| Software Tuning Discuss all software tuning topics. |
#29 |
#30 |
#31 |
#32 | |
The only item on the check list I am really worrying about is how to get around the low octane fuel for 1000-2000 miles (perhaps less - I still need to check it). In fact, I have to find out that next. Back to OP, I will run a tank of 87 and log data with OFT. I kinda hope, that measured driving style could limit knocking ... Maybe naive thinking. Andy |
#33 | |
Drives: FT86
I could make up a tune for you will a lot less timing for runnig low octane fuel, but on 87 with a 12.5:1 compression you likely still going to get some knock but with a modded tune it will be less Message me if your interested |
#34 | |
Thx. When I get to the point I am 100% committed, I will reach out to you. |
#35 | |
When I was traveling in Europe, while stationed in the Army, I could buy gas at the EES for $.23 per gallon. On the economy it was selling for $.67 per gallon. I was driving a VW bug. So, I borrowed two 20 liter poly-something containers, that my landlord used in his business to transport dry cleaning fluid. I positioned these containers in the front of my bug, hidden under an Army blanket. That about doubled the range of my car on relatively cheap gasoline, allowing me to make it to another military installation. (please folks, no lectures on how dangerous that was - )So, Andy, where in your head, did you start off from? (London or Cape Town?) humfrz |
#36 | |
Drives: Black Panda BRZ
![]() Seriously, you allude to the lsd being helpful in avoiding getting stuck on this trip. How is that kind of terrain compatible with going easy on the car to try and avoid knock? |
#37 |
Not sure about the point of all the secrecy on the plans. I personally would throw my idea out there since there is bound to be somebody on here that has experience in the regions in question.
At this point it would appear that Alf could not have chosen a poorer vehicle to travel through the unknown even if he had tried to.
#38 |
Drives: car
@alf If by "far off the map" you mean take your car places it shouldn't, I'd advise reconsider or change plans. I've taken my car off into the dirt briefly while visiting the canyons and the wear that I did to all my mounts/shocks/ etc wasn't worth it. Dragged the muffler through a bunch of ruts. It made it, but to what cost to my future driveability and my wallet to have to fix these things?
#39 |
Drives: FR-S Whiteout
If you must.. maybe trim 5* of timing globally by subtracting it from your base ignition timing map and see what happens? you'd be better off with that than running tables set for good fuel.
Intent > Content
cowardice is the mother of cruelty. |
#40 | |
@steve99 offered to build a 87 map for me. I will run tests here at home to see what driving style works and what does not. If there is a certain window of RPM/throttle where it works, I will stick to it. Also, I will carry octane boosters. yes, I must. |
#41 | |
I already went "for off the map" and yes, there is a wear and tear. I actually went on top of High Sierra with 8 inches deep ruts and other really one way no u turn possible bad spots in Cali as well as drove thru calf deep sand roads and my superb skills, maintaining momentum and being calm always saved me. |
#42 | |
I will surely reveal my plans in more detail, once I commit to the trip. This is just an early research. And doing it in 86 is a point here. |
| mixing e85 (109 octane) with e15 (91 octane) | pcguru2000 | Engine, Exhaust, Transmission | 19 | 03-08-2022 10:35 PM |
| 100 Octane? | hellyvin | Northern California | 23 | 07-24-2017 08:01 PM |
| Do you use 93% octane | RichardsFRS | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 62 | 02-08-2016 11:21 PM |
| 100 octane race gas: 91 octane ratio? | GhostofAkina | Scion FR-S / Toyota 86 GT86 General Forum | 15 | 02-08-2013 01:23 AM |
| 93 Octane? | ashtray | BRZ First-Gen (2012+) — General Topics | 175 | 04-04-2012 12:22 PM |
