Old 07-21-2018, 04:53 PM   #19293
omgfrswtf
omgfrswtf's Avatar
Drives: 2015 FR-S
omgfrswtf, you are supposed to OIL the K&N filter, NOT fill it up with gas!
PS - welcome to the forum.
Ohshit. This explains the soggy throttle on my way to work today.
Lol, and thanks, thrilled to be here.
omgfrswtf is offline   Reply With Quote
The Following User Says Thank You to omgfrswtf For This Useful Post:
humfrz (07-21-2018)
Old 07-21-2018, 07:35 PM   #19294
SmartedPanda
SmartedPanda's Avatar
Drives: SWP BRZ Limited Manual. 2014
Finished putting on some used RCE in my rear and SPC LCA, took 4.5 hours roughly. First one took 3 hours, 2nd one took an hour, 30 mins to clean up and tighten everything.
[| Blox 490 Knob | Mishimoto Silicon Intake | K&N Filter | DD Always-On DRL | Tomei 60S | Weather Tech | RED USDM TOM's Tail Lights | OEM Underbody Panels | Intec High Mount Brake | RexSpeed Heated Wide Mirrors | TC105N 17x9 | Super Sport 245/40R17 |TRD Quickshifter | Porsche Brake Air Duct | TRD Sliding Armrest| OEM Knee Pads | MTEC Shifter Springs| WRX OEM Oil Cooler| Generic PVC Catch Can|]
SmartedPanda is offline   Reply With Quote
Old 07-22-2018, 05:58 PM   #19295
Aipex8
Drives: 2017 Toyota 86 860 Special Edition
A few LED mods today. First, some under hood lighting. There are two 12" strips on the underside of the hood (the little ridge just before the sound deadening material) and then three strips under the lip at the firewall. I had a similar mod in my previous car and the firewall lights lit up the oil filter and dipstick... here they are more for just looking cool, but still a functional mod as they are very bright LEDs. I'm not crazy about the color and may replace them with something less blue and closer to the next mod (but the wiring harness I made makes it easy to swap the strips out). The wiring harness is all custom and the strips are just some junk I picked up at AutoZone as my go-to for LEDs (VLEDS) doesn't carry the weatherproof strips I need.
Next, some really bright 6000K footwell lights hooked into the dome circuit (I also have dim colored footwell lights that come on with the lights for mood lighting). These are a perfect match for my map light bulb. Links to both below. Oh and I also scored some stock carpet mats on ebay. My lightly used 86 had WeatherTech mats which I'll use in the winter, but are pretty ugly that well lit if you don't need them in the summer months.
http://www.vleds.com/shop-products/a.../pcb-14-c.html
http://www.vleds.com/shop-bulb-numbe...5-24-ll-c.html
Aipex8 is offline   Reply With Quote
Old 07-22-2018, 06:38 PM   #19296
Lakitu
Lakitu's Avatar
Drives: 2017 Halo 86
Replaced toyota shitty broken and rusted studs with new ARP studs, put DBA rotors on.
Build Thread / Daily Driver
OFT Stage 2+, GrimmSpeed CAI, JDL Ultra Quiet FP, Perrin 2.5" Resonated CBE, Enkei 18x8.5 +45, 245/35 Continental ExtremeContact
Lakitu is offline   Reply With Quote
The Following 3 Users Say Thank You to Lakitu For This Useful Post:
Aipex8 (07-22-2018), Kaotic Lazagna (07-22-2018), new2subaru (07-22-2018)
Old 07-22-2018, 08:13 PM   #19297
Aipex8
What are the specs on the studs? They look longer.
Old 07-22-2018, 09:47 PM   #19298
Lakitu
Lakitu's Avatar
I'm not sure exactly but they are about two times the length of OEM. Open ended lug nuts are pretty much required for these.
Old 07-22-2018, 10:37 PM   #19299
Kaotic Lazagna
Drives: GR Corolla
Installed genuine TRD front lip and skirts, and then changed the oil.
The Following 2 Users Say Thank You to Kaotic Lazagna For This Useful Post:
humfrz (07-23-2018), Leonardo (07-22-2018)
Old 07-23-2018, 12:15 AM   #19300
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
Finally got around to detailing it this weekend. Had not gotten a chance to do it at all this year.
Friday: Washed
Saturday: Cleaned interior, claybar
Sunday: Touch up paint, polish, sealant
It is now shiney AF.
Old 07-23-2018, 12:53 AM   #19301
That's pretty long!
Why is that?
Old 07-23-2018, 12:57 AM   #19302
Friday: Washed
I'm impressed - that would have taken me a week ..
Old 07-23-2018, 01:05 AM   #19303
Lakitu
Lakitu's Avatar
That's pretty long!
Why is that?
These studs are meant to be used in conjunction with wheel spacers, I believe, which I don't use. Thankfully Muteki lugnuts are long enough that the studs don't stick out of them. Though, you can see the dome tip and it actually provides a nice contrast to the otherwise black wheels/tires/lugnuts setup. I'll probably paint them black if I get tired of the look.
The Following User Says Thank You to Lakitu For This Useful Post:
humfrz (07-23-2018)
Old 07-23-2018, 01:11 AM   #19304
Ahhh...yes, I got the picture ..
Old 07-23-2018, 03:08 AM   #19305
DIM
Didn’t do anything to my 86, but I bought a new toy.
DIM is offline   Reply With Quote
The Following 3 Users Say Thank You to DIM For This Useful Post:
ermax (07-24-2018), Leonardo (07-23-2018), MJones_RB (07-25-2018)
Old 07-23-2018, 05:40 AM   #19306
notout86
Drives: GTS 86 auto
Oh, I have no idea -
"When they first got the car, two guys are looking at the car and under dash. Not sure why they were doing that other than they wanted to disable my dash cam".
If it would make you feel any better, when I have the oil changed in my car, I mark the old filter before I take it in. Then, after the oil change, while the car is still in the lot, I check to make sure the filter has been changed.
In addition, I check the oil dip stick to make sure they put the right amount new oil in and it was in fact new oil. I also look under the car to make sure there isn't any oil dripping from the drain plug -
Gosh humfrz, a little bit of me has died. With your background, experience and knowledge, I would have taken you for someone who does his own oil & filter changes. Especially on this car as it is so simple, starting with the cup-holder for the filter.
BTW, on the rare times someone else has done my changes it has always been overfilled which can be bad.
GTS86 Auto (Australia)
The Following User Says Thank You to notout86 For This Useful Post:
humfrz (07-23-2018)
