#15 |
Drives: 2017 BRZ
I'm not sure, but it has worked for some people who've replaced the driveshaft, and is relatively easy to try and doesn't involve buying parts. It might be that the pinion yoke is balanced separately, so when the driveshaft is bolted up, there is potential for the balancing effects on each to interfere. Again I'm not positive tho.
| The Following User Says Thank You to gtengr For This Useful Post: | jcw99 (07-23-2018) |
#16 | |
#17 |
It would seem to me that the first step would be to measure the pinion angles.
If they were "off", then, since the transmission is aftermarket, to move the transmission up or down or rotate the differential. I'd still have the driveshaft checked for balance. Easy for me to say, as I ease in the air conditioned bedroom to take a looong Sunday afternoon nap ![]() humfrz |
| The Following User Says Thank You to humfrz For This Useful Post: | Ultramaroon (07-22-2018) |
#18 | |
| The Following User Says Thank You to Ultramaroon For This Useful Post: | humfrz (07-22-2018) |
#19 |
Drives: frs
No shop local, and I have tried that. Gonna pull the driveshaft and use the shaft end to check angle.
#20 |
Drives: frs
Yes, I’ve tried all four possibilities
| WTB: 3.7 or 3.9:1 ring and pinion | Salemate | Canada Classifieds | 0 | 01-25-2018 09:52 AM |
| WTB ring and pinion | Salemate | Canada Classifieds | 0 | 03-13-2016 02:07 PM |
| Considering going to 3.727 gear/pinion in 6MT | HotLavaMann | Engine, Exhaust, Transmission | 83 | 01-10-2015 10:34 AM |
| Change FD ratio to 4.56 by changing only pinion | peachch | Engine, Exhaust, Transmission | 1 | 08-31-2013 01:25 PM |
| MFactory Ring and Pinion Sets | JMPoole | Engine, Exhaust, Bolt-Ons | 14 | 07-31-2013 12:09 PM |
