Old 08-13-2018, 10:28 PM   #1
Magiclow
Drives: 2013 Ultramarine Blue FRS
Engine Cooling options
Hello
I have been taking my car to the track and I have couple questions on engine cooling.
1. after 4 laps the car is at 250 degrees, I don't know if its too hot or not, can somebody tell me @ what temp will it become an issue for our engine?
2. if cooling is needed, should I be looking at a upgraded radiator as well as an oil cooler? what other options do I have?
3. also what brand do most people recommend?
Thank you for your help!
Magiclow is offline   Reply With Quote
Old 08-13-2018, 11:23 PM   #2
Originally Posted by Magiclow View Post
Hello
Here are my thoughts for you, till someone comes along that knows what he is talking about.
The coolant temperature at 250 degrees F should be OK, as long as the coolant hasn't reached its boiling point. The boiling point is determined by the coolant composition and the pressure the coolant is under.
So, with a coolant mixture of 50/50 water/ EG, and at a pressure of 15 psi, the engine should be OK running at 250 degrees F.
However, I wouldn't run an engine too long at that temperature.
Wait - someone is coming along -
Magiclow (08-14-2018)
Old 08-13-2018, 11:56 PM   #3
norcalpb
norcalpb's Avatar
250 oil or coolant temp?
Old 08-14-2018, 10:27 AM   #4
Magiclow
Oil Temp, I saw it on my Openflash tablet
Old 08-14-2018, 10:34 AM   #5
You need to get that oil temp down. The rad is probably fine.
Give this a read http://www.ft86club.com/forums/showthread.php?t=114293
Magiclow (08-16-2018)
Old 08-14-2018, 10:35 AM   #6
RFB
RFB's Avatar
Drives: FRS
Max Temp
What is the safe maximum, constant, (lap after lap) oil temp for the twins on the track with thicker track oil ?
RFB is offline   Reply With Quote
Old 08-14-2018, 10:39 AM   #7
250 would be "safe" but if you are hitting that high on a regular basis then you are running the risk of going over which could be a problem.
Old 08-14-2018, 10:44 AM   #8
Trueweltall
Trueweltall's Avatar
Drives: 2016 Subaru BRZ
  • 100-169F Warm Up Phase, high oil pressures
  • 170-189F Near Operating temps, oil pressures still higher
  • 190-225F Normal Operating Range, oil pressures normalize
  • 225-245F Middle End of operating range for track use, 5% drop in oil pressures
  • 245-255F Upper End of operating ranges for track use, 10% further drop in pressures on 0w20
  • 255-265F Red Zone of operating ranges for track zone, 0w20 starts to thin, oil pressures drop to questionable range.
  • 265F+ Playing with fire on 0w20
Trueweltall is offline   Reply With Quote
The Following 5 Users Say Thank You to Trueweltall For This Useful Post:
gtengr (08-14-2018), Magiclow (08-16-2018), mrg666 (08-14-2018), RFB (08-14-2018), TofuJoe (08-15-2018)
Old 08-14-2018, 10:58 AM   #9
RFB
RFB's Avatar
Drives: FRS
Thanx !
What kind of oil pressure drops (in psi) are you seeing at high temp with 20 ?
Old 08-14-2018, 11:21 AM   #10
Oh, I thought you were talking about coolant temperature -
Old 08-14-2018, 11:33 AM   #11
Trueweltall
Thanx !
Once I hit 240 with 0w-20 my oil pressure at idle is almost nonexistent on the gauge, it's in the single digits and sets off the warning light.
Old 08-14-2018, 11:56 AM   #12
RFB
RFB's Avatar
Drives: FRS
Thanx, wanted to set my oil pressure alarm, 0 was the default on the gauge, and an alarm at zero is to late - lol.
Old 08-14-2018, 12:31 PM   #13
norcalpb
norcalpb's Avatar
I hit 250 on every run at Laguna last weekend with my Forester XT oil cooler.
Sounds like we both need something more heavy duty.
Old 08-14-2018, 01:04 PM   #14
re-animator
i don't think i would use 0w20 on the track m8.
re-animator is offline   Reply With Quote
2jz to BRZ engine management options?? Clash0901 Engine Swaps 21 12-02-2017 11:35 AM
Smoke testing for FI engine bay cooling mike the snake Forced Induction 16 04-30-2014 09:25 AM
FS: Password JDM Carbon Fiber Engine Cover and Cooling Plates FRSTRM Engine, Exhaust, Bolt-Ons 9 03-21-2014 01:22 PM
New full carbon fiber engine cooling plate from APR GuerillaRacing Engine, Exhaust, Transmission 6 01-22-2014 12:53 PM
Bushing upgrades, geometry options and other component options? der_rainman Suspension | Chassis | Brakes -- Sponsored by 949 Racing 10 06-26-2013 12:53 PM
