Old 08-04-2018, 11:44 AM   #1
Elliotw
Elliotw's Avatar
Drives: '18 BRZ tS, '18 GTI SE, '11 RS
Question Low profile jack
My current low profile jack doesn't work on the front jack spot of the car without driving up on ramps. because of the STI front lip. I was curious if anyone has had success with a low profile jack that works with the STI front lip(without ramps)? If so please link the model of jack that works.
Thanks
Elliotw is offline   Reply With Quote
Old 08-04-2018, 01:04 PM   #2
stevesnj
stevesnj's Avatar
Low profile ramps maybe?
https://www.discountramps.com/plasti...mps/p/6009-V2/
My 2016 Build thread
Old 08-04-2018, 05:56 PM   #3
asdf
Loading...████████] 99%
asdf's Avatar
Drives: #0517
What I have always ended up doing is using the scissor jack on the front side to bring it up a little bit first and then have no problems getting a floor jack under the front bumper. Then up in the air and onto stands
R1 3 5
. 2 4 6
asdf is offline   Reply With Quote
Old 08-04-2018, 07:05 PM   #4
Trueweltall
Trueweltall's Avatar
Drives: 2016 Subaru BRZ
https://www.amazon.com/gp/aw/d/B007G...RJC?th=1&psc=1
Trueweltall is offline   Reply With Quote
Old 08-06-2018, 08:38 AM   #5
BigTuna
BigTuna's Avatar
Drives: 2013 WRB BRZ
When I was lowered, my jack wouldn't fit either. I build some low profile ramps out of some 1x12 board. after driving up on it, the jack slid right under.
Something like this. https://forum.miata.net/vb/showthread.php?t=537487
I've also got a low profile jack from harbor freight that works like a charm as well.
https://www.harborfreight.com/3-ton-...ump-62326.html
BigTuna is offline   Reply With Quote
The Following User Says Thank You to BigTuna For This Useful Post:
stevesnj (08-11-2018)
Old 08-09-2018, 03:36 PM   #6
kch
Senior Misanthrope
kch's Avatar
Harbor Freight used to have a 2-ton ultra-low-profile floor jack that fit under my STI lip (barely), but it seems they no longer carry it. :-\
Edit: it was pretty similar to this one but less expensive.
Edit2: This is it. Seems prices have gone up since it was discontinued...
Old 08-09-2018, 04:50 PM   #7
Stang70Fastback
A.K.A. Starlord
Stang70Fastback's Avatar
Drives: 2015 Series.Blue
The ARCAN jack that @Trueweltall posted an Amazon link to was what I was going to recommend. It isn't cheap, but it works. It gets to the front jack point on my BRZ without ramps... and my BRZ is lowered... and has a front lip.
It will also jack the car incredibly high, making it super easy to work underneath
Check out my blog, read all about my BRZ adventures, and oogle my sweet cell-phone photos!
You can also find me on Instagram, and on Facebook.
Stang70Fastback is offline   Reply With Quote
Old 08-09-2018, 09:59 PM   #8
Trueweltall
It's worth it if you're lowered more than 1/2 inch, that's for sure! The Arcan extra low profile jack will last you a lifetime probably. If you're using the stock muffler and you're lowered, it will not get in the way when you slide it under to the rear diff.
Old 08-10-2018, 08:53 AM   #9
Willie Swoopes
Junior Pizza Joe
Willie Swoopes's Avatar
Drives: 2017 BRZ Limited Manual WRB
Just got a Harbor Freight low profile Jack for my birthday yesterday.
Wife asked what I wanted and...
Steel 3 ton lowered 2-7/8 inch raised 19 1/2 inch about $90
Item #62326
Fits (with an inch of clearance) under the mostly stock 2017.
So today I'm doing oil changes! Any love for the Fumoto valve?
Scooby-Doo: Scooby-Dooby-Doo!
Shaggy: And like, Shaggy too.
Willie Swoopes is offline   Reply With Quote
Old 08-10-2018, 09:22 AM   #10
JoeC
Drives: Subaru BRZ Limited
Item #62326
I have the same jack. I have to drive up on a couple 2x6s but I'm pretty low with a front lip.
Also have the fumoto (on all my cars). It's a fantastic little upgrade.
JoeC is offline   Reply With Quote
Old 08-10-2018, 04:53 PM   #11
edwardl
Drives: 2018 BRZ
Two of these:
edwardl is offline   Reply With Quote
The Following User Says Thank You to edwardl For This Useful Post:
8RZ (02-06-2019)
Old 08-10-2018, 06:23 PM   #12
Willie Swoopes
Junior Pizza Joe
That's some high tech there! I wonder if Subaru might take notice and add it to the new BRZs.
Old 02-02-2019, 02:32 PM   #13
Silverz
Drives: Black frs
Originally Posted by stevesnj View Post
No. I have a set of those low profile ramps and they don’t get the car high enough to do anything. Plus ramps are even tougher to use because the lip has to go over them.
You may have to jack up from the side under the jack points.
Silverz is offline   Reply With Quote
Old 02-06-2019, 10:55 AM   #14
racetz39
Drives: 2018 BRZ-tS WHC 476/500
[QUOTE=Elliotw;3117866]My current low profile jack doesn't work on the front jack spot of the car without driving up on ramps. because of the STI front lip. I was curious if anyone has had success with a low profile jack that works with the STI front lip(without ramps)? If so please link the model of jack that works.
I've also got a BRZ tS, my 3 ton jack just slips under the front lip and reaches the metal crossmember for jacking. Lifts nice and high too.
https://smile.amazon.com/gp/product/...?ie=UTF8&psc=1
racetz39 is offline   Reply With Quote
Harbor Freight - 3 Ton Low Profile Jack SmartedPanda DIY (Do-It-Yourself) Guides 41 01-16-2018 11:15 PM
Craftsman 2-1/2 Ton Floor Jack, Low Profile for $39.99 at Sears No1der Southern California 1 04-28-2016 11:29 PM
WTB: Low profile floor jack and jack stands! lupindub Want-To-Buy Requests 2 11-26-2015 11:03 PM
Low Profile Jack? PMPB CANADA 20 03-19-2015 09:56 PM
Harbor Freight Low Profile Jack on sale $139 DarrenDriven Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 28 10-06-2014 06:18 PM
