Old 12-14-2013, 03:51 PM   #1
Robert95g
Drives: 2013 FR-S Whiteout
1st gear problems?
Anybody else randomly have a hard time putting it into first gear? Like it catches on something's or there's rubber blocking it? Sometimes it happens sometimes it doesn't for days. Also very very less often going into second? No other gears have that problem? Someone help!!!
Robert95g is offline   Reply With Quote
Old 12-14-2013, 04:06 PM   #2
Vlady
Vlady's Avatar
Drives: Argento Scion FRS
It only happens sometimes if I down shift into first or happens when its cold outside.
Vlady is offline   Reply With Quote
Old 12-14-2013, 04:09 PM   #3
humfrz
You might try putting it into reverse before you put it into first, if the transmission is cold ......
No, mine doesn't have that problem.
humfrz
Old 12-14-2013, 04:09 PM   #4
whaap
whaap's Avatar
I've never had a problem. I don't down shift into first gear unless I'm just barely moving.
whaap is offline   Reply With Quote
Old 12-14-2013, 04:10 PM   #5
Iand518
Iand518's Avatar
Drives: 2013 asphalt fr-s
Sometimes reverse gear stubborn, and will have to go in 1st come back to center then reverse. My accord did this also. Sticky 1st would concern me a little, that second gear concerns me more. I'd have service take a look .
Iand518 is offline   Reply With Quote
Old 12-14-2013, 04:11 PM   #6
FR-S Matt
With 4.10 gears on a manual, 1st gear is so short that downshifting to it isn't a good idea. Never had a problem going into first. If in ever rolling above 5 mph, I'm always in 2nd.
Old 12-14-2013, 04:16 PM   #7
Iand518
Iand518's Avatar
I also don't recommend down shifting into 1st much above walking . Be kind to your synchronizers.
Old 12-15-2013, 09:29 PM   #8
Turdinator
Señor Member
Turdinator's Avatar
You can always double de-clutch to get back into first easier.
1974 TA22 Celica
2013 86 GT
Old 12-15-2013, 09:36 PM   #9
Hanni_0176
Hanni_0176's Avatar
Drives: 2013 Scion FR-S 10 Series MT
I've noticed that when it's cold out and the engine is still cold, I occasionally have to double clutch when downshifting into 2nd or 1st gear. If I approach a stop and don't feel like double clutching, I have to come to a full stop (0 mph on the dash) in order to get it smoothly into first. 2nd gear almost always grinds a tiny bit when upshifting into 2nd for the first few times also.
Mods: K&N Air Filter - Open Flash Tablet (Stage 1 v1.55) - more to come!
Hanni_0176 is offline   Reply With Quote
Old 12-15-2013, 09:56 PM   #10
Iand518
Iand518's Avatar
Grinding when up shifting into 2nd, Even when cold is not right. Like clutch isn't fully disengaging. Better have it checked.
Old 12-15-2013, 10:33 PM   #11
mike the snake
I wonder about the clutch as well.
So many people report having issues with shifting probs in different gears, I wonder if the issue lies within the clutch and not the transmission.
If the pressure plate didn't retract enough, or the clutch disk wasn't perfectly flat (poor design or manufacturing), it would do exactly what everyone is reporting.
Old 12-15-2013, 10:49 PM   #12
ciro
Drives: Scion FR-S
When I first purchased the FRS I thought I had air in the clutch line which may have been true because one day the clutch feel firm and the issues reduced. As they still were happening I took it to the dealer many times and go rejected when I asked them to inspect the internals of the transmission to check if there is a problem anywhere. Long story short they did a fluid change after many visits and that helps.
Get an fluid change and let the car warm up. Speaking that its been about 0 degrees this month in minne-snow-da I let my engine get at least to the cold mark before even moving the gears. It still has some trouble from time to time but just tap it quick into second and back to first with no issues. Also I think people are wrong to baby this transmission. As the temp range and tolerances are mostly for warmer climates as I am suspecting more and more the more wear and frequent fluid changes during the warranty period are a good way to cut the gears and get the easy feel back.
Take it or leave it, its my own thoughts but I can get into every gear now very smoothly and first gear easily while at even 15mph with the OEM fluids everyone hates ( Yes some people think thats bad).
Just found this on Aisin website I laughed!
http://www.aisin.com/technology/reli/environment/
ciro is offline   Reply With Quote
Top Gear Crashes Helicopter During Filming of "Top Gear Korea" Episode SteveH Other Vehicles & General Automotive Discussions 7 02-13-2013 12:08 AM
Reverse Gear not going into gear? MT joergasm Issues | Warranty | Recalls / TSB 22 11-29-2012 12:08 AM
No more 1st gear thump or 2nd gear notchiness kc4mne Scion FR-S / Toyota 86 GT86 General Forum 28 09-06-2012 08:39 PM
5th Gear and 6th Gear 0% throttle to 80% throttle gear crunch? kharn83 Issues | Warranty | Recalls / TSB 9 08-06-2012 07:44 PM
Reverse gear on the first and second gear side randytindoggy Scion FR-S / Toyota 86 GT86 General Forum 50 01-29-2012 01:21 PM
