Old 06-19-2018, 08:30 AM   #43
Rican_D
Rican_D's Avatar
Drives: Asphalt FR-S
He says that they are the same same xB led projectors they use on other applications. They have videos of those, perfect wide beam pattern.
Sent from my Pixel 2 XL using Tapatalk
Rican_D is offline   Reply With Quote
Old 06-19-2018, 02:00 PM   #44
kevaughan
kevaughan's Avatar
Drives: BMW E30, 2014 FR-S
Originally Posted by NRXRaptor View Post
SpecD's don't come with lights. That's why they're so cheap. You have to provide your own. From what info I've gathered their quality control is hit or miss. Haven't heard the same from Morimoto or Intec, at least with regards to headlights
Yup. I'm looking into a no-compromise retrofit for the Spec-D headlights with HID lenses and a whiter more brighter DRL bar. It's going to end up being $1600CAD for me from (GTARetrofits.com).
If I can get myself to like the DRL bar on these intec/coplus/ft86sf LED headlights, I rather get these over the Spec-Ds for hassle-free and plug-n-play solution that's cheaper.
kevaughan is offline   Reply With Quote
Old 07-19-2018, 10:11 PM   #45
Rican_D
Rican_D's Avatar
A little update, they shipped out the lights today. I'm supposed to be getting them Monday. Hopefully get them installed sometime soon after.
The Following 3 Users Say Thank You to Rican_D For This Useful Post:
Chimera (07-20-2018), Draco_PR23 (07-26-2018), zeal86 (07-19-2018)
Old 07-20-2018, 08:10 PM   #46
Chimera
Drives: FRS
I too decided to get a set. Did yours ship, or did they create the shipping label? My shipping label was created a few days ago, but mine hasn't actually shipped yet last I checked. ��
Nvm, mine now say in transit. ��
Old 07-20-2018, 10:55 PM   #47
shadow_772
Drives: 2014 BRZ Limited
Looking forward to thoughts on these once you have them in hand
shadow_772 is offline   Reply With Quote
Old 07-20-2018, 11:13 PM   #48
NRXRaptor
I beat everyone to it lol. despite my immense driving skill, I collided with someone who didn't want to merge as I was checking to see if I could follow. geico was ok with getting these ones because they cost less than getting refurbished OEM headlight units
my initial impression is that they are functionally superior to the intec versions. beam pattern is much wider. the single projector lens looks better imo than the horizontal one stacked on top of the parabolic reflector. the toggle between sequential and normal is something that should have been there on the intecs. they cost less. I can't confirm if they are brighter or not as I cannot measure lumens. these don't seem to have a cool iridescent uv coating that will degrade within a year, so that's a plus. if anything goes wrong with them I'm pretty sure subispeed will hang me out to dry just like they and intec both did when the uv coating disintegrated. these are also truly plug and play. subispeed falsely advertised the intecs as plug and play but they definitely weren't with my 2016 BRZ. the plus side is that I really like the shop that fixed that for me. I'm pretty damn sure that you need a hyperflash relay with these, as I get hyperflash in sequential mode sometimes but never in normal mode
imo the intecs had some cool plastic doodads in the housing that I could see when I walked up to the car, and the iridescent uv coating was really cool even though it was functionally garbage
overall these are a much better buy than the intecs. I wish I had waited a year. I think you guys will really like your lights
NRXRaptor is offline   Reply With Quote
The Following 2 Users Say Thank You to NRXRaptor For This Useful Post:
Chimera (07-21-2018), kevaughan (07-20-2018)
Old 07-20-2018, 11:35 PM   #49
carlovestela
Drives: 2015 Firestorm FRS
Yeah. I ordered mine last july 4 at theretrofitsource
carlovestela is offline   Reply With Quote
Old 07-20-2018, 11:37 PM   #50
carlovestela
Is it much brighter than stock?
Old 07-21-2018, 08:17 PM   #51
Chimera
Drives: FRS
Haven't driven with them yet, or adjusted the lights.
If you get the 6pin to 8 pin adapter, i recommend connecting that the the headlight before putting the headlight in the car, its tight and applying it on the car I cracked the mount on one side of mine from force at an angle probably. its still on there, just wiggles a little now.
The Following User Says Thank You to Chimera For This Useful Post:
BlackieChanz (09-23-2018)
Old 07-21-2018, 09:29 PM   #52
carlovestela
I thought its plug and play for frs.
Btw are you still using your turn signals at the top of yout foglights?
Old 07-21-2018, 10:14 PM   #53
Chimera
Drives: FRS
It is with adapter harness. And yes, I'm using both signals atm.
LeonardoDaVinny (11-17-2018)
Old 07-22-2018, 10:15 AM   #54
carlovestela
Any plans on disconnecting the lower signal?
Btw. Whats your fog lights?
And your seat cover? Lol
Thanks
Old 07-22-2018, 10:44 AM   #55
Rican_D
Rican_D's Avatar
Lol, yeah shipped. Coming in tomorrow.
We need to find ppl who ordered the FT86SF versions, so we can get a comparison going.
The Following User Says Thank You to Rican_D For This Useful Post:
Chimera (07-22-2018)
Old 07-22-2018, 12:05 PM   #56
Lakitu
Lakitu's Avatar
Drives: 2017 Halo 86
They look good, but I prefer the DRLs running along the top rather the bottom.
Build Thread / Daily Driver
OFT Stage 2+, GrimmSpeed CAI, JDL Ultra Quiet FP, Perrin 2.5" Resonated CBE, Enkei 18x8.5 +45, 245/35 Continental ExtremeContact
Lakitu is offline   Reply With Quote
The Following 2 Users Say Thank You to Lakitu For This Useful Post:
chaoskaze (07-22-2018), kevaughan (07-22-2018)
Spec-D Headlights & Morimoto D2S HID Kit FyeaFRS Cosmetic Modification (Interior/Exterior/Lighting) 9 03-10-2017 12:19 AM
6K H11 Morimoto HID Kit Zero90 Exterior Parts (Aero, Lighting, Etc.) 2 05-20-2014 12:49 PM
FS: FRS HID Retrofit Kid (Morimoto) Khyron686 Exterior Parts (Aero, Lighting, Etc.) 2 04-21-2014 10:08 PM
Stock FR-S Headlights & Tail Lights, Morimoto Elite HIDs, and OEM Mud Guards tbox Exterior Parts (Aero, Lighting, Etc.) 14 01-11-2014 02:18 PM
Help Morimoto HID kit Jacob G. Cosmetic Modification (Interior/Exterior/Lighting) 4 02-18-2013 02:03 AM
