View Poll Results: Do you have chirping (cricket) noise during idle once the car is warmed up?
Yes (Please only vote after you have 300 miles or more on the odometer) 3,101 85.22%
No (Please only vote after you have 300 miles or more on the odometer) 538 14.78%
Voters: 3639. You may not vote on this poll
Old 07-12-2012, 08:13 AM   #267
Jayde
Jayde's Avatar
Originally Posted by Chewie4299 View Post
I just had my fuel light go on for the first time. I filled up before that ever happened at Mobil or BP the last 3 times.
This time I went to Shell. Seems like the car really runs better on Shell. I'm certain that this is completely a placebo effect as I always laughed quietly to myself when someone says something like that but I HAVE to believe it because I spent 4.15/gal when the Mobil station 20 yards away was charging 3.61/gal for 93.
Fortunately my crickets are still dead but I'm certain there's still enough 2 stroke oil left in the gas to do that on its own. No way to really attribute this to the gas.
Sent from my Galaxy Nexus using Tapatalk 2
Let us know how it is!
I have a gas station right next to my work that just recently became a Shell station, so I'm tempted to try it.
Jayde is offline   Reply With Quote
Old 07-12-2012, 08:24 AM   #268
Chewie4299
Spaceman
Chewie4299's Avatar
Drives: 2013 Firestorm Scion FR-S
Oh I'm certain its high quality gas. I just don't believe that it's 15% better than Mobil considering that's how much more I paid.
I think all the gas in CT is 10% ethanol. So if that is linked to the chirping then Subayota is my only hope.
Chewie4299 is offline   Reply With Quote
Old 07-12-2012, 08:46 AM   #269
Jayde
Jayde's Avatar
That, or put some 2 stroke oil mix in your fuel.
Old 07-12-2012, 09:20 AM   #270
sierra
Drives: Skoda Yeti DSG diesel 4x4
Just added 2oz of 2 stroke oil to half a tank of gas.
It killed the crickets instantly and they were loud. Feels so good to drive the car without that stupid noise.
I hope toyobaru addresses this fuel pump noise and doesn't leave it unresolved.
At last!!!!!!
Did the engine feel any smoother, quieter apart from the chirping having stopped?
The comment to use marine 2T is a good one and a high performance low ash version if available.
Lots of apprehension from others afraid to add something specifically designed for the job but apparently having less concern for what's happening to the fuel pump and injectors as the washer breaks down.
sierra is offline   Reply With Quote
Old 07-12-2012, 09:43 AM   #271
Chewie4299
Spaceman
Chewie4299's Avatar
Originally Posted by sierra View Post
At last!!!!!!
It was crazy how fast the chirping went away with this addition. Mine was LOUD.
Old 07-12-2012, 09:59 AM   #272
raphymartinez
raphymartinez's Avatar
Has anyone tried Marvel Mystery oil? Should do the trick from other things I've read/heard about it. I'm gonna try it to see if it takes care of it.
2013 Firestorm FR-S (MT)
raphymartinez is offline   Reply With Quote
Old 07-12-2012, 10:09 AM   #273
cobrabyte
cobrabyte's Avatar
Drives: 2013 BRZ, 2002 WRX
Marvel did come to mind but I was thinking purely about cost-per-fillup. If this is going to be a regular thing, it may as well be cost effective. I believe it will cost about $0.50 per fillup using the Lucas 2-stroke oil I picked up.
You can get Marvel in those huge containers so maybe it's just as cost effective at that scale.
I'd be interested to learn whether it remedies the issue.
cobrabyte is offline   Reply With Quote
Old 07-12-2012, 10:25 AM   #274
Thunderchicken
Drives: 2008 STi
Has anyone went to the dealership pointed out your findings or at leased called they to put it on record that doing this does make the crickets go away then toyota can source out a product that they feel comfortable with and us the minimum standard.
Thunderchicken is offline   Reply With Quote
Old 07-12-2012, 11:46 AM   #275
Z0rr0
Drives: 2013 Raven 6MT FR-S
I do not believe that you guys should be "OK" with having to add anything to the fuel. There is an obvious problem, that Subaru/Toyota need to address.
Z0rr0 is offline   Reply With Quote
Old 07-12-2012, 11:48 AM   #276
Hanzo
Hanzo's Avatar
Drives: Waiting for the ND Miata
Agree but if there is a temporary fix that doesn't harm the engine/exhaust system it might be worth a try. The sound is very annoying.
Hanzo is offline   Reply With Quote
Old 07-12-2012, 11:50 AM   #277
Chewie4299
Spaceman
Chewie4299's Avatar
I'm not satisfied with having to use 2 stroke oil. But it is preferable to suffering that chirping while waiting for a solution.
The Following User Says Thank You to Chewie4299 For This Useful Post:
bayareakhiladi (07-13-2012)
Old 07-12-2012, 12:48 PM   #278
Thunderchicken
Drives: 2008 STi
I agree that as a ower that you should just be able to follow the manual. But in-light of this sound that toyota and subaru change the maintanice required so that it keeps from expensive fixes down the road. If they find out that adding some 2 cycle oil to the tank every time you change the oil or something like that than you know that the motor is going to stay in working condition as long as possible.
My suggestion to the people who put the 2 cycle oil in that they note the mileage when they used and the milage when the noise returns and rinse and repeat so when you talk to the regional rep. They can pass the info on and find a more perminat solution that isn't costing us extra money cause it will be done when you get your oil changed or when you change you own oil if you follow what I'm saying.
Old 07-12-2012, 03:53 PM   #279
Fenrir
Drives: Mazdaspeed 3
Rotary owners have been putting 2-stroke oil in their gas tanks for 20+ years for similar reasons, and haven't got any sort of compensation or resolution from Mazda.
Fenrir is offline   Reply With Quote
Old 07-12-2012, 06:45 PM   #280
Chewie4299
Spaceman
Chewie4299's Avatar
I'm going to buy THIS (3.2oz Pennzoil 2-cycle oil bottle) and THIS (1gal of the same oil).
I'm going to carry the small bottle with me and add it to the tank every time I fill up and then I'll refill it at home. 3.2oz bottle gets you roughly 500:1 in our 13.2gal tank. I'm going to try to run my tank down to the light but not much further before filling up so I'll keep the bottle about 2/3 to 4/5 full as there will already be some in the tank.
I've been researching it and using quality 2-cycle oil looks like it will do no harm to a 4-cycle engine and will actually only serve to prolong the life of the engine by ensuring lubrication every cycle. Some even claim it can help gas mileage albeit minimally.
I realize, again, that having to do this is absurd. But I've worked out the math and using ~3oz of that gallon jug at each fill up should cost $0.40. This is WELL worth not having to deal with that chirping until they fix it.
Can anyone confirm hearing that Toyota/Subaru are addressing this? It may have been mentioned in this thread and even though I've read it all I cannot recall.
The Following 2 Users Say Thank You to Chewie4299 For This Useful Post:
Bonburner (07-12-2012), excited86 (07-12-2012)
Is this idle noise normal? robo_robb Engine, Exhaust, Transmission 288 01-25-2022 09:40 AM
Squeak noise from engine. Fish Scion FR-S / Toyota 86 GT86 General Forum 52 05-08-2014 01:06 PM
Video of chirping at idle Julio86 Engine, Exhaust, Transmission 15 02-01-2013 10:37 AM
Starting to get worried - Engine noise Laika BRZ First-Gen (2012+) — General Topics 49 07-02-2012 03:45 PM
Idle issue poll/role call Hawaiian Scion FR-S / Toyota 86 GT86 General Forum 8 06-13-2012 12:00 PM
