Fidei Defensor
Drives: 2015 Subaru BRZ Limited - Black
Hello folks,
I'm having the ptuning turbo kit (w/ GTX2867R) installed in a few weeks, and need to figure out what to do about the exhaust. I'm concerned about noise, inside and outside of the vehicle, as I drive in a lot of neighborhoods where excess noise would not go over well. I'm also not a fan of needless noise myself, nor are my passengers. My goal is a sleeper vehicle with a modest boost to power. What I'm reading seems to indicate that the larger the exhaust diameter, the louder the exhaust. Also, since my turbo goals are no higher than 300 horsepower, I don't see the need for a 3" (76mm) exhaust. The sweet spot appears to be around 2.5" (63mm). I think 2.75" (70mm) would be tolerable as well. The stock exhaust being, if I read elsewhere correctly, 2.25" (57mm). I'm not 100% sure that's right though but I can't imagine it being any higher than 2.25". These metric conversions appear quite odd to me, by the way, since I would think the car's specs would be conceived in metric. Why would a non-US car company bother with such odd values as 57mm for an exhaust, when 55mm or 60mm are cleaner values? I wonder if the stock exhaust is really 55mm (2.165"), but anyway, I digress quite unnecessarily here. :-) The ptuning turbo kit dumps the wastegate into the exhaust, by the way. I'm not sure if that's relevant to my central question in this thread, but it could be if a small diameter exhaust system restricts exhaust flow at a bad time -- I don't know if that's a concern, or not. I'm considering the Invidia Q300 cat-back exhaust, but diameter appears slightly to the low side of my goal (2.5 being ideal, I think). At only 2.36"(60mm), it doesn't appear to be that much of an upgrade from stock (55mm), though 60^2/55^2 = 1.19. So Q300 has almost 20% more cross-sectional area and should flow at least a bit more air than stock. The Q300 being cat-back, how would I mate it with the ptuning turbo kit components? Is there something a bit roomier than the Q300 that's also quiet and can be mated with the ptuning turbo kit? I guess anything I get will probably need to have a suitcase-style muffler. Here's the exhaust system that ptuning have designed for use with their kit. http://www.ptuning.com/subdir/itemde...&ModelDesc=BRZ It looks top-notch, but IMO the emphasis appears to be on performance and not noise-suppression. Those mufflers seem awfully small. Is size a fair way to predict muffler performance, in general? Anyway, please folks. Help me out! There are a dizzying array of options out there and I must decide soon, or my install schedule has to slip. Thank you so much for your time folks. -John Last edited by johnmk; 04-05-2016 at 11:34 PM. |
Drives: GT 86
i know the blitz nur spec is queit
Look at ft86speedfactory, they will have diameters listed on all their exhausts. I was told the suitcase or other large mufflers are more effective than the tuner style cans. I've listened to many sound clips but due to a variety of recording situations they all sound exactly the same to me. My best advice is to find all the exhausts in your price range with the size pipe you want, make a list, pick one of those. Also, I've heard the stock cat back isn't restrictive so I would imagine anything with a larger pipe(like q300) would be fine for 300hp
To mate other exhausts to our turbo kit, all you need is this v-band to 2-bolt adapter: http://www.ptuning.com/subdir/itemde...&ModelDesc=BRZ
Another quiet option would be the Perrin 2.5" w/ resonator: http://www.ptuning.com/subdir/itemde...&ModelDesc=BRZ |
Fidei Defensor
Will the Perrin 2.5" w/ resonator definitely flow more air than stock, and by a significant margin?
Killed Scion
Drives: 2013 FR-S Whiteout
If you're looking for a 2.5in that's quiet and not invidia q300 go with the Perrin Resonated. They also offer the perrin resonated in a 3in as well.
Miyuki みゆき "Beautiful Snow" The Whiteout FR-S Instagram: trevor.parque |
taicho
Drives: The rEd Fr-S
Corsa FTW
Drives: Velocity Orange 86 GT
I run a q300 turboed. Works just fine. The front and overpipe ahould be more your concern. The 911s never hear me coming
#9 | |
Drives: 2005 Toyota Camry
-alex |
#10 |
#11 |
Drives: BRZ & Forester
I am quite happy with my WORKS Exhale ABM (Axle Back Muffler) Exhaust and do not consider it being ‘too loud’ (muffler audio at provided link).My BRZ @WORKS ::: http://www.ft86club.com/forums/showp...1&postcount=43 sporting the ABM. |
#12 |
Drives: 1993 Impreza w/ WRX Swap + FWD!
If you truly want "quiet" and not just "less loud" then you can't beat the Legsport muffler plus a resonator in the midpipe:
http://www.ft86club.com/forums/showthread.php?t=83973 Even with headers and a resonator less cat pipe, my legsport muffler is extremely quiet. Reason being it has TWO mufflers in sequence which you can combine with a midpipe resonator for much quietness! |
#13 |
No rice, no life
Drives: 2013 Asphalt FR-S
Why not just stick with the stock headerback? It's relatively quiet and sounds pretty good with an aftermarket header. I don't think you'll notice any significant power difference between stock and an aftermarket 2.75" exhaust anyway.
Plus the stock exhaust is free lol. You can always buy a different one later.
2013 Asphalt Scion FR-S | Jackson Racing Supercharger | KW V3 | Enkei RS05RR 18x9.5
| quiet 3" exhaust | blown | Engine, Exhaust, Transmission | 20 | 05-18-2016 01:10 AM |
| FS: Ptuning 3" Header-back Exhaust System | jprice130 | Engine, Exhaust, Bolt-Ons | 2 | 11-28-2015 02:19 PM |
| FS: Perrin 2.5" Resonated Cat Back Exhaust System | tonystewart | Engine, Exhaust, Bolt-Ons | 2 | 12-27-2013 05:53 AM |
| Full 3" exhaust system Who does it? | Victor Draken | Engine, Exhaust, Transmission | 23 | 11-07-2013 01:09 PM |
| FS: Magnaflow 2.5" Performance Exhaust System (Catback) | Teeeazy | Engine, Exhaust, Bolt-Ons | 1 | 10-09-2013 02:30 PM |
