Old 07-25-2018, 07:47 AM   #15
toyubie
Drives: none
Originally Posted by MCTeeJ View Post
Can confirm the r400 is a good exhaust, but they like to break hangers so be aware of that. I switched to a Tanabe Concept G and I like that more betterer.
Uh oh, mine is coming today... What do you mean they break hangers?
toyubie is offline   Reply With Quote
Old 07-25-2018, 08:01 AM   #16
MCTeeJ
MCTeeJ's Avatar
Drives: 2014 Scion FR-S
The muffler section is a bit weighted and the welds on the hangers like to crack and rattle after a while. I'm not saying it'll happen to you, but it's happened to more than a few people.
MCTeeJ is offline   Reply With Quote
Old 07-26-2018, 08:33 AM   #17
toyubie
Drives: none
Ah, I found a few posts about it. That's a little disappointing for the price, the weld quality on my N1 is stellar. Oh well, nothing a quick fat weld won't fix.
The Following User Says Thank You to toyubie For This Useful Post:
MCTeeJ (07-26-2018)
Old 07-26-2018, 05:26 PM   #18
Alpha86
Drives: 2013 Firestorm Red FRS
Well I tried the RTV, applied a thick bead to every flange, didn't fix it. My next plan is to have the stock midpipe cut to fit with the Y-pipe, and if that doesn't work then I'll see if I can grab a used Q300
Alpha86 is offline   Reply With Quote
Old 07-26-2018, 06:01 PM   #19
Ernest72
I have JDL UEL catless headers and Q300. No rasp but some drone. Got a hooker front pipe with helmholz resonator helped a lot over stock.
Old 07-30-2018, 10:41 PM   #20
perryair
junior mafia
Drives: ‘20 sti limited
don't know if you're still after the issue but i installed the exact same header back in the day and there was a certain rpm where it was too close to the underside shield and would rattle - but again only at a certain RPM range. my installer banged out that spot with a rubber mallet and the sound stopped.
20 sti limited | 17 bmw m240i | 16 scion im |15 brz limited {prokit, 17x8 +35 rpf1, bfg comp 2 a/s, stg 2, jdl uel, voodoo knob} | 05 honda civic | 06 scion tc | 95 mustang gt | 89 chevy s-10 cameo
perryair is offline   Reply With Quote
Old 08-04-2018, 02:41 PM   #21
Alpha86
The rasp has decreased a lot since I installed it, must be the break-in period. I'll keep an eye out for clearance issues when I do my oil change in about 200 miles.
Old 08-05-2018, 04:08 PM   #22
SuperTom
SuperTom's Avatar
Drives: C5, GT-86, '24 Colorado TrailBoss
That is what I got to help with drone.
I have ACE 350 Headers, Hooker Blackheart Catted/Resonated FP, Borla Catback. Car is noise free when cruising, opens up when you punch it. But not obnoxious or ricey or droney. The old school J-Pipe Helmholz resonator in the Hooker front pipe is great. Its basically old fashion noise cancellation technology.
Also Tune is huge to getting rid of annoying sounds, valve overlap ect.
SuperTom is offline   Reply With Quote
Old 08-06-2018, 06:40 PM   #23
Ernest72
Yeah. It does what it said it would do.
Will header cause rasp? Tysoncrosby21 Engine, Exhaust, Transmission 8 02-12-2017 04:09 AM
Rasp issue, need help on fix? slyder Engine, Exhaust, Transmission 9 01-23-2015 05:09 PM
Glasspack to get rid of rasp? dem00n Other Vehicles & General Automotive Discussions 3 10-18-2014 09:56 AM
Rasp help??? Gshoxx Engine, Exhaust, Transmission 3 05-01-2014 01:20 AM
RASP noise after Header install ANYONE?? Squido3J Engine, Exhaust, Transmission 5 04-02-2014 06:46 AM
