Old 07-25-2018, 11:27 AM   #379
Second Nature
Drives: 2013 FRS DIRTY ASPHALT
Originally Posted by TheStig85 View Post
Thanks for the quick reply!!
Second Nature is offline   Reply With Quote
Old 07-25-2018, 11:31 AM   #380
TheStig85
Drives: 2013 Subaru BRZ
Originally Posted by Second Nature View Post
When you swapped the sensors and OCV Did you swap them with the ones right under them or did you replace it? Looking to do this on my FRS I’m pulling up a p0018. Out of warranty here.
I'd just swap them from Left to Right. If the code changes from P0018, it's most likely that sensor that's bad. Just do the sensor first. If nothing changes, try the OCVs.
TheStig85 is offline   Reply With Quote
Old 07-25-2018, 11:32 AM   #381
TheStig85
Did a quick Google search... ignore the Part No.s but this is where they are located on the Engine:
Old 08-07-2018, 04:08 PM   #382
TheStig85
I know I've been quiet for awhile but my issue hasn't resolved itself. I'm thinking my only solution is buying another ECU, unless someone can enlighten me otherwise.
Assuming I need to go that route, for a 2013 Subaru BRZ Premium Manual, what ECU would I need to buy?
Old 08-07-2018, 06:34 PM   #383
Jesus, that thing is expensive.
https://parts.subaru.com/p/Subaru_20...2765AG511.html
Old 08-07-2018, 09:16 PM   #384
steve99
Drives: FT86
Do you have a flash device like tactrix or know someone with one. If so you can buy any secondhand ecu and just flash in the correct calibration. The hardware is all same auto manual and different years.
Theirs dozzens of them on ebay for arround $100 usa
Sportsguy83 (08-08-2018)
Old 08-08-2018, 10:18 AM   #385
kinghurl
Drives: BlueBurz
Is there someone stateside that can do this? There are growing piles of ECUs here that could be restored to at least stock making this fix a lot less $$.
Sent from my SM-G930V using Tapatalk
kinghurl is offline   Reply With Quote
Old 08-08-2018, 11:35 AM   #386
ermax
ermax's Avatar
You could get a Tractrix for 179 and do it yourself and then have a good tool for flashing, Techstream and datalogging.
Old 08-08-2018, 01:49 PM   #387
TheStig85
I don't but I was talking to a guy at Verus Engineering and he mentioned he heard some race teams having this code. Their solution? Aftermarket ECU, such as Motec.
This worth looking at? I don't want to buy another OEM ECU to just have the same problem I'm having now in another few months.
Old 08-08-2018, 02:25 PM   #388
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Motec adds up quick. M130 ECU is like 2K + custom harness.
Old 11-16-2018, 10:04 PM   #389
TheStig85
@steve99 @Ultramaroon
Update time!
I've procrastinated heavily on this due to frustration, travelling, etc. I finally took the time and met up with a local guy that tried to diagnose wtf is going on with my car.
He tested camshaft sensors, OCVs, VVT angles, wire harness, etc. Took us a good 6 hours. In the end he couldn't pinpoint exactly what the issue was but he thinks it may be either:
1) Oil Pressure is low.
Mechanically he says the car is perfectly fine. No knock, angles are perfect, etc. But if the oil pressure is too low, it could be causing the code to be thrown (P0016). How could it potentially be low? The camshaft oil filter. (Does our car have one of these?). He didn't have the tool/sensor to measure this, so we're just spitballing this idea right now.
2) ECU is gone bad again. I know I replaced it, but I'm being told since everything has been checked, it may be possible it went bad after 9 months. I'm looking into maybe borrowing one from a buddy for testing. Can I do this? If not, I may look into a cheap solution and buying a used one.
Old 11-16-2018, 11:21 PM   #390
Update time!
Oil pressure is plausible but it would have specific symptoms of lazy slew. Servo would be laggy and might even develop a low-frequency flutter if the integral gain is high enough.
The filters are here
Old 11-19-2018, 08:51 AM   #391
ermax
ermax's Avatar
When I rebuilt my engine I replaced those filters. Mine were clean but I could easily see these getting sludged up and restricting pressure. Unfortunately they aren’t easy to get to.
Old 11-19-2018, 10:01 AM   #392
TheStig85
Going to see if I can find a used ECU to test first. If the code doesn't throw, that's the issue. If it continues, then I'll need to look into the filters. Crossing my fingers. Unless anyone here has an ECU I can borrow?
P0016 fixable without new ECU? Mr.Jay Issues | Warranty | Recalls / TSB 8 02-06-2022 05:15 AM
P0016/P0017 cause AVOturboworld Issues | Warranty | Recalls / TSB 18 04-16-2021 11:09 PM
P0016 Code Shady195 Engine, Exhaust, Transmission 30 02-21-2019 02:31 PM
p0016 need help asap lol Issues | Warranty | Recalls / TSB 25 10-30-2018 03:49 PM
OFT P0016 and TSB question mmmcambelsoup Software Tuning 10 05-24-2017 09:24 AM
