Old 07-29-2018, 09:40 PM   #1
86fun
Drives: 2013 FRS
Shop recommendations in SF Bay area to do a swap?
I think I'm ready to put in a 2J, but I'm going to pass on doing it myself this time. Is there anyone good in the Bay Area? Pure Auto is on the other side of the country, but LA is a possibility too... I don't want any rookies on this one, need some good suggestions!
86fun is offline   Reply With Quote
Old 07-30-2018, 12:49 PM   #2
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
If you are buying a Pure Auto swap kit then maybe they would do a discount if you shipped your car to them and paid for them to do the swap too. The cost might be worth shipping it, especially if you are already dropping that much coin. I can understand if you wanted someone local in case something needs a revision or fixing, but shipping the car could still prove to be the best idea.
I don’t know anyone local. Neil at The Racers Line might be able to do the swap or at minimum know someone. I’m sure if Neil had the Pure Automotive swap kit that he could do the swap.
Are you looking for someone to do the install and you will source all the parts or do you need someone who will source the motor, tranny, etc?
Old 07-30-2018, 04:02 PM   #3
86fun
Drives: 2013 FRS
Ideally one place to do everything seems best. Maybe I need to break it up in to parts... one place for motor acquisition and build, another for fitment and fab work, and another for final assembly/install, and then a tuner?
Above all I really would like pros with the 2J build as I want the motor build and configuration to be solid. Who is best in the Bay Area with 2J's?
Old 07-30-2018, 04:45 PM   #4
ILLSMOQ
Drives: 2017 WR BLUE BRZ
If you’re going motec, regardless of the motor, with the amount of tuning required after the swap is completed, shipping your car to Pure to have them do everything will save you lots money in the long run....plus, since they have been running through so many swaps lately, your chances of getting a reliable car back should be higher I would think.
ILLSMOQ is offline   Reply With Quote
The Following User Says Thank You to ILLSMOQ For This Useful Post:
Pure Automotive (02-08-2019)
Old 07-30-2018, 05:11 PM   #5
86fun
Drives: 2013 FRS
You guys are probably right, shipping off would be best. I was really hoping to keep it local mostly for the support, as I can imagine a lot could and probably would go wrong with a swap like this until you sort out all the weak links in the drivetrain and install bugs. If we had a good shop in the area that would definitely push me to going for it, I will have to think about it more now.
Old 07-30-2018, 06:06 PM   #6
Irace86.2.0
If you wanted to do some budget route for a dedicated track car then perhaps there would be money to be saved by doing as much of the work you could like securing a motor, pulling the bumper, motor and tranny, and delivering a chassis, 2jz, etc to the shop, but if you were going to have this as a street car or daily, and wanted it to feel like stock then Pure Motive has the kit, can get the parts, can do the install and it will feel like the car came with a 2jz. You may actually save money that way too than trying to do it all with multiple shops or with one off components.
Old 07-30-2018, 11:46 PM   #7
86fun
Drives: 2013 FRS
This is going to be a street car. I was definitely thinking the Pure kit because of that, I want everything to work in the dash/console. What I'm not so sure about is the rest of the drivetrain, diff, axles, and maybe rear knuckle/hubs. Seems like that is a bit of an unknown for doing the swap and probably needs some fab work. Otherwise, yea, any shop should be able to put in the plug and play stuff. Guess I'll give Brady a call and see what he can do.
Old 07-31-2018, 10:34 AM   #8
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
You'll need a custom driveshaft, but the stock diff is strong enough for a 500 whp build. You need to start thinking about swapping it for a Ford 8.8 if you're shooting for say 700+.
Stock axles would last, if you're not going to be doing a lot of launches and are not ridiculously low. I'd recommend DSS axle upgrade. Nothing else is required for the rear.
Old 07-31-2018, 05:28 PM   #9
CSG Mike
CSG Mike's Avatar
Elite Performance
86fun (07-31-2018)
Old 08-01-2018, 12:24 AM   #10
strmshadow84
Drives: 14 Cayman S, 16 Camaro 2SS
If your up North (Santa Rosa) you can try RPM in Rohnert Park, that's where I have my LS rx7 at, and they seem to do good work.
strmshadow84 is offline   Reply With Quote
Old 08-01-2018, 12:41 AM   #11
Bach415
Bach415's Avatar
Drives: Whiteout FRS
If this is going to be a street car in Cali, have you thought about the consequences of it not being a bar legal swap + smog?
Bach415 is offline   Reply With Quote
Old 08-01-2018, 12:53 AM   #12
Irace86.2.0
Only if he gets popped. Many areas of California are smog exempt, especially up here north of Santa Rosa, so no worries about finding a smog shop to pay off.
The Following User Says Thank You to Irace86.2.0 For This Useful Post:
Bach415 (08-01-2018)
Old 08-01-2018, 01:32 AM   #13
86fun
Drives: 2013 FRS
Yea, I had Martin build my 3SGTE race motor about 15yrs ago. They are pretty heavy domestic though, at least last time I visited. I was hoping for a place with 2J experience... or at least import experience.
Old 08-01-2018, 01:35 AM   #14
86fun
Drives: 2013 FRS
I don't live in a smog zone, I don't have to get smogged. If I sell it, then it has to go out of state. The car is going to remain 100% stock on the outside.
The Following User Says Thank You to 86fun For This Useful Post:
Recommendations for Body Shop in PHX/TUS Area JohnBgon BRZ First-Gen (2012+) — General Topics 3 05-28-2018 02:19 PM
PDX Shop Recommendations Crazy Drew Northwest 1 03-25-2015 02:17 PM
Paint/body shop recommendations in LA/So Cal area? PhysicalGraffiti Southern California 3 01-09-2015 04:29 PM
Any recommendations on a shop in San Diego to do spring swap? 355rockit Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 08-11-2014 02:43 PM
SF Bay Area Body Shop Recommendations? Jun_ Southern California 7 12-28-2012 12:43 PM
