Old 02-18-2018, 02:31 AM   #15
twag4
Drives: frs
Also, believe it or not, it fits in there now, but just. It doesn’t leave enough room for movement. I’m pretty sure firm engine mounts will be a must.
twag4 is offline   Reply With Quote
Old 02-18-2018, 05:00 AM   #16
CSG Mike
CSG Mike's Avatar
I've been through 3 transmissions in 3 months, with a built one on the way, but this definitely has my eyes on it, as a potential option for guys who don't want to spend as much as I am on mine...
twag4 (02-18-2018)
Old 02-18-2018, 02:14 PM   #17
twag4
Drives: frs
I was seriously looking at going with a quaife sequential, but I wasn’t sure I would want to live with it using it on the street. This was a big welcome option!
The Following User Says Thank You to twag4 For This Useful Post:
CSG Mike (02-18-2018)
Old 02-18-2018, 07:45 PM   #18
Colin86
Drives: 86
Power level? What were you doing with the car when the failures occurred?
Colin86 is offline   Reply With Quote
Old 02-19-2018, 01:17 PM   #19
CSG Mike
CSG Mike's Avatar
One had an input shaft bearing failure at about 220whp. On track. Live streaming too. I believe some track enthusiasts watched it happen live.
Second one cracked gears 1-4, and the 3/4 shaft failed completely. On the street. ~280whp.
Third one failed on track at 250whp. 4 laps in. Bent shift fork? Stuck between neutral and 4th.
Car is capable of 360whp.
Old 02-19-2018, 11:27 PM   #20
twag4
Drives: frs
Some pics of the and after the installation:
The Following 9 Users Say Thank You to twag4 For This Useful Post:
FunnyGopher (07-17-2018), gtengr (02-28-2018), Irace86.2.0 (04-18-2020), lamawithonel (07-17-2018), shiro (02-11-2019), Spawn_Of_Creation (02-27-2018), StraightOuttaCanadaEh (02-20-2018), turbocat (03-03-2018), Yobiwan (02-24-2018)
Old 02-20-2018, 12:46 AM   #21
twag4
Drives: frs
well crap, some of them are sideways or upside down. Sorry guys!
Old 02-27-2018, 07:26 PM   #22
Spawn_Of_Creation
Human
Drives: 2015 BRZ Black
Are those solid or poly trans mounts?
If you have driven it, whats the NVH like?
"Always listen to experts. They'll tell you what can't be done, and why. Then do it." - The Notebooks of Lazarus Long
Spawn_Of_Creation is offline   Reply With Quote
Old 02-27-2018, 11:31 PM   #23
twag4
Drives: frs
There is a polyurethane mount on the direct bottom of the transmission, mounted with two bolts to the black “V” shaped piece. Haven’t driven it yet. I have several more things to accomplish to get it drivable.
Old 07-15-2018, 02:21 PM   #24
choi0706
Drives: t
any update?
choi0706 is offline   Reply With Quote
Old 07-16-2018, 09:44 PM   #25
twag4
Drives: frs
Transmission works well, has nice shifting. A little noise in the shifter that I need to address, but I have a very y light flywheel, and very firm engine mounts. My engine is on a very soft break in tune right now also. I have made many changes, including Driveshaft shop axles. I have a vibration somewhere that I need to isolate. It is either the driveshaft or axles, as it also occurs with clutch pedal pressed and engine at idle. I will post again once I figure it out.
Old 07-16-2018, 10:08 PM   #26
CSG Mike
CSG Mike's Avatar
Other way around. If it happens at idle, not moving, then it is on the engine side.
If it happens only at speed, whether or not you have the clutch depressed, then it would be trans/post trans between the trans and wheels.
Old 07-17-2018, 06:15 AM   #27
twag4
Drives: frs
It only occurs when the car is moving. If I am at say 75 mph, and I press the clutch and let the engine drop to idle, the vibration is still there.
Old 07-17-2018, 11:22 AM   #28
CSG Mike
CSG Mike's Avatar
Ah, okay I must have misunderstood.
Def something between the trans and tires.
Help! Best option to fix this? timmydatooth Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 11 04-04-2017 02:33 PM
brz lip kit option Davesta619 Cosmetic Modification (Interior/Exterior/Lighting) 4 06-12-2016 11:46 PM
Which is the best FI option? gt8613 Forced Induction 20 01-03-2014 01:21 PM
New F/I option SnapOv3st3r Forced Induction 41 03-24-2013 09:44 PM
topspeed difference between manual transmission and automatic transmission torquemada BRZ First-Gen (2012+) — General Topics 51 05-04-2012 07:54 PM
