Old 06-10-2018, 02:05 AM   #1
Donovan34
Donovan34's Avatar
Drives: 2014 Turbo Monogram Frs
Automatic turbo frs 2nd gear problems.
Hey guys I’ve been have a reoccurring issue. When I’m on WOT going from 1st to 2nd, there seems to be a lag between it. Like it takes a second or two to actually switch. It happens almost every time and only seems to be going from first to 2nd gear. I’m pushing about 10 psi. Any thoughts?
Donovan34 is offline   Reply With Quote
Old 07-06-2018, 01:33 AM   #2
Decimus
BAE
Decimus's Avatar
Drives: Asphalt FRS
Check your ATF to see if its low. When mine was slightly low, gear changes took a lot longer and the shifts were very hard. I also had a boosted auto brz on 10psi greddy kit.
Decimus is offline   Reply With Quote
Old 07-10-2018, 01:21 AM   #3
Savoelh
Savoelh's Avatar
Drives: Scion FRS
Atf = automatic transmission fluid?
Savoelh is offline   Reply With Quote
Old 07-16-2018, 12:45 PM   #4
tyler_win_photo
tyler_win_photo's Avatar
Drives: 2014 Scion FRS (Asphalt)
Yes
tyler_win_photo is offline   Reply With Quote
Old 07-16-2018, 09:55 PM   #5
Savoelh
Savoelh's Avatar
Drives: Scion FRS
I have been having this same issue. I thought the tranny was just responding slow but I will check the fluid levels and let you guys know as soon as I find out.
Old 08-04-2018, 02:28 AM   #6
Savoelh
Savoelh's Avatar
Drives: Scion FRS
So I took a gander at the fluid levels of the transmission and they are good. I will be taking the car into a transmission shop in the future to find out some way to improve transmission response time.
Hopefully it will be an easy mod / fix. Ive always known the AT to be very slow in this car so I doubted it was anything to do with the fluid but it was a good thought.
Old 08-04-2018, 11:28 PM   #7
tyler_win_photo
Does it happen only on full throttle or even with light throttle?
Old 08-07-2018, 01:09 AM   #8
Savoelh
Savoelh's Avatar
Drives: Scion FRS
For me it is only under full throttle.
Old 08-07-2018, 12:46 PM   #9
tyler_win_photo
Could try asking dealership to reset transmission ecu.
Old 08-07-2018, 01:40 PM   #10
Trust86
Drives: 2016 Halo FRS
Does the atf smell burnt?
Trust86 is offline   Reply With Quote
Old 08-10-2018, 12:34 AM   #11
Savoelh
Savoelh's Avatar
Drives: Scion FRS
I don't remember the smell tbh.
I do think it that it might have something to do with the tune though. The car only has 12k miles on it.
Sent from my LM-V350 using Tapatalk
The Following User Says Thank You to Savoelh For This Useful Post:
Trust86 (08-10-2018)
Old 08-10-2018, 03:32 PM   #12
snowdog
Drives: 2013 Scion FRS
Are you in "sport mode"? I have found that in "sport mode" my car will hit the rev-limiter and cut power before it shifts to 2nd. Not sure if this is what you are experiencing.
snowdog is offline   Reply With Quote
Old 08-10-2018, 04:28 PM   #13
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
Can you provide a datalog of the occurrence during a pull or something?
Edit: I just want to confirm it is transmission and not engine. FWIW, auto transmissions can be tuned. APR for German cars does it all the time.
Old 08-12-2018, 10:51 PM   #14
Savoelh
Savoelh's Avatar
Drives: Scion FRS
Hmmm yes actually. I am usually in sport mode with manual mode on as well. I'm gonna have to test this the next time I get into the car. Really sounds like this could be it.
The car is tuned with EcuTech so I [I]can[I] get a data log but I dont have cables right now so I cant. But soon hopefully
Also at one point I was thinking that it was from the engine (maybe a miss fire under load) but I've moved away from that thought after paying closer attention.
*Automatic* Second Gear Issue!! Donovan34 Engine, Exhaust, Transmission 11 08-25-2017 11:40 AM
MT:Problems with engine rattling in 2nd gear. awhatzable Issues | Warranty | Recalls / TSB 14 10-18-2015 12:07 PM
ECUTEK for automatic FRS problems alex6219 Software Tuning 3 06-03-2015 04:49 AM
Manual gear shift in Automatic 86 djmm Scion FR-S / Toyota 86 GT86 General Forum 21 07-30-2014 08:08 PM
1st gear problems? Robert95g Engine, Exhaust, Transmission 11 12-15-2013 11:49 PM
