Old 07-29-2016, 05:47 PM   #71
DustinS
DustinS's Avatar
Drives: 2013 Ultramarine FR-S
Originally Posted by KoolBRZ View Post
Will this work with the OpenFlash Tablet without disabling emissions controls.
Shiv Based his kit off of this. So I assume he is using the same pin, which may not pass emissions.
Old 07-29-2016, 08:46 PM   #72
steve99
Drives: FT86
Im pretty sure the openflash guys are just using ztans flex rom coded A01G rom and flashing that directly into USA 700C to B01C ecus. The ECU hardware is likely same and the A01G roms dont have evap code enabled as we dont have evap system here . So unlikly you will pass emissions in some states depending on tests done as evap will show failed.
I think any auto guy will be out of luck at present as their is no auto flex coded roms although wayno is close on that, but again it will be A01I rom, and its a crap load of work to port code to other roms and test.
Old 07-29-2016, 10:07 PM   #73
Wayno
Wayno's Avatar
Drives: Toyota 86 GTS
Originally Posted by ztan View Post
Having seen the E85 at the station yesterday, I went back home and pored over the wiring diagrams and the car.
The two commonly used sensor inputs are the rear oxygen sensor (O2S2) and the Evap pressure sensor. ECU pins as per diagram below (the wiring manual has the connectors as if you were looking end on at the harness plug - they are mirror-imaged when you look at them plugged in to the ECU.
I had a look at the connector AD2 (which is more accessible than the ECU) which joins the ECU to the fuel pump and Evap cannister harness: the wires were not there for the Evap cannister (A01G ROM). It turns out that I am in luck and the ECU does not interrogate Evap Pressure in my A01G car, so I don't need to compensate for losing the signal.
Moving on to connector A35 on the ECU, pin 20 was empty and I decided to hook a wire up to it. Pulled the connector out - it turns out that I could use the Molex pin from a scrap IDE type ribbon cable on this. To do this, lift the retainer on the IDE plug with a pick and pull the connector out. The A35 connector has a horizontal locking tab in the middle - that needs to be pulled out about 2mm, then the IDE Molex pin slides all the way down the barrel and does not come out when the locking tab is replaced. See last picture for new wire placement.
Lol, i haven't owned any ide cables for years. It looks like a usb or firewire plug though.
Old 07-29-2016, 10:38 PM   #74
KoolBRZ
KoolBRZ's Avatar
Drives: Silver 2013 BRZ Ltd Auto 45,000 mi
I'd be willing to try, but I'd still have to do a lot of hand coding. I'd need to know the right memory addresses, and which code to put where. I'd also have to use the e-brake safety code, since I don't have a clutch, and I want to make sure I could disconnect the code without bricking my ECU.
I'm going to fill with E85 for the first time tomorrow using the OFT ESC E85 tune. Let me know if you want to help me port this to a US A/T rom.
Edit; I'm NOT going to switch to E85 yet. All my local stations closed. I'm not driving 30 miles round trip just to fill up, then constantly worry whether or not I have enough fuel to get back to the station again. Plus, it's in Oregon where I can't pump my own gas.
If I say yes, will that make you think I understand?
KoolBRZ is offline   Reply With Quote
Old 07-29-2016, 10:46 PM   #75
steve99
Drives: FT86
if they are no good let me know i think we have some old ide stuff somewhere.
Old 08-21-2017, 03:13 AM   #76
Wayno
Wayno's Avatar
Anyone who wants a flex tune for any AU/EU/US MY12-MY16 can message me.
Not for free. And do not message me for MY17.
Calibrations:
A01G
A01G as 700G
A01G as A00G
A01G as A02G
A01G as D00G
A01G as F10G
A01G as F20P
A01I
A01I as 700I
A01I as A00I
A01I as A02I
A01I as E00I
A01I as F20Q
A01G as 500C
A01G as 700C
A01G as 900C
A01G as A00C
A01G as A01C
A01G as B00C
A01G as B01C
A01G as D00C
A01G as F00C
A01G as F40C
A01I as 500D
A01I as 700D
A01I as 900D
A01I as A00D
A01I as A01D
A01I as B00D
A01I as B01D
A01I as D00D
A01I as F00D
A01I as F40D
The Following 2 Users Say Thank You to Wayno For This Useful Post:
Chimera (08-21-2017), Vin (08-21-2017)
Old 07-30-2018, 01:01 PM   #77
mato2sk
Drives: Toyota GT86
I want to share with you about the adaptation of Ztan flex fuel analyzer.
I designed the PCB, and instead of the PLX display, used the small OLED SSD1306, because it is cheaper.
