Old 01-23-2016, 09:36 AM   #1
RichardsFRS
RichardsFRS's Avatar
Drives: 2013 Pearl White 6MT
Do you use 93% octane
What will 93 get me. It's in most stations here
RichardsFRS is offline   Reply With Quote
Old 01-23-2016, 09:38 AM   #2
Cmorris8848
Cmorris8848's Avatar
Drives: CWP 2015 BRZ Stock
Pretty much what the spec sheet says. That's what the car was designed to run.
Cmorris8848 is offline   Reply With Quote
The Following User Says Thank You to Cmorris8848 For This Useful Post:
hmong337 (01-23-2016)
Old 01-23-2016, 12:34 PM   #3
Cole
Not a troll
Cole's Avatar
I don't use 93 simply because availability is hit and miss where I am. 91 is way more available, so I have a 91 tune loaded on my car
Old 01-24-2016, 10:00 PM   #4
Xinshadow
Drives: 2013 Scion FR-S Ultramarine
Insurance on hot days when running hard, maybe a very small power increase, certainly not enough to feel.
I've used nothing but 93 octane since I bought mine 3 years ago, hasn't had any issues being driven very hard in 100F weather. I'd say its worth the few extra cents, especially on track days.
Sent from my LGLS990 using Tapatalk
Current mods: OFT Stage 2 (w/93 oct), OFH, Perrin Resonated catback, DSS Aluminum Driveshaft, Perrin drop-in filter, Avo silicone inlet, Mishimoto catch can, Grimmspeed MCB, Perrin crank pulley, Nameless overpipe/downpipe combo, DBA slotted rotors, Ferrodo brake pads, goodrich SS brake lines, DOT5 synthetic brake fluid.
Xinshadow is offline   Reply With Quote
Old 01-24-2016, 10:21 PM   #5
N1rve
N1rve's Avatar
Drives: 2019 BMW ///M4
Moar Powah!
93 Isn't available where I live.
Also -- I never noticed octane was a percentage.
N1rve
Old 01-24-2016, 10:56 PM   #6
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
Dude seriously? You asked the same question in another post and people answered myself included, the manual calls for it when available, only if it is absolutely not available do you use 91 (bearing of course if you have a 91 tune) also you've been using 87 for quite some time correct? :
The Following 4 Users Say Thank You to FRSBRZGT86FAN For This Useful Post:
PandaSPUR (01-25-2016), soulreapersteve (01-25-2016), swarb (01-25-2016), theadmiral976 (01-24-2016)
Old 01-24-2016, 11:01 PM   #7
theadmiral976
Drives: WRB Subaru BRZ Limited 6MT
93 octane will get you a car that functions as designed from the factory. Running 91 octane on the stock map is not going to hurt anything but most people will notice a power decrease. Running less than 91 octane will greatly increase the chances of your engine experiencing knock. While not immediately fatal to the engine, it will harm it over time.
No offense meant but you've got to pay to play. The FA20 engine is a high compression motor that cannot run on low octane fuel without experiencing predetonation. It's a physical reality.
If you must run 91 octane, remapping your engine using OFT, EcuTek or similar will help compensate for the timing changes made by the stock map to compensate for the 2 octane difference.
At a minimum, please read the owner's manual or at least the sticker on the inside of the fuel door.
theadmiral976 is offline   Reply With Quote
The Following User Says Thank You to theadmiral976 For This Useful Post:
FRSBRZGT86FAN (01-25-2016)
Old 01-25-2016, 01:54 AM   #8
FRSBRZGT86FAN
I totally agree with this as well, the sticker on the gas door is even saying put premium only. However the issue is in some places "premium" means 91 and not 93 however if OP is worried about damage from 91 he should worry not as you said, but what he should worry about is the fact he kept putting 87-89 octane in the car for quite some time. This is straight from the manual:
Old 01-25-2016, 02:05 AM   #9
Lelantas
Lelantas's Avatar
Drives: '15 BRZ ISM
Well, it's not!
Bottom line as other posters have mentioned: read the owner's manual. Use 93 octane if you have it available, us poor Californians without 93 can use 91 without harm to the engine.
Lelantas is offline   Reply With Quote
Old 01-25-2016, 03:30 AM   #10
humfrz
It may be ... down in Georgia .......
(humfrz)
Old 01-25-2016, 06:58 AM   #11
RichardsFRS
First off why do you continue to copy and paste my post FRSBRZ? It's weird and you should certainly have something better to do besides follow my post around.
Secondly Ive not even had the car quiet sometime. I've had it almost two months. I'll just drive the gas out and I'll put high octane in, no big deal
To the others, really if you have nothing of importance to add to my post, please don't reply. As I'm only looking for useful information
And for the ones with useful information Thanks!
Old 01-25-2016, 07:05 AM   #12
Jonathanlim
Drives: 15' Frs
Can you have 93 octane in your tank but on a 91 map?
Jonathanlim is offline   Reply With Quote
Old 01-25-2016, 08:28 AM   #13
PandaSPUR
PandaPandaPandaPandaPanda
PandaSPUR's Avatar
Drives: 2015 BRZ Limited CWP
Yep.
PandaSPUR is offline   Reply With Quote
Old 01-25-2016, 08:51 AM   #14
I tend to just throw in the highest available where ever I happen to be when I need gas. Since I burn through two tanks a weeks the locations can be pretty random and once can be 91 and the next 93 or even 94. Possibly because my ECU never gets a chance to level out on one level of fuel I never notice any difference between one tank and another regardless what level I pump into it. That is the beauty of a ECU that learns since it will adjust to whatever the situation is, give you the best for what you have and reduce the risk of issues.
100 Octane? hellyvin Northern California 23 07-24-2017 08:01 PM
91 vs 94 Octane nocwage Engine, Exhaust, Transmission 27 07-15-2014 12:52 AM
What Octane for the FR-S? 914_WHITE_FRS Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 34 07-13-2013 11:43 PM
100 octane race gas: 91 octane ratio? GhostofAkina Scion FR-S / Toyota 86 GT86 General Forum 15 02-08-2013 01:23 AM
93 Octane? ashtray BRZ First-Gen (2012+) — General Topics 175 04-04-2012 12:22 PM
