#113 |
Drives: Toyota 86
#114 | |
Drives: ‘16 4Runner, ‘19 Corolla HB
2019 Toyota 86 TRD Edition
The tire is 3/4" taller. That means that the vehicle itself rides 3/8" higher (the upper half of the tire doesn't add to the ride height). Last edited by Quentin; 08-03-2018 at 11:12 PM. |
| The Following User Says Thank You to Quentin For This Useful Post: | BellaItalia (08-05-2018) |
#115 | |
Drives: TBA
Note that my ¾" taller estimate includes half the 18" wheel diameter plus half the tire diameter compared to stock 17". |
#116 |
Drives: C5, GT-86, '24 Colorado TrailBoss
if true would make the car feel slower with worse gearing
#117 |
Drives: '15 BRZ RA
A 3/4" difference is too much. Tire size calculator gives a 1/2" diameter difference:
https://tiresize.com/calculator/ New cars have a 4.3 fd, so a bit longer gearing cause of the bigger wheel should not be an issue. In fact, what you lose in acceleration per gear you gain in top speed per gear. You lose something and you gain something else. |
#118 | |
![]() I think I was using 225/40-18 for my calcs last night. Looks like the overall diameter of the tire is only 5mm bigger which is 2.5mm ride height difference. Sent from my iPhone using Tapatalk |
#119 | |
Putting a wheel inside a tire doesn’t change the tire’s diameter. You only need to look at the outer diameter which is the tire. It’s not entirely accurate to go off the tire diameter though because the diameter is measured in an unloaded state. You would really have to measure the actual car to get an accurate number. Last edited by ermax; 08-04-2018 at 10:23 AM. |
#120 | |
I just checked that too not sure where ATMO is getting his #'s its only .2" difference. Effectively only changes the Current 4.3 gear ratio to act like a 4.27 not a huge difference. The weight of the setup could be a difference but we need #'s first to determine how much.
#121 |
Drives: 2018 Subaru WRX
Can anyone who has Raven/Crystal Black confirm if their paint is metallic? I'm looking at picturesfrom the recent first driven reviews and the paint seems to have that metallic sheen.
Thanks! |
#122 |
Drives: 2017 Toyota 86 860 Special Edition
I have a 860SE, so my wing tips and mirrors are Raven and yes, they have metal flake.
#123 |
#124 |
pessimistic skeptic
Ugliest body kit I have ever seen on a twin, especially the rear bumper.
| The Following User Says Thank You to mrg666 For This Useful Post: | TachyonBomb (08-05-2018) |
#125 | |
ft86club resident b-boy
Drives: Yamaha R3, moonslate 2018 GT Black
#126 | |
Drives: TBA
https://www.tirerack.com/tires/tires...omCompare1=yes https://www.tirerack.com/tires/tires...omCompare1=yes |
| Johl's Toyota 86 Blackline Edition | johl | Member's Car Journals | 88 | 07-09-2019 02:07 PM |
| 2019 Toyota 86 TRD Edition | interna | CANADA | 8 | 07-08-2018 10:02 PM |
| 2017 Toyota 86, 860 Edition Under 1K miles | thatweirddude25 | Cars for Sale/Trade | 0 | 05-08-2018 03:43 PM |
| Toyota 86 GTS MY15 Edition | M4V3R1CK | Scion FR-S / Toyota 86 GT86 General Forum | 2 | 07-15-2014 11:39 PM |
