Old 07-13-2018, 12:23 PM   #15
The European version got many of the engine changes but not all of them.
Page 73
Originally Posted by rvoll View Post
Can anyone tell me the difference between the two manifold options? Besides being red or black, is one plastic and the other aluminum? Are they exactly the same otherwise? Is this just marketing or is there a reason they are different?
You could read the info I linked.
Old 07-13-2018, 12:36 PM   #16
highway7
Drives: FRS 2013
Is yours automatic?
highway7 is offline   Reply With Quote
Old 07-13-2018, 12:38 PM   #17
Originally Posted by highway7 View Post
Is yours automatic?
Doesn't matter if he is in England.
If he is in London, Ontario he can bring it by and show me.
Old 07-13-2018, 12:44 PM   #18
rvoll
Drives: 2018 BRZ Limited, 2017 Sportage
You could read the question I asked. I know the differences between the two engines, they are well publicized. I wanted to know if the part was different and how/why. For example, if they are made of different materials, does the aluminum one disperse heat better which is needed for the revised engine. Why is this relevant? If you have an engine with the regular cover, wouldn't better heat dispersal be a good thing as an upgrade? So, can you answer the question or are you only looking for opportunities to try and slight someone? Or perhaps this is just one of those 33 posts you must do each day....
rvoll is offline   Reply With Quote
Old 07-13-2018, 01:04 PM   #19
Well if you actually read the fucking thing instead of being your normal obnoxious self you would see the answers were there.
Here let me narrow it down for you.
Old 07-13-2018, 01:56 PM   #20
extrashaky
Drives: 2014 BRZ Limited
Originally Posted by krayzie View Post
Except that's the wrong part. That cover has been eliminated on the version with the red manifold.
Old 07-13-2018, 02:01 PM   #21
funwheeldrive
I bet youre fun at parties
Old 07-13-2018, 02:13 PM   #22
mrg666
pessimistic skeptic
mrg666's Avatar
I heard 2017 engine is so much more improved. Is that true? Maybe OP can just swap the engine with 2017 version. It would be awesome! Anybody has done this swap before? Or it could be possible to replace intake and exhaust manifolds with the new versions. I am already liking this idea!
Old 07-13-2018, 02:13 PM   #23
rvoll
You're right. My apologies.... My assumption is that if that manifold is put on the non-manual version, it won't work because of other changes in the engine. In fact, it might not even fit. Again, I was just looking for a possible upgrade opportunity...
Old 07-13-2018, 02:17 PM   #24
Well considering that the sum total of all the changes including internals, exhaust, intake system and tune was only 5HP then there would be virtually zero benefit to changing just one component. We never have found any truly sensible reason why all the changes were not made to the autos but it is probably safe to assume it was strictly due to some emissions control reason.
Old 07-13-2018, 06:32 PM   #25
edwardl
Drives: 2018 BRZ
The link tcoat posted has the differences.
edwardl is offline   Reply With Quote
Old 07-13-2018, 06:52 PM   #26
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
I know there are guys here that put the red (and expensive) manifold on the earlier engines. Doubt it did anything but change the color.
Old 07-13-2018, 06:53 PM   #27
spike021
spike021's Avatar
zeal86 is one of them: https://www.ft86club.com/forums/showthread.php?t=76829
Instagram: @spike.grc
spike021 is offline   Reply With Quote
Old 07-14-2018, 09:29 PM   #28
Ernest72
The only reason the STI was faster than the WRX is because it had a red manifold.
2017 fa20 engine into 2013 car? ROADRACER Engine, Exhaust, Transmission 91 12-28-2021 11:52 PM
2017 engine hoses? Warlin Engine, Exhaust, Transmission 1 03-19-2018 02:11 PM
2017 Engine Stronger? How Much? Xxyion Engine, Exhaust, Transmission 32 10-10-2017 11:26 AM
Low hum after starting the engine (BRZ MY 2017) spike021 BRZ First-Gen (2012+) — General Topics 15 03-22-2017 11:55 AM
2017 engine vs 2013 engine DailyDriver86 Engine, Exhaust, Transmission 17 11-09-2016 05:16 PM
