Old 07-22-2018, 04:03 PM   #15
gtengr
Drives: 2017 BRZ
Interesting idea. For the sake of description, if the driveshaft's axis of rotation is lined up with an imaginary z-axis, it is symmetrical about the x and y planes. In my head, that means clocking angle would have no effect. Am I missing something?
I'm not sure, but it has worked for some people who've replaced the driveshaft, and is relatively easy to try and doesn't involve buying parts. It might be that the pinion yoke is balanced separately, so when the driveshaft is bolted up, there is potential for the balancing effects on each to interfere. Again I'm not positive tho.
gtengr is offline   Reply With Quote
The Following User Says Thank You to gtengr For This Useful Post:
jcw99 (07-23-2018)
Old 07-22-2018, 04:22 PM   #16
All that totally makes sense. Thanks!
Old 07-22-2018, 05:20 PM   #17
It would seem to me that the first step would be to measure the pinion angles.
If they were "off", then, since the transmission is aftermarket, to move the transmission up or down or rotate the differential.
I'd still have the driveshaft checked for balance.
Easy for me to say, as I ease in the air conditioned bedroom to take a looong Sunday afternoon nap
Ultramaroon (07-22-2018)
Old 07-22-2018, 05:37 PM   #18
I can testify from firsthand observation that the front diff mounts give a lot. It looks like one could get a couple degrees of adjustment with some shims.
humfrz (07-22-2018)
Old 07-27-2018, 01:51 AM   #19
twag4
Drives: frs
Is there room to line a straight edge up with one of the side ribs in the transmission housing?
Also, do you have a local shop that can verify the integrity of your new driveshaft?
No shop local, and I have tried that. Gonna pull the driveshaft and use the shaft end to check angle.
twag4 is offline   Reply With Quote
Old 07-27-2018, 01:52 AM   #20
twag4
Drives: frs
Have you tried clocking the driveshaft 180 degrees?
Yes, I’ve tried all four possibilities
WTB: 3.7 or 3.9:1 ring and pinion Salemate Canada Classifieds 0 01-25-2018 09:52 AM
WTB ring and pinion Salemate Canada Classifieds 0 03-13-2016 02:07 PM
Considering going to 3.727 gear/pinion in 6MT HotLavaMann Engine, Exhaust, Transmission 83 01-10-2015 10:34 AM
Change FD ratio to 4.56 by changing only pinion peachch Engine, Exhaust, Transmission 1 08-31-2013 01:25 PM
MFactory Ring and Pinion Sets JMPoole Engine, Exhaust, Bolt-Ons 14 07-31-2013 12:09 PM