I also added fuel temperature and sensor frequency measurement.
Is not yet connected to Evap pin A35-20, because I have a not modified ROM (01G), as instructed by Ztan.
The voltage at the output is the same as for Ztan.
You can also use Arduino Nano or Uno, and use Ztan wiring diagram, but instead of the PLX display, plug in the A4 and A5 OLED SSD1306.
Wiring Diagram with Eagle software.
https://drive.google.com/file/d/1KJb...ew?usp=sharing
List of parts
C1, C2, C4 = 100nF
C6, C7 = 22pF
C5 = crystal 16mhz
C8, C9 = 330nF
C3 = 10uF
C10 = 100uF
R2, R5 = 3k3
R4, R6, R7 = 1k8
R1 = 10k
R3 = 6k8
T1 = BC547
E_SENSOR = 13577429 flexfuel sensor
Code:
#include <Arduino.h>
#include <Wire.h>
#include <EEPROM.h>
#include <U8glib.h>
U8GLIB_SSD1306_128X64 mujOled(U8G_I2C_OPT_NONE);
uint16_t pwm_output  = 0;      //integer for storing PWM value (0-255 value)
int HZ = 0;                  //unsigned 16bit integer for st
int inpPin = 8;
int V_out_int;
float V_out, V_out_avg, E_scalar;
//Define global variables
volatile uint16_t revTick;    //Ticks per revolutionoring HZ input
int ethanol = 0;              //Store ethanol percentage here
float expectedv;              //store expected voltage here - range for typical GM sensors is usually 0.5-4.5v
uint16_t voltage = 0;              //store display millivoltage here (0-5000)
//temperature variables
int duty;                     //Duty cycle (0.0-100.0)
float period;                 //Store period time here (eg.0.0025 s)
float temperature = 0;        //Store fuel temperature here
int fahr = 0;
int cels = 0;
int celstemp = 0;
float fahrtemp = 0;
static long highTime = 0;
static long lowTime = 0;
static long tempPulse;
//EEPROM store
int EE_V_addr = 0;
float V_out_default = 147;
long Elast, Enow, Edelta;
//TRAC switch double click
bool TRAC_buttonMonitor = HIGH;
int debounce = 20;
int doubleClick = 200;
int longClick = 3000;
int TRAC_initializeDelay = 5000;
int TRAC_buttonState = 4; //initialize to 0 for normal operation, 4 for on by default after delay
long TRAC_buttonCounter = 0;
void setupTimer()   // setup timer1
  TCCR1A = 0;      // normal mode
  TCCR1B = 132;    // (10000100) Falling edge trigger, Timer = CPU Clock/256, noise cancellation on
  TCCR1C = 0;      // normal mode
  TIMSK1 = 33;     // (00100001) Input capture and overflow interupts enabled
  TCNT1 = 0;       // start from 0
ISR(TIMER1_CAPT_vect)    // PULSE DETECTED!  (interrupt automatically triggered, not called by main program)
  revTick = ICR1;      // save duration of last revolution
  TCNT1 = 0;       // restart timer for next revolution
ISR(TIMER1_OVF_vect)    // counter overflow/timeout
{ revTick = 0; }        // Ticks per second = 0
void setup() {
  pinMode (3, OUTPUT);
  pinMode (10, OUTPUT);
  digitalWrite (10, LOW);
  pinMode (6, INPUT);
  EEPROM.get(EE_V_addr, V_out_avg); //load last V_out_avg
  if (isnan(V_out_avg))
    V_out_avg = V_out_default;
  V_out_int = (int)V_out_avg; //convert to integer for analogWrite
  analogWrite(3, V_out_int); //output V_out as PWM voltage on pin 3
  setupTimer();
  Serial.begin(9600);
void loop() {
   getfueltemp(inpPin); //read fuel temp from input duty cycle
  if (revTick > 0) // Avoid dividing by zero, sample in the HZ
     {HZ = 62700 / revTick;}     // (62200)  3456000ticks per minute, 57600 per second
      else                        // 62200 calibrated for more accuracy
      {HZ = 0;}
    //calculate ethanol percentage
      if (HZ > 50) // Avoid dividing by zero
      {ethanol = HZ-50;}
      else
      {ethanol = 0;}
  if (ethanol > 99) // Avoid overflow in PWM
  {ethanol = 99;}
    V_out = 255 - (2.73 * ethanol);
      V_out_avg = V_out_avg + (0.1 * (V_out - V_out_avg)); //V_out_avg as moving average
