| View Poll Results: Do you have chirping (cricket) noise during idle once the car is warmed up? | |||
| Yes (Please only vote after you have 300 miles or more on the odometer) |
3,101 | 85.22% |
| No (Please only vote after you have 300 miles or more on the odometer) |
538 | 14.78% |
| Voters: 3639. You may not vote on this poll | |||
#281 | |
Drives: 2013 SWP Limited BRZ, MT
I have an appointmt with the dealer to address many issues, lets hope the crickets come out tomorrow morning. I'll let you know what they say. |
#282 | |
Spaceman
Drives: 2013 Firestorm Scion FR-S
So I filled up this morning from the gas light having come on. That diluted the oil enough that by the time I got home the chirping was back. It was quieter than before buck quickly getting louder.
#283 |
Drives: ZN6 / GDB-G
2 stroke oil in gas tank !?
someone should forward this thread to Subaru/Scion of North America |
#284 |
Drives: Whiteout / MT FR-S
#285 | ||
Spaceman
| The Following 8 Users Say Thank You to Chewie4299 For This Useful Post: | adprokid (07-13-2012), Bonburner (07-12-2012), cobrabyte (07-12-2012), excited86 (07-12-2012), Re~Mix (07-12-2012), Sigh-on-Rice (07-12-2012), ToxicSneakers (07-13-2012), YukiHachiRoku (07-13-2012) |
#286 |
Drives: Civic Si coupe
Does that whole problem do damage to the engine? I just hope not
#287 |
Noticed really loud consistent chirping around 1000km mark. Had been filling up at petrocan94. Filled up at Shell today after gas light came on, and all chirping gone. Hopefully it stays this way..
#288 | |
It seems Shell gas has been helping the chirping. Two members aren't getting the sound once they use that brand. I'm going to try it at my next fill up.
| The Following User Says Thank You to Jayde For This Useful Post: | Lowellrenzo (07-16-2012) |
#289 |
Drives: none
#290 | |
Spaceman
Others are having luck after buying certain brands. I think what they are actually getting is ethanol free gas.
#291 |
I've used Sunoco and Mobil here, both giving me chirping.
#292 | |
Drives: Skoda Yeti DSG diesel 4x4
I carry a 1L bottle in the car, with graduations so that you see how much you are adding. I also set the trip each time I fill up so that I know how much to add. It doesn't need to be exact. As I mentioned for my diesel I use 200:1 but suggested that 500:1 should be enough to lubricate the high pressure fuel pump. That is the same reason I use it and my common rail diesel also runs a cat. Once again, Valvoline 2 stroke RACING oil, is very high spec and the only one I use. 30mpg will give about 400miles to a tank. If you increase a bit to 4oz per tank that gives a simple 1oz per 100miles on the trip when you fill up so you chuck it in first for 420:1 I would also be concerned for the rest of the HP fuel system that has been designed to use fuel carrying a lubricant as they have in Japan. The better MPG is a fact and noticeable using it at 200:1 As is smoother and quieter. |
#293 | |
Drives: none
#294 |
Drives: 2008 STi
Something came to mind when ethanol popped up and maybe the HPFP is causing the ethanol to draw in moisture in to the HPFP as it compresses the fuel and washing the lubrication from the fueling system. It may mean the use of a fuel stabilizer to keep the moister down and all parts well lubricated. It will only get worse when they up the ethanol to 15%.
| Is this idle noise normal? | robo_robb | Engine, Exhaust, Transmission | 288 | 01-25-2022 09:40 AM |
| Squeak noise from engine. | Fish | Scion FR-S / Toyota 86 GT86 General Forum | 52 | 05-08-2014 01:06 PM |
| Video of chirping at idle | Julio86 | Engine, Exhaust, Transmission | 15 | 02-01-2013 10:37 AM |
| Starting to get worried - Engine noise | Laika | BRZ First-Gen (2012+) — General Topics | 49 | 07-02-2012 03:45 PM |
| Idle issue poll/role call | Hawaiian | Scion FR-S / Toyota 86 GT86 General Forum | 8 | 06-13-2012 12:00 PM |
