Old 07-20-2018, 05:00 PM   #15
Originally Posted by ermax View Post
The WIX 57830 or Napa Gold 7830 (made by WIX) seem to be good. I was looking at the PurolatorONE filter for our cars and it looks identical to the WIX. Not sure if WIX is actually making all these filters or if some chinese company makes them all and Purolator, Napa and WIX all buy from the same supplier.
I actually used the PureONE filter in my car after I rebuilt the engine. I only ran it for a few days before doing a filter/oil change. I need to cut it open and see how it looks.
I have rebuilt probably 20 engines over the years and never once though of doing this. It could tell you a lot more than just looking at what can easily be seen.
Old 07-20-2018, 05:14 PM   #16
ermax
ermax's Avatar
One of these days I'm going to get one of these to make it a little easier.
Old 07-21-2018, 01:40 AM   #17
FirstWinter
Drives: Car
Not even sure how much you would see from cutting a filter open. I just send in my oil for analysis each change and get detailed reports.
FirstWinter is offline   Reply With Quote
Old 07-21-2018, 08:55 AM   #18
Ernest72
My father got hundreds of thousands of miles are various cars with orange Fram filters. Not saying they are a good filter, but it’s likely your OCI, not your filter.
I use pure one or Oem. No need to spend on higher cost filters unless maybe you are tracking the car. But no big deal if you do, it’s not a lot of money over the life of the car.
Old 07-21-2018, 08:58 AM   #19
ermax
ermax's Avatar
I was talking about the construction. In particular how much media is in them. The cheap Fram filters for example have very little media in them.
Old 07-21-2018, 09:01 AM   #20
Summerwolf
Panda Trueno
Summerwolf's Avatar
Drives: No twin now.
And cardboard endcaps.
The Following User Says Thank You to Summerwolf For This Useful Post:
ermax (07-21-2018)
Old 07-21-2018, 03:33 PM   #21
Stang70Fastback
A.K.A. Starlord
Stang70Fastback's Avatar
Drives: 2015 Series.Blue
I use OEM. It's only, like, $8 from the dealership for the filter and washer.
Check out my blog, read all about my BRZ adventures, and oogle my sweet cell-phone photos!
You can also find me on Instagram, and on Facebook.
Stang70Fastback is offline   Reply With Quote
The Following 2 Users Say Thank You to Stang70Fastback For This Useful Post:
nikitopo (07-22-2018), Overdrive (07-22-2018)
Old 07-22-2018, 07:51 AM   #22
mrg666
pessimistic skeptic
mrg666's Avatar
I bought a couple of K&N filters on sale and I will keep using them for another year. I trust them. The other one I check is Mobil-1.
Old 07-22-2018, 08:30 AM   #23
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
Guys, check with your dealer which oil filters (if any) don't void your engine warranty.
Old 07-22-2018, 10:51 AM   #24
Stang70Fastback
A.K.A. Starlord
Uhhh... what are you talking about? No filter voids your warranty so long as it is designed for your vehicle. Even then it won't VOID anything. They would have to provide evidence that the oil filter caused the failure.
Do you also tell people they have to check with the dealer before using an aftermarket brand of oil? Don't be silly.
The Following User Says Thank You to Stang70Fastback For This Useful Post:
Spuds (07-22-2018)
Old 07-22-2018, 11:15 AM   #25
ZionsWrath
Thanks
ZionsWrath's Avatar
I been using purolator pure one, buy a dozen at a time. Got several left for my BRZ. Had to buy a new daily and as I understand they don't make the same yellow pureones anymore? Not sure, i got 2 months before i have to do an oil change. I'll probably stick to OEM for my daily as i plan to do 4-6 month oil changes.
Interested to see other posts. Ibwould go Mobil 1 but they were like $10 a piece last i checked, too much IMO.
Old 07-22-2018, 11:30 AM   #26
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
Oh really? Who can say if an oil filter is designed for your vehicle or not? The issue is with the pressure relief valve. It is known that Subaru has a higher bypass pressure spec and if the filter is not the correct one, you take the risk your oil to stay more time in the bypass mode (i.e. stay unfiltered).
Even if my dealer said that another oil filter doesn't void my warranty, I wouldn't do it if I cared of my engine's health. What's the point to save just a few dollars on such a high importance peripheral?
Check here for details: https://www.bobistheoilguy.com/forum...Number=1410171
Old 07-22-2018, 11:37 AM   #27
ermax
ermax's Avatar
The WIX bypass pressure matches the OEM filter.
There are laws in the US preventing dealers from denying claim because of aftermarket parts like filters. The dealers still try to pull one over on people though.
The Following User Says Thank You to ermax For This Useful Post:
Old 07-22-2018, 03:55 PM   #28
chaoskaze
The Fail Boat
chaoskaze's Avatar
Drives: CWP S.B.
Originally Posted by Somerandom18 View Post
I've always preferred Wix/XP filters. They're available at O'Riley's.
Sent from my Pixel XL using Tapatalk
Don't use wix if you have a oil cooler of some sort. * basically a "flat top" that sticks out
The seal on those it's pretty badly designed * cuz it's flat & not tapered....even stock oem filter seals much better. Friends had those & they would just leak oil. I guess it really depends on the design/quality of oil cooler sandwich plate itself but ppl should know.
if you are stock in that department then it's totally ok to just run whatever.
As for myself I been using cusco magnetic oil filters, but I would use any magnetic oil filter really.
WTB Overpipe (Tomei preferred) SocalMonsta Want-To-Buy Requests 2 11-16-2016 04:05 PM
WTB: Mid-pipe (invidia preferred) dubaar Canada Classifieds 5 06-01-2016 11:43 PM
Preferred downshifting method? Wired86 BRZ First-Gen (2012+) — General Topics 176 05-05-2016 06:36 PM
Best/Preferred gauges for monitoring. gdrider77 Forced Induction 84 11-24-2015 05:35 AM
FS / FT 2015 BRZ Limited 6MT *Trade Preferred* jim1234664 Cars for Sale/Trade 1 04-14-2015 01:32 AM
