Old 08-10-2018, 09:45 AM   #29
ZZT86
ZZT86's Avatar
Drives: BR86
^^ that's fine but for those of you that often daily theirs & do repeated short trips is why the oil quickly grenades itself.
ZZT86 is offline   Reply With Quote
Old 08-10-2018, 03:55 PM   #30
kch
Senior Misanthrope
kch's Avatar
Originally Posted by Pat View Post
Yeahhhh... I'm pretty sure that's not a problem. My oil gets to 270 on track days.
I wouldn't run my oil more than one weekend if my temps were getting that high. I have a Setrab 619 oil cooler and my temps max out around 230, so I feel more comfortable using the oil for multiple events.
The Following User Says Thank You to kch For This Useful Post:
Pat (08-10-2018)
Old 08-10-2018, 04:21 PM   #31
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
That seems a little high to me, your car could benefit from an oil cooler.
Old 08-10-2018, 04:34 PM   #32
FRSBRZGT86FAN
Originally Posted by supercommode View Post
Thanks everyone. Lot's of good info and opinions. I'm still deciding on which fuel to run primarily. The E-85 takes a big hit on mileage and I drive about a 100 miles a day. However, it's about $0.60 cheaper... At any rate. Thanks again.
I've used E85 heavily around 40k miles on my 86, with a similar setup to someone else having a CNT UEL and OFT. I used it locally and it was very fun, the extra power boost is intoxicating
I also calculated it was close to .90 cents cheaper than 93 most of the time so the mpg hit was slightly countered by cost.
If I ever plan to do a long distance trip thats more than 210 miles round trip, I fill with 93 and swap the tunes, that's assuming an over 35 percent range hit on the vehicle and that's a little on the high side estimate for me to be safe.
Also rather than than the 7500 miles change intervals I cut mine down to 4500, only because the oil consistency and smell had changed and I wanted to be safe. I haven't done an oil analysis but it doesn't hurt anything but my wallet to play it safe and shorten the intervals. I suggest you look into doing the same
Old 08-14-2018, 09:51 PM   #33
Surok
Wise old man
Surok's Avatar
Drives: 86 GTS
i went back to 98 or as close as i could bear.. i got it down to E13... god 98 is SLOW! back to E85 for me!
Surok is offline   Reply With Quote
The Following User Says Thank You to Surok For This Useful Post:
chaoskaze (10-30-2018)
Old 08-14-2018, 11:11 PM   #34
ZZT86
ZZT86's Avatar
Drives: BR86
I've been on E85 since 2014 . . . it's cleaner for the environment . . . our 98 is crap.
Old 08-31-2018, 03:36 PM   #35
chaoskaze
The Fail Boat
chaoskaze's Avatar
Drives: CWP S.B.
Actually I got to e85 recently. Cuz I started running out of things to mod....lol
I noticed my oil is a lot more watery when cold. *it drips faster, but seems the same when hot.
Will report everything I notice long term wise + maybe oil report.
Old 08-31-2018, 05:52 PM   #36
jubella2
jubella2's Avatar
Drives: DGM BRZ
When I did the math I found E85 cost 11 cents per mile and 92 was 12 cents so it basically evens out.
jubella2 is offline   Reply With Quote
Old 08-31-2018, 06:02 PM   #37
FRSBRZGT86FAN
That's interesting, I had much better cost differences, 93-91 prices change so much more than e85 so I guess that helped. Also in my area there was only one racing fuel station with e85 so he would always competitively change prices.
Old 10-19-2018, 08:16 PM   #38
Breadman
Breadman's Avatar
Drives: 2017 BRZ w/PP
Here is my blackstone with 4 autocrosses on flex fuel. 2750 miles on 0w20 synpower
The Following User Says Thank You to Breadman For This Useful Post:
MugsBRZ (11-25-2018)
Old 10-19-2018, 09:09 PM   #39
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
With the supercharger, I tend to go thru tires much quicker and have more wrinkles on my face from smiling when I run e85.
carsebuco (10-20-2018)
Old 10-20-2018, 11:45 AM   #40
Lantanafrs2
Drives: 2013 frs red
The only long term problem for me is the desire for more power. Header made it better but will a snail make it wail?
Lantanafrs2 is offline   Reply With Quote
Old 09-04-2019, 02:24 PM   #41
DandoX
Senior gif poster
DandoX's Avatar
Drives: 2013 Asphalt FRS
Originally Posted by kch View Post
I know this is an old thread, but if anyone is still concerned with long-term use of E85, this is the most recent UOA I have after using E85 for roughly 40k miles.
Sorry to revive an old thread, just saw this and that Black Stone report looks great. Mind giving an update now? Also what kit/tune are you using?
I'm running 0w40, do you think that would change how it reacts with E85?
DandoX is offline   Reply With Quote
Old 09-04-2019, 04:11 PM   #42
kch
Senior Misanthrope
kch's Avatar
Oil weight should make no difference w/r/t E85. I was using the moto-east kit with the evap harness, tuned on ecutek.
Sadly, I moved up to the PNW where E85 is hard to come by, and I stopped using it. But E85 never caused me any problems.
DandoX (09-04-2019)
Long term E85 use redrocket89 Engine, Exhaust, Transmission 92 06-28-2021 06:40 AM
Long-term adverse effects of Whiteline chassis inserts? ApexEight Suspension | Chassis | Brakes -- Sponsored by 949 Racing 18 09-07-2017 08:13 AM
long term and short term brichard0625 Engine, Exhaust, Transmission 7 08-26-2013 09:56 AM
Fuel Trims - Long term and short term victorb Engine, Exhaust, Transmission 6 03-27-2013 03:18 PM
Short Term and Long Term Fuel Trims naikaidriver Engine, Exhaust, Transmission 3 03-18-2013 10:55 PM
