Old 08-06-2018, 12:35 PM   #15
TeamJacobs111711
Drives: 2015 Subaru BRZ
Originally Posted by atomicalex View Post
You've confirmed that you are not getting power to some of the fuses necessary. Have you traced that power back to the source? If it ends in a relay and the relay is functioning, then the signal to trigger the relay is likely not there.
So how do I solve the issue when the signal to trigger the relay is no there? I have also switched out the 80a fuse which most or all of the fuses that are not getting power link to and still nothing. What else can I check?
TeamJacobs111711 is offline   Reply With Quote
Old 08-06-2018, 02:41 PM   #16
atomicalex
Drives: 2018 BRZ Limited Perf Pack
You have to track that back to its original source. Then sort out why that is not giving up 12V.
Let's pick one element that is not working. Something that is limited in the controls. You said the window buttons don't work, correct? Where does power appear/disappear in the chain from the battery? IE - battery --> 80A --> 30A --> ECU-B/Dome light --> G/R wire --> Main Body CU --> Window Regulator master <--> Window switch --> window motor.
Did you blow up your body CU?
www.atomicalex.com
2018 BRZ Limited Perf Pack 6MT, a couple of motorcycles, and a stick shift station wagon
atomicalex is offline   Reply With Quote
Weird Electrical Issue Relogical Issues | Warranty | Recalls / TSB 0 04-19-2018 03:09 PM
Wierd Electrical issue - no windows + no trunk after battery replacement Takumi788 Issues | Warranty | Recalls / TSB 7 11-11-2016 11:15 AM
Electrical Issues fuzzybat23 Issues | Warranty | Recalls / TSB 10 12-13-2014 06:51 PM
electrical issue? unichip and left led fog light not playing nice tracerit Software Tuning 2 10-07-2013 10:09 AM
Electrical system EDCOVEY Issues | Warranty | Recalls / TSB 0 11-27-2012 12:45 AM
