Old 07-10-2018, 11:25 AM   #57
Trueweltall
Trueweltall's Avatar
Drives: 2016 Subaru BRZ
I am replacing my clutch and flywheel with the ACT XT Performance Street Kit, went ahead and got the Verus fork and pivot. I will try and remember to update this post if I have any lock out issues. I did read that the stock fork does tend to bend when you upgrade the pressure plate.
Trueweltall is offline   Reply With Quote
The Following User Says Thank You to Trueweltall For This Useful Post:
Pat (07-10-2018)
Old 07-29-2018, 09:31 AM   #58
reeves
Add me to the list.
Replaced my clutch/flywheel/TOB with stock/Exedy OEM ones, and now I can't shift into gear. When I took my transmission off, the fork & spline looked fine. Greased them both before installing everything. Bled the clutch with a entire quart of DOT4 brake fluid just to make sure no air is in the system. Adjusted the clutch pedal to MAXIMUM height just to make sure.. but the clutch isn't disengaging enough for me to shift into gear.
I might try swapping out the slave cylinder (again) just to make sure I didn't get a defective one from Autozone. If that doesn't work, I'll pull the transmission off (again) just to check everything.
Old 07-29-2018, 02:21 PM   #59
churchx
churchx's Avatar
Drives: 2014 GT86
reeves: funnily, sometimes maximum height is not the best clutch operation wise. After recent gearbox overhaul (synchros upgrade & some bearings change)/clutch change, i needed to reduce a bit pedal dead travel to get ease of gear switch back. As travel adjustment mod is simple, i suggest also to try other settings in range. Maybe it will work for you too.
Plumbus (07-20-2020)
Old 07-29-2018, 06:36 PM   #60
reeves
Thanks, I tried 3 adjustments: One slightly below the brake pedal, as shown on the DIY pedal adjustment, another slightly above the brake pedal height.. and the third at maximum height. All heights were still unable to get the shifter into gear.
Old 07-29-2018, 06:59 PM   #61
It might be worthwhile to verify the bore of that new slave cylinder. It should be 3/4 inch. The original is 13/16 inch. If the bore of the new slave cylinder is greater than 13/16, then likely that is the root of your issue. In the swap thread you mentioned that it didn't look the same. It might really be wrong, not just form as is the case with mine.
edit: after catching up with your post in the DIY thread, let's continue here. I don't think the issue lies with the slave cylinder. Just have a friend verify that the clutch fork is moving normally as you press the pedal.
I predict that something is wrong underneath the bell housing. :|
reeves (07-29-2018)
Old 07-29-2018, 07:53 PM   #62
churchx
churchx's Avatar
Drives: 2014 GT86
reeves: regarding pedal adjustment i don't look on pedal "position" at all. First i intentionally moved bite point almost before or right after beginning of travel, then started to dial back some dead travel in increments, till i was happy with result, +half turn more. I also was not looking at just basic tests like switch in gears (especially 1st & reverse) when stationary and trying to move forth & back w. clutch only, w/o gas, bet also short driving, trying out all gears.
reeves (07-29-2018), Ultramaroon (07-29-2018)
Old 07-29-2018, 08:37 PM   #63
reeves
My clutch won't fully disengage so I can't even focus on bite point yet. I adjusted my pedal to max height just to "make sure" pedal height wasn't the issue... before focusing on other possible causes.
I might just order the original 13/16 OEM slave cylinder first and try that. Then if that doesn't work, I'll pull the tranny apart again.
I did attempt to shift gears (engine off) while the shifter was wrongly installed a few inches LOWER than it should've been. Not sure if that can break anything, but I didn't get it corrected until @ermax helped me out with a pic of his shifter.
Old 07-29-2018, 09:11 PM   #64
reeves
It moves normally/freely as the clutch is depressed. Like you said though, the cylinder isn't likely the culprit. I'm just swapping out a new one because it's a quicker/cheaper thing to rule out before pulling the tranny apart.
The Following User Says Thank You to reeves For This Useful Post:
Old 07-29-2018, 10:01 PM   #65
The 3/4 in. bore that you have installed now will push the clutch fork 17% further than the stock one.
I doubt that there's anything wrong with your stock one either.
Old 07-29-2018, 10:10 PM   #66
reeves
I gotta order a new OEM one because my original one blew its top off lol.
I forgot to bolt it down (after reassembling the tranny) and when I stepped on the clutch, the copper ring & pin popped out of the cylinder body. It's pretty much toast. The copper part can't be pushed in. It won't even budge now, not even a little wiggle... even on a vice grip.
It's kinda bent upwards too if viewed from the side.
Old 07-29-2018, 10:15 PM   #67
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
Well that explains that.
Old 07-29-2018, 10:18 PM   #68
K gotcha. The piston is jammed crooked. If not for that, it would slip right apart.
Oh, and the piston is aluminum with a yellow anodized finish. The finish adds some toughness to the surface and makes it corrosion resistant. It also gives a visual indication of wear as it's only a couple thousandths of an inch thick.
Old 07-29-2018, 10:36 PM   #69
reeves
I have the Autozone 900061 slave cylinder on right now. Doesn't really make a difference though, it still won't shift into gear. I just wanted to eliminate the possibility that I got a faulty cylinder from them that's all, hence I'm ordering a new OEM cylinder.
Once I'm satisfied the cylinder isn't at fault, then I'll pull the tranny off to see if anything's wrong inside.
Everything I replaced is Exedy OEM (clutch, pressure plate, & flywheel) so I don't know why the clutch isn't disengaging.
And everyone who's had this problem either solved it by buying a new tranny, or they've vanished lol
Old 07-29-2018, 11:05 PM   #70
Irace86.2.0
Does the car shift into gear when the car is off?
Help With Reverse Camera Install tiz22 Electronics | Audio | NAV | Infotainment 28 09-08-2019 12:06 AM
Reverse lights not working after Short Shifter install SDIAZ Issues | Warranty | Recalls / TSB 0 01-15-2014 11:12 PM
DIY CLUTCH INSTALL .. charged86 DIY (Do-It-Yourself) Guides 3 09-13-2013 12:10 PM
Reverse Camera - install question Sutty AUSTRALIA 1 07-28-2012 08:40 AM
