Old 07-20-2018, 03:59 PM   #15
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Originally Posted by churchx View Post
Makes me think what aftermarket magnetic ones were made for then.
Some transmissions did not have plugs that were magnetic, mostly older cars. Those required frequent oil changes.
Those same plugs have the same thread pitch and bolt size as newer cars (aka ours), so the drain plug is interchangeable. If you notice, most of these will just have a thread and "types of vehicles" it fits to.
-alex
Old 07-20-2018, 11:21 PM   #16
NRXRaptor
Originally Posted by 8RZ View Post
Gimmick item.
false. how is it just fine to have metal shavings all up in your gears as opposed to fewer metal shavings? magnetic engine oil drain plugs and filters are gimmicks, as the filter is in fact a filter
NRXRaptor is offline   Reply With Quote
Old 07-20-2018, 11:27 PM   #17
8RZ
The Gunshine State
8RZ's Avatar
Drives: '14 BRZ Limited
You misunderstood me. I’m saying aftermarket magnetic plugs are gimmicks since the stock ones are already magnetic.
Current DD: M235i
8RZ is offline   Reply With Quote
Old 07-20-2018, 11:31 PM   #18
Summerwolf
Panda Trueno
Summerwolf's Avatar
Drives: No twin now.
That diff plug is definitely magnetic. You can see it on your first couple changes, lol.
Old 07-20-2018, 11:35 PM   #19
rande
rande's Avatar
Drives: Spyder, MR2, FRS, Tundra
The drain plugs in my 2013 are not magnetic.
rande is offline   Reply With Quote
Old 07-20-2018, 11:58 PM   #20
MCTeeJ
MCTeeJ's Avatar
Drives: 2014 Scion FR-S
Gimmick item.
Hello fellow T86 member
MCTeeJ is offline   Reply With Quote
The Following User Says Thank You to MCTeeJ For This Useful Post:
8RZ (07-23-2018)
Old 07-21-2018, 12:49 AM   #21
You obviously didn't get the optional magnetic drain plug package …
Old 07-21-2018, 12:53 AM   #22
hmmm...
Old 07-25-2018, 07:55 AM   #23
jayliu.jiayu@gamil.com
jayliu.jiayu@gamil.com's Avatar
Drives: 2017_86 2016_frs 2007_335i
they r both magnetic drain plug. the diff plug with very large magnetic on the top of the plug. and the transs plug was mounting in side of plug
i just change those fluid one month ago on my 2017 Toyota 86
jayliu.jiayu@gamil.com is offline   Reply With Quote
Changing Differential and Transmission fluid Seabass47 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 3 02-20-2017 12:21 AM
Changing Automatic Transmission Fluid euthqt Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 4 06-01-2016 03:16 AM
Different brand rear fluid changing torque bias? zooki Engine, Exhaust, Transmission 1 09-06-2015 10:13 PM
Differential and Transmission Fluid Swap with Red Line Oil - 2013 Subaru BRZ JPxM0Dz Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 1 05-05-2013 05:12 PM
Transmission and Differential Fluid Change LINK Amadeus DIY (Do-It-Yourself) Guides 1 12-23-2012 06:01 PM
