions 12 01-09-2011 05:45 PM