  //Store EEPROM data every 5 minutes
  Enow = millis();
  Edelta = Enow - Elast;
  if (Edelta >= 300000)
    Elast = Enow;
    EEPROM.put(EE_V_addr,  V_out_avg ); //store V_out_avg to EEPROM
    mujOled.firstPage();
  do {
    mujOled.setFont(u8g_font_helvB08);
    //Printing the data on the OLED
mujOled.drawStr(0, 15, "Eth: ");
mujOled.drawStr(0, 30, "Temp: ");
mujOled.drawStr(0, 45, "Freq: ");
mujOled.setPrintPos(72, 15);         //setting the dimensions to print the ethanol
mujOled.print(ethanol, 10);
mujOled.println("%");
mujOled.setPrintPos(72, 30);   //setting the dimensions to print the temperature fuel
mujOled.print(cels, 10);
mujOled.println("C");
mujOled.setPrintPos(72, 45);   //setting the dimensions to print the frequency
mujOled.print(HZ, 10);
mujOled.println("Hz");
    while( mujOled.nextPage() );
    delay(250);
void getfueltemp(int inpPin){ //read fuel temp from input duty cycle
  highTime = 0;
  lowTime = 0;
  tempPulse = pulseIn(inpPin,HIGH);
    if(tempPulse>highTime){
    highTime = tempPulse;
  tempPulse = pulseIn(inpPin,LOW);
    if(tempPulse>lowTime){
    lowTime = tempPulse;
  duty = ((100*(highTime/(double (lowTime+highTime))))); //Calculate duty cycle (integer extra decimal)
  float T = (float(1.0/float(HZ)));             //Calculate total period time
  float period = float(100-duty)*T;             //Calculate the active period time (100-duty)*T
  float temp2 = float(10) * float(period);      //Convert ms to whole number
  temperature = ((40.25 * temp2)-81.25);        //Calculate temperature for display (1ms = -40, 5ms = 80)
  celstemp = int(temperature);
  cels = celstemp;
  fahrtemp = ((temperature*1.8)+32);
  fahr = fahrtemp;
//TRAC switch doubleclick
  TRAC_buttonMonitor = digitalRead(6);
  switch (TRAC_buttonState)
    case 0: //inactive
      if (TRAC_buttonMonitor == LOW)  // button pressed
        digitalWrite (10, HIGH); //Transistor on
        TRAC_buttonState = 1; //increment state
      break;
    case 1: //check for release
      if (TRAC_buttonMonitor == HIGH) //if button released
        TRAC_buttonCounter = millis(); //start counter
        TRAC_buttonState = 2; //increment state
      break;
    case 2: //wait for doubleClick
      if (TRAC_buttonMonitor == LOW && (millis() - TRAC_buttonCounter) > debounce && (millis() - TRAC_buttonCounter) < doubleClick) //second click registered
        TRAC_buttonState = 3; //increment state
      else if ((millis() - TRAC_buttonCounter) > doubleClick)
        digitalWrite (10, LOW); //Transistor off
        TRAC_buttonState = 0; //reset state
      break;
    case 3: //doubleClick made
      if ((millis() - TRAC_buttonCounter) > longClick)
      break;
    case 4: //initialize after delay by default
      if (millis() > TRAC_initializeDelay)
        TRAC_buttonState = 3; //set state to doubleClick
      break;
mato2sk is offline   Reply With Quote
The Following User Says Thank You to mato2sk For This Useful Post:
steve99 (07-30-2018)
Old 07-30-2018, 09:31 PM   #78
steve99
Drives: FT86
List of parts
C1, C2, C4 = 100nF
C6, C7 = 22pF
C5 = crystal 16mhz
C8, C9 = 330nF
C3 = 10uF
C10 = 100uF
R2, R5 = 3k3
R4, R6, R7 = 1k8
R1 = 10k
R3 = 6k8
T1 = BC547
Message me if you need modified rom
Nice work :-)
Old 07-30-2018, 11:17 PM   #79
ZZT86
ZZT86's Avatar
Drives: BR86
Great stuff although I would rather a bigger display = easier to read.
ZZT86 is offline   Reply With Quote
Old 07-31-2018, 12:50 PM   #80
mato2sk
Drives: Toyota GT86
It is also possible to use LCD 20x2, or larger Oled 1.5 ".
I can also change the font size.
Old 08-01-2018, 07:00 AM   #81
mato2sk
Drives: Toyota GT86
I changed the font size, and the individual data is rotated every 5 seconds on the OLED display.
