Old 07-30-2018, 08:34 PM   #29
Zer0
Drives: 2015 frs
Dry sump
Dry sump arrived
Zer0 is offline   Reply With Quote
The Following 3 Users Say Thank You to Zer0 For This Useful Post:
Code Monkey (07-30-2018), DaSilva3525 (07-30-2018), Thedishdoc (03-08-2019)
Old 07-30-2018, 08:40 PM   #30
DaSilva3525
Drives: 2013 Brz
Originally Posted by Zer0 View Post
Dry sump arrived
Daaaaaaayum
Keep that motivation up, she's turning out to be a beast right off the bat
DaSilva3525 is offline   Reply With Quote
The Following User Says Thank You to DaSilva3525 For This Useful Post:
Zer0 (07-30-2018)
Old 08-01-2018, 01:48 PM   #31
Zer0
Drives: 2015 frs
S.P.E.C super twin clutch assembly
The Following User Says Thank You to Zer0 For This Useful Post:
JeremyR (08-01-2018)
Old 08-03-2018, 04:15 PM   #32
Zer0
Drives: 2015 frs
ATI Super Damper and supercharger pulley.
DustinS (08-03-2018)
Old 08-06-2018, 02:00 PM   #33
Zer0
Drives: 2015 frs
A few more parts arrived
The Following 4 Users Say Thank You to Zer0 For This Useful Post:
Boudin (08-07-2018), DustinS (08-06-2018), R_E_L (08-26-2018), Thedishdoc (03-08-2019)
Old 08-06-2018, 03:05 PM   #34
thosey7
Drives: N/A
Holy smokes, sick build!
thosey7 is offline   Reply With Quote
The Following User Says Thank You to thosey7 For This Useful Post:
Zer0 (08-06-2018)
Old 08-07-2018, 09:41 PM   #35
Boudin
Drives: Soon
Following....
Curious what route you're going with trans and ECU?
Sent from my SM-G965U using Tapatalk
Boudin is offline   Reply With Quote
Old 08-07-2018, 09:56 PM   #36
Zer0
Drives: 2015 frs
Originally Posted by Boudin View Post
Following....
T56 magnum xl close ratio.
Gm ecu total rewire of car to eliminate can bus.
Aim dataloger dash setup
Smartwire power distribution module to simplify things.
Old 08-07-2018, 10:29 PM   #37
DIY
DIY's Avatar
Drives: BRZ, WRX
Nice project, subscribed.
Follow me on Instagram: @brzdiy
My Build Thread
DIY is offline   Reply With Quote
The Following User Says Thank You to DIY For This Useful Post:
Zer0 (08-07-2018)
Old 08-11-2018, 11:24 PM   #38
Zer0
Drives: 2015 frs
The measurements on the engine side of my Vorshlag mounts won't work with a LT4. Not surprised they were designed for a LS swap. I was able to find laser cut motor side mount plates to use to make your own mounts, I also found laser cut tabs. I purchased both, and will use them to make my own engine side mounts that will hopefully work with my lower Crossmember side Vorshlag mounts. If not I will have to make that side as well. We will see how far back, and how much lower I can go with the engine
Old 08-21-2018, 04:36 PM   #39
HawaiianMike
Drives: 2015 Brz Limited
Love the build so far! I don't know why but I never considered moving the heater hoses until this thread.
Will be following very closely as I plan on purchasing a wrecked camaro for its lt1 & Trans.
HawaiianMike is offline   Reply With Quote
The Following User Says Thank You to HawaiianMike For This Useful Post:
Zer0 (08-22-2018)
Old 08-22-2018, 03:47 AM   #40
Zer0
Drives: 2015 frs
Motor prep.
I removed the oil pump, replaced the plastic oil dumbbell with a aluminum machined unit, and swaped out the oil pan
The Following 2 Users Say Thank You to Zer0 For This Useful Post:
Busybee (12-25-2018), DustinS (08-22-2018)
Old 08-22-2018, 03:53 AM   #41
Zer0
Drives: 2015 frs
Going to try to get the bell housing measurements this week, and clock it if necessary. Hopefully I get lucky, and don't need to adjust it's position.
Old 08-25-2018, 10:43 PM   #42
Zer0
Drives: 2015 frs
Found out the timing chain cover, crankshaft snout length , and supercharger front snout is different from dry to wet sump engine. I bought a extra supercharger. I'm going to swap the front of the superchargers, and sell the one I bought setup for the wet sump LT1 motor with the crank pulley, oem shorty header manifolds, and coolant pump. Adapters would be needed to bolt the supercharger on to the LT1 heads, but they are available already.
Andy0323's Back To Basics Build Thread <Long Term Project> andy0323 Member's Car Journals 15 02-02-2018 01:16 AM
long term and short term brichard0625 Engine, Exhaust, Transmission 7 08-26-2013 09:56 AM
Long term Bt216 Scion FR-S / Toyota 86 GT86 General Forum 3 06-07-2013 12:58 AM
Fuel Trims - Long term and short term victorb Engine, Exhaust, Transmission 6 03-27-2013 03:18 PM
Short Term and Long Term Fuel Trims naikaidriver Engine, Exhaust, Transmission 3 03-18-2013 10:55 PM
