Old 08-09-2018, 09:39 PM   #1
SuperTom
SuperTom's Avatar
Drives: C5, GT-86, '24 Colorado TrailBoss
DIY rear bumper air shield
Purpose is to create a wind shield when changing from a stock style suitcase muffler. This should stop air from getting trapped behind the rear bumper which creates a parachute.
I have the Borla exhaust which drops ~10lbs off the car. I know Borla has there own diffuser for their exhaust but it also adds ~8lbs back on. Negating the weight loss of the exhaust.
For the record I want to make this out of a sheet of Carbon Fiber. I would need a 2' x3' sheet to make. 2x4 sheets are $300 for 1mm thick. Crazy! If anyone can find a sheet cheaper please let me know
For this version I used Coroplast as the plate. I want lightweight,I have no idea how the coroplast will hold up. At least I can transfer the design if I find a better material to use
Materials used all found at home depot
Sheet of coroplast need at 2'x3' to work with
Threaded rods
Hollow aluminum tube
nuts bolts washers, fender washers
Total weight 1.5lbs
weighted everything at ~2lbs then minus everything I didn't use ~.5lbs
Parts on scale
Rods bolted up to stock heat shield brackets.
Now showing the aluminum tubes with fender washers giving a solid mount for the shield
Installed! The plate tucks inbetween the rear stock diffuser and mount. used the stock rear diffuser attachments just switched out the black plugs with bolts. Also cut the rod bar after everything was mounted.
An inside view
Have it up all the way to the rear subframe. Plate sits on top or the LCA bolts
Final pic!
UPDATE POST 23!!
SuperTom is offline   Reply With Quote
The Following 6 Users Say Thank You to SuperTom For This Useful Post:
EndlessAzure (03-24-2019), jordan7831 (08-11-2018), Mazikowski (08-10-2018), MJones_RB (08-17-2018), norcalpb (08-14-2018), sato (08-10-2018)
Old 08-10-2018, 10:04 AM   #2
D-rek07
How much clearance between the coroplast and the exhaust pipe? Like where the exhaust pipe goes through that cut out?
D-rek07 is offline   Reply With Quote
Old 08-10-2018, 10:15 AM   #3
SuperTom
SuperTom's Avatar
You can see from the last pic about 1/2" around the pipe area. Gave it more room with the coroplast so it doesn't melt. If I can find cheaper carbon fiber I would cut it closer so no air can't sneak up there
Old 08-10-2018, 11:10 AM   #4
D-rek07
Originally Posted by SuperTom View Post
You can see from the last pic about 1/2" around the pipe area. Gave it more room with the coroplast so it doesn't melt. If I can find cheaper carbon fiber I would cut it closer so no air can sneak up there
Why carbon fiber over aluminum?
Old 08-10-2018, 01:59 PM   #5
SuperTom
SuperTom's Avatar
WEight
Old 08-10-2018, 02:31 PM   #6
D-rek07
WEight
Approximately 1.5 lbs lighter. Is that worth the added cost?
Old 08-10-2018, 03:00 PM   #7
8RZ
The Gunshine State
8RZ's Avatar
Drives: '14 BRZ Limited
For him it was, nice job Tom.
Current DD: M235i
8RZ is offline   Reply With Quote
The Following User Says Thank You to 8RZ For This Useful Post:
SuperTom (08-10-2018)
Old 08-10-2018, 03:00 PM   #8
SuperTom
SuperTom's Avatar
Carbon fiber sheet at 1mm thick should be lighter and stronger than aluminum. im looking for at least a 2'x3' sheet. Where are you getting your measurements from please source. 1mm thick aluminum might not be strong enough Id have to hold it in my heads to check for flex
Old 08-10-2018, 03:10 PM   #9
SuperTom
SuperTom's Avatar
home depot has sheets at .019" thickness which equates to about a .5mm I will check those out to give me an idea
Old 08-10-2018, 04:31 PM   #10
D-rek07
You're probably right. I just found the weights of a 2" x 3" by 1mm sheet of CF and AL. 1mm aluminum probably would be too thin, but it doesn't need to really structurally support anything. I'm just bored at work, so thought I would give the feedback.
Old 08-10-2018, 04:36 PM   #11
D-rek07
A 2" x 3" by 0.5mm thick piece of aluminum weighs .783kg or 1.72lbs.
A 2" x 3" by 1 mm thick piece of carbon fiber weighs .875kg or 1.93lbs.
Just using densities of the materials.
Old 08-10-2018, 04:39 PM   #12
SuperTom
SuperTom's Avatar
Well I read on the ecomodders forums many of them use coroplast to create flat panels under the cars. Although a rock bouncing up could easily punch a hole in it.
Aluminum may be enough I just don't want it to flex crazy if a lot of wind goes through that area. But I don't think it has to be super solid stiff to work. I will test that aluminum sheet when I go to home depot tomorrow. And hopefully its not too heavy.
Old 08-10-2018, 05:00 PM   #13
I don't see any reason to change up what you have now. Looks great and will be just fine on the highway. It's already tougher than the bumper cover.
Old 08-10-2018, 06:13 PM   #14
D-rek07
Any idea what the heat resistance of that plastic is? I know the bumper is very close to the exhaust but the material properties I'm sure are different between the two plastics.
The Following User Says Thank You to D-rek07 For This Useful Post:
Ultramaroon (08-10-2018)
What are my options for a rear bumper/bumper cover/etc that would fit TRD exhausts. GNious Cosmetic Modification (Interior/Exterior/Lighting) 23 05-04-2017 06:07 PM
WTB - Front Lip/Bumper Splash Shield OEm Xplicit Canada Classifieds 0 04-10-2017 06:33 PM
Rear Bumper Exhaust Shield Ryan5x Cosmetic Modification (Interior/Exterior/Lighting) 27 08-27-2016 12:16 AM
Free-Rear bumper cover (entire rear facia) replaced after slight rear-end collision n7011n Exterior Parts (Aero, Lighting, Etc.) 7 03-26-2014 04:46 AM
How long to wait to put x-pel shield on after bumper re-painted? Ammunition Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 1 02-21-2014 03:14 PM