Recovery time can be changed
delay(3000); // recovery time Oled
Code:
#include <Wire.h>
#include <EEPROM.h>
#include <U8glib.h>
int p;
void pageEthanol();     // Page-1
void pageTemp(); // Page-2
void pageFreq();    // Page-3
void (*pages[])() = { pageEthanol, pageTemp, pageFreq } ;
int inpPin = 8;
int V_out_int;
long int prepis = 0;
//float expectedv;              //store expected voltage here - range for typical GM sensors is usually 0.5-4.5v
//uint16_t voltage = 0;              //store display millivoltage here (0-5000)
int fahr = 0;
int cels = 0;
int celstemp = 0;
float fahrtemp = 0;
//EEPROM store
int EE_V_addr = 0;
int debounce = 20;
void setup() {
  pinMode (6, INPUT);
  mujOled.setFont(u8g_font_fub25);
  mujOled.setColorIndex(1);
  p = 0;
  setupTimer();
  Serial.begin(9600);
void loop() {
      {HZ = 0;}
      {ethanol = HZ-50;}
      else
      {ethanol = 0;}
  {ethanol = 99;}
    V_out = 255 - (2.65 * ethanol);
  Enow = millis();
    Elast = Enow;
  do {
    (*pages[p])();
  } while( mujOled.nextPage() );
  p = p+1;
  if (p == 3)
    p=0;
  highTime = 0;
  lowTime = 0;
  cels = celstemp;
  fahr = fahrtemp;
    case 0: //inactive
      break;
      break;
      break;
      break;
      break;
void pageEthanol() {
    mujOled.drawStr(0, 28, "Ethanol ");
    mujOled.setPrintPos(32, 64);         //setting the dimensions to print the ethanol
void pageTemp(){
     mujOled.drawStr(10, 28, "Temp: ");
     mujOled.setPrintPos(33, 64);   //setting the dimensions to print the temperature fuel
void pageFreq() {
 mujOled.drawStr(20, 28, "Freq: ");
mujOled.setPrintPos(12, 64);   //setting the dimensions to print the frequency
Old 08-01-2018, 02:54 PM   #82
T0rt0r0
Drives: European gt86
Code:
#include <Wire.h>
#include <EEPROM.h>
#include <U8glib.h>
int inpPin = 8;
int V_out_int;
int fahr = 0;
int cels = 0;
int celstemp = 0;
float fahrtemp = 0;
//EEPROM store
int EE_V_addr = 0;
int debounce = 20;
void setup() {
  pinMode (6, INPUT);
  setupTimer();
  Serial.begin(9600);
void loop() {
      {HZ = 0;}
      {ethanol = HZ-50;}
      else
      {ethanol = 0;}
  {ethanol = 99;}
  Enow = millis();
    Elast = Enow;
  do {
    mujOled.setPrintPos(40, 64);         //setting the dimensions to print the ethanol
  delay(5000); //Data ethanol Recovery Time
  do {
     mujOled.setPrintPos(40, 64);   //setting the dimensions to print the temperature fuel
 delay(5000); //Data temperature Recovery Time
  do {
mujOled.setPrintPos(30, 64);   //setting the dimensions to print the frequency
    delay(5000);  // Data freq Recovery Time
  highTime = 0;
  lowTime = 0;
  cels = celstemp;
  fahr = fahrtemp;
    case 0: //inactive
      break;
      break;
      break;
      break;
      break;
Nice !
You may want to look at this if you wanna plug it to the obd: http://www.ft86club.com/forums/showthread.php?t=123339
(So you can show oil temp, intake temp, etc.)
If you make a plugin using this project I'll be glad to add it to the git hub sources
T0rt0r0 is offline   Reply With Quote
Old 08-03-2018, 02:37 PM   #83
mato2sk
Drives: Toyota GT86
In winter I want to upgrade to a turbo.
I want to integrate other functions in this device (temperature and pressure oil, turbo pressure, etc.)
Or I will build a separate device on the arduino platform.
When I have this device built, I like to share it.
Old 08-03-2018, 03:08 PM   #84
Aussie
Drives: 2013 Scion FR-S 6MT
This is what I did when I went turbo.
http://www.ft86club.com/forums/showt...ht=instruments
Aussie is offline   Reply With Quote
Open source Over Boost Fuel Cut ztan Software Tuning 19 02-15-2026 02:32 AM
Open Source Electric Supercharger neutron256 Forced Induction 913 08-22-2021 06:16 PM
open source software question GeeTee86 AFRICA 15 02-15-2015 07:52 PM
The Retrofit Source summer open house! soundman98 Southeast 0 06-23-2014 09:41 PM
ECUtek Flex Fuel REVOLUTION: World's First Flex Fuel Factory ECU GTR - BRZ soon! Visconti Engine, Exhaust, Transmission 356 05-20-2013 10:36 AM
