Old 08-02-2018, 01:13 PM   #43
NARFALICIOUS
NARFALICIOUS's Avatar
Drives: 88 Supra 1JZ, 16 FRS, 25 GR Corolla
Originally Posted by Trueweltall View Post
Where are you getting them that cheap? I paid $44 for the newer TOB.
Must be a Subaru pricing thing. The Toyota one is $21
https://parts.toyota.com/p/Toyota__/...U00307349.html
NARFALICIOUS
Noob Poster
1988 | 2016
NARFALICIOUS is offline   Reply With Quote
The Following User Says Thank You to NARFALICIOUS For This Useful Post:
Trueweltall (08-02-2018)
Old 08-02-2018, 01:33 PM   #44
It pays to shop both suppliers for parts. Sometimes one or the other can be much cheaper. Doesn't seem to be a pattern though.
Old 08-02-2018, 01:46 PM   #45
celek
Resident Gear Head
celek's Avatar
All in who's label is on the parts Subaru makes most of the parts, but Toyota makes the driveline. Although strange Subaru has been using the same TOB part number since 1990 in 476 different models
celek is offline   Reply With Quote
The Following User Says Thank You to celek For This Useful Post:
Tcoat (08-02-2018)
Old 08-02-2018, 01:55 PM   #46
Subaru doesn't make any of the parts. Their suppliers do.
Old 08-02-2018, 01:58 PM   #47
NARFALICIOUS
Originally Posted by VerusEric View Post
I believe Toyobaru honestly found the issue to be caused by grease degradation at this point. They issued a TSB for it, they updated the bearing for all 2017+ units, and the greases physically look and act differently.
Thanks for all the research. Real interesting.
Not all 2017s have the updated parts, it was switched mid-year. see T-SB-0219-17
NARFALICIOUS
Noob Poster
1988 | 2016
Tcoat (08-02-2018)
Old 08-02-2018, 02:25 PM   #48
MrDinkleman
Drives: 2016 Oceanic, "base" model
I drove about 5,000 miles after mine started making the noise. It still quieted down when it warmed up right up to the minute it blew and took out everything. If I had changed it early like you did all would have been fine.
The sooner it is changed the less likely you are to have catastrophic failure like I did.
Sigh... This is just another issue that makes me wish Toyota had stuck their driveline (an upgraded 3SGE- 4SGE?) in the Scion versions. Hell, I'd even be happy with a W58 transmission (old, old, old 5-speed used in the 80s for those of you not familiar with old, old, old Toyota technology).
MrDinkleman is offline   Reply With Quote
The Following User Says Thank You to MrDinkleman For This Useful Post:
Tcoat (08-02-2018)
Old 08-02-2018, 02:32 PM   #49
Well that would seem nice on the surface but they were not without issues and the bullet proof memories are more nostalgia than fact. The old tech would still be old and not live up to it's rep way back when.
Old 08-02-2018, 09:38 PM   #50
VerusEric
VerusEric's Avatar
Drives: BRZ, STI, GT350R, Supra, 987.2
Originally Posted by Spec C Wannabe View Post
How old is the specimen? Could it be that the sample of used TOB you got is so old that the grease property has already deteriorated?
I mean 2013-2016 TOB unused VS 2017+ TOB unused should be a more comparable match.
The unit I cut apart was out of my car, the shop car, with ~13k miles on it. The BRZ is a 2014.
VerusEric is offline   Reply With Quote
The Following User Says Thank You to VerusEric For This Useful Post:
Spec C Wannabe (08-05-2018)
Old 08-03-2018, 09:36 PM   #51
MrDinkleman
Oh, I dunno if I agree that "bulletproof memories are more nostalgia than fact".
It is a fact of engineering that anything and everything that can be made faster, lighter, cheaper will be until you go a little too far making it faster/cheaper/lighter. Then you start over. Every engineering student has watched the video of the Tacoma Narrows bridge.
The TOB assemblies in my older Toyotas never gave me problems. My 1988 truck went 175k miles before the clutch was replaced due to a leaking main seal contaminating the clutch surface. There are no tabs on the bearing. It's just a big fat thrust bearing pressed on to a big fat, cast (forged?) bearing carrier that slides up and down a lightly greased steel tube pressed into the front transmission bearing seal. I've no doubt that someone looked at that and thought, "we can make that assembly faster, cheaper, lighter..." but in the process they also thought, "we'll call it a wear item and give it an expected life of 36 months or 36k miles, whichever occurs first."
Same goes for the VVTi and DI systems. My 2011 Yaris had the VVTi and DI. It never had the death rattle (see my thread, 0W-30 oil, in the mechanical maintenance section) nor the crickets in the 140k miles I drove that car until it was totalled in a rear-ender...
So, I agree with you that resurrecting old tech is a non-starter. But not because it would "not live up to its rep" but because it would increase the cost of the car to a point not many people would buy one.
Old 08-05-2018, 10:26 PM   #52
Token11b
My TOB finally went out around 65k miles. Decided to change the clutch too. The clutch doesn’t look bad but man the TOB nuked itself and destroyed one of the clips. I’ll get some pics tomorrow.
2013 Scion FRS Firestorm- Current mods: Gruppe-S UEL Headers w/overpipe, Perrin intake tube w/drop in filter Perrin 3" catback, OFT stage 2 turn
Token11b is offline   Reply With Quote
Old 08-08-2018, 02:57 PM   #53
Stang70Fastback
A.K.A. Starlord
Stang70Fastback's Avatar
Drives: 2015 Series.Blue
So I had my bearing replaced at juuussstt under 36,000 miles due to this premature "failure" issue. Unfortunately they replaced it with the same old part number, as this was done just before the TSB was issued. I'm now at 62,000 miles. What are the odds I can talk my way into having it replaced again? Probably slim...
Check out my blog, read all about my BRZ adventures, and oogle my sweet cell-phone photos!
You can also find me on Instagram, and on Facebook.
Stang70Fastback is offline   Reply With Quote
Old 02-16-2020, 01:22 PM   #54
B-R-Z
I love peanut butter
B-R-Z's Avatar
Drives: 2013 SWP BRZ Limited
Here's a link to a thread I started on this topic. I recently purchased the Exedy OEM replacement FJK1005 kit which appears to come with the revised part. I'm not sure if all of their stock has been revised yet or not so it's worth checking and then buying the part from Toyota/Subaru if you did not get the revision in your kit.
http://www.ft86club.com/forums/showthread.php?t=138893
B-R-Z is offline   Reply With Quote
Old 02-16-2020, 01:22 PM   #55
B-R-Z
B-R-Z's Avatar
Edit: Disregard, the bad TOB and revised appear to both have shared the same type of housings so without seeing the white dot on one of the tabs, there's no way to know if it's truly the revised version.
Old 07-30-2021, 12:29 PM   #56
RebornS14
RebornS14's Avatar
Drives: S14K
correct. NTN is the manufacturer/supplier for the release bearing.
https://bcabearings.com/catalog/sear...26model%3D9563
RebornS14 is offline   Reply With Quote
Throw out bearing Hyp Northern California 26 03-13-2017 11:42 PM
Post If You Have Had Your Throw-Out Bearing Go Bad! Bushhy Issues | Warranty | Recalls / TSB 8 10-24-2016 05:34 PM
Throw-out bearing mhigham Issues | Warranty | Recalls / TSB 71 08-18-2016 10:21 AM
Noisy throw out bearing jp_r6 Issues | Warranty | Recalls / TSB 23 08-18-2016 04:45 AM
throw out bearing clips... Shit Luck Engine, Exhaust, Transmission 0 04-12-2014 06:34 PM
