| BRZ First-Gen (2012+) — General Topics All discussions about the first-gen Subaru BRZ coupe |
#15 | |
#16 |
Drives: FRS 2013
Is yours automatic?
#17 |
Doesn't matter if he is in England.
If he is in London, Ontario he can bring it by and show me.
#18 |
Drives: 2018 BRZ Limited, 2017 Sportage
You could read the question I asked. I know the differences between the two engines, they are well publicized. I wanted to know if the part was different and how/why. For example, if they are made of different materials, does the aluminum one disperse heat better which is needed for the revised engine. Why is this relevant? If you have an engine with the regular cover, wouldn't better heat dispersal be a good thing as an upgrade? So, can you answer the question or are you only looking for opportunities to try and slight someone? Or perhaps this is just one of those 33 posts you must do each day....
#19 | |
Here let me narrow it down for you.
#20 |
Drives: 2014 BRZ Limited
#21 |
#22 |
pessimistic skeptic
I heard 2017 engine is so much more improved. Is that true? Maybe OP can just swap the engine with 2017 version. It would be awesome! Anybody has done this swap before? Or it could be possible to replace intake and exhaust manifolds with the new versions. I am already liking this idea!
#23 |
You're right. My apologies.... My assumption is that if that manifold is put on the non-manual version, it won't work because of other changes in the engine. In fact, it might not even fit. Again, I was just looking for a possible upgrade opportunity...
#24 |
Well considering that the sum total of all the changes including internals, exhaust, intake system and tune was only 5HP then there would be virtually zero benefit to changing just one component. We never have found any truly sensible reason why all the changes were not made to the autos but it is probably safe to assume it was strictly due to some emissions control reason.
#25 |
Drives: 2018 BRZ
The link tcoat posted has the differences.
#26 |
Famous Potatoes
Drives: '15 ultramarine
I know there are guys here that put the red (and expensive) manifold on the earlier engines. Doubt it did anything but change the color.
#27 | ||
Instagram: @spike.grc
#28 |
The only reason the STI was faster than the WRX is because it had a red manifold.
| 2017 fa20 engine into 2013 car? | ROADRACER | Engine, Exhaust, Transmission | 91 | 12-28-2021 11:52 PM |
| 2017 engine hoses? | Warlin | Engine, Exhaust, Transmission | 1 | 03-19-2018 02:11 PM |
| 2017 Engine Stronger? How Much? | Xxyion | Engine, Exhaust, Transmission | 32 | 10-10-2017 11:26 AM |
| Low hum after starting the engine (BRZ MY 2017) | spike021 | BRZ First-Gen (2012+) — General Topics | 15 | 03-22-2017 11:55 AM |
| 2017 engine vs 2013 engine | DailyDriver86 | Engine, Exhaust, Transmission | 17 | 11-09-2016 05:16 PM |
