Old 08-09-2018, 12:05 AM   #15
Randomizer
Drives: Its stock nothing else....or is it?
Originally Posted by Strife26 View Post
Isn't there a sticky post that has "all" the exhausts and some have decibels?
Yeah sadly I'm a bit lazy to go and look through all of them......so yeah.
Randomizer is offline   Reply With Quote
Old 08-09-2018, 12:07 AM   #16
jflogerzi
jflogerzi's Avatar
Quiet is relative... Are you planning to do Headers at all? If so start their and then do your exhaust. Youtube should provide you tons of clips.
Old 08-09-2018, 12:07 AM   #17
Randomizer
Originally Posted by Spawn_Of_Creation View Post
Perrin 2.5" Resonated
HKS Legmax Sports (Dual or Quad)
Invidia Q300
Stock OEM
Do the three have some performance gain?? by any chance?
I do want it a bit better in same way than the stock other than quiet.
Old 08-09-2018, 12:24 AM   #18
Randomizer
No the header is gonna stay stock. Just a quiet exhaust with some "performance gain" if its possible. Better than nothing.
Old 08-09-2018, 12:26 AM   #19
jflogerzi
jflogerzi's Avatar
Butt Dyno is not gonna feel any difference. Change in exhaust is purely for sound. So I would base my decision off of this. Header+Tune will give you more sound and power for the same price as a full cat back system.
Gruppe-S at 475$(Basically the same as Tomei just cheaper w/o name)
and a used OFT v1 for 400$
This is by far the best combo for the twins under 1K. the Stage 2 tune for OFT works well with this header as long as you still have stock airbox.
The Following User Says Thank You to jflogerzi For This Useful Post:
Strife26 (08-09-2018)
Old 08-09-2018, 12:28 AM   #20
jflogerzi
jflogerzi's Avatar
well damn forget my next post. My vote is Perrin 2.5 inch. Take a look at Corsa. Its designed for stock header and sounds really good based on video's I have seen
Old 08-09-2018, 12:49 AM   #21
Randomizer
Hmmm.....so just header. I have the stock airbox which I'm not planning to swap. A tune is needed for the new header. Is it gonna effect the emission? I'm not gonna get a check engine light am I?
Old 08-09-2018, 01:01 AM   #22
Spawn_Of_Creation
Human
Drives: 2015 BRZ Black
No, the tune oft stage 2 tune removes the primary cat check, which is the normal cause the check engine light after installing a cattless header. As long as you have the secondary cat in the front pipe, you should still pass emissions (excluding California which does a visual check.)
"Always listen to experts. They'll tell you what can't be done, and why. Then do it." - The Notebooks of Lazarus Long
Spawn_Of_Creation is offline   Reply With Quote
Old 08-09-2018, 01:22 AM   #23
Randomizer
Yeah I live in Cali so its gonna be hard for me.
Old 08-09-2018, 01:27 AM   #24
jflogerzi
jflogerzi's Avatar
swapping stock headers only takes a few hours. If you feel comfortable, its a job you can do with basic hand tools, jack stands and a jack. Don't drive like an ahole and you will be fine. Now nothing is 100% and your are taking a risk so keep that in mind.
Old 08-09-2018, 01:29 AM   #25
jflogerzi
jflogerzi's Avatar
OFT will disable the CEL for the missing primary cat. In CA you will not pass smog test/emissions.
Old 08-09-2018, 01:36 AM   #26
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
You've got more patience than most of us, this dude could've found all the info he needed had he sat down and just researched and flipped through the forum
The Following 2 Users Say Thank You to FRSBRZGT86FAN For This Useful Post:
humfrz (08-09-2018), new2subaru (08-09-2018)
Old 08-09-2018, 01:40 AM   #27
jflogerzi
jflogerzi's Avatar
I had a long break from the forums... thus my tolerance levels are higher for now LOL
FRSBRZGT86FAN (08-09-2018)
Old 08-09-2018, 01:46 AM   #28
Ya, I agree.
Usually, I'm patient with newbies, but, with this dude, I asked a question that he didn't answer, then I made a suggestion that he scoffed at.
I must have missed one of my meds today!
brz, exhaust, quiet
quiet and loud exhaust both in 1 JonMotoring Engine, Exhaust, Transmission 28 04-24-2020 02:22 PM
Help, need quiet exhaust Lunatic Engine, Exhaust, Transmission 47 02-07-2019 12:41 AM
quiet 3" exhaust blown Engine, Exhaust, Transmission 20 05-18-2016 01:10 AM
I need a quiet exhaust system 2.5-2.75" johnmk Forced Induction 12 04-07-2016 10:50 PM
Quiet exhaust s2kdrew Engine, Exhaust, Transmission 21 06-25-2012 11:22 PM
