#645 |
Drives: 2013 frs red
I would get your debit card, put at least another 5 gallons in and drive it. Give it 20 miles or so, then look at your real time diagnostics.
#646 |
Drives: 88 Supra 1JZ, 16 FRS, 25 GR Corolla
LT Fuel trims are still negative. I've driven 125 miles or so on E85 now.
25 miles or so - https://datazap.me/u/narfalicious/e851?log=0&data=1 more than 125 miles - https://datazap.me/u/narfalicious/e8502?log=0&data=1
NARFALICIOUS
Noob Poster 1988 | 2016 |
#647 | |
Drives: FT86
fuel trims loog a little negative but that's normal on first tank of E85 due residual petrol the logging of some parrameters is incorrect, assume your on older v2 tune. if you use V4 tune then logging will be correct |
#648 |
Drives: Toyota 86
is there anyway to see if the oil in my car is suited to run E85? i've done alot of research trying to find information on the oil that was put into my car when it got serviced recently (Valvoline Synpower 0W20) its not really mentioned anywhere on the internet and it mentions E85 once on the PI sheet but im not sure its really suited
Thanks in advance |
#649 | |
Drives: FT86
If its rated SN or GF5 it will be E85 compatable |
#650 |
Drives: TRD R.S. 1.0 FRS
hi,
so this is my first tank of e85. my afr seems pretty high. especially when im just in gear cruising without any throttle is shows 20 for the afr. should i be worried? https://datazap.me/u/bboyairrick/3rd...-12&mark=10647 Last edited by airrick; 07-11-2018 at 03:33 AM. Reason: forgot my link |
#651 | |
Drives: FT86
See ECU logging link below |
#652 |
Drives: 2013 brz
Mixing
I've got just openflash tablet on stock car and wanna try e85. No flex fuel.
I've found a shop in canada that sells e100. To get e85 can I just fill up with e100 and then 93 pump gas on my car? Appropriate volume of course. Does it mix on it's own or do I have to mix it externally out of the car? |
#653 | |
Drives: FT86
should work id probably mix it to about E70-e80 if on a standard oft tune as that's about the middle of the operating range |
#654 |
This was during a 2nd gear pull.
Everything look normal? It seems like im running a little rich. what AFR do i want to be at during WOT? https://datazap.me/u/bboyairrick/sup...5-650&mark=277 |
#655 | |
Drives: FT86
Afr and commanded afr should be closecinder full throttle yes you are running about 8% richer than commanded afr. Lkely needs some maf scaling |
#656 | |
what im trying to do is let my ecu learn the trims better correct? |
#657 | |
Drives: FT86
No maf scaling requires collection of data and then recalibraringvthe mas aor flow sensor tables in tune to correct the fueling error |
| The Following User Says Thank You to steve99 For This Useful Post: | airrick (07-23-2018) |
#658 |
| Stock FR-S Tune Just Done | Zach3794 | Engine, Exhaust, Transmission | 67 | 11-05-2017 02:01 PM |
| stock BR-Z, much detonation during shifts: tune? | elefunkd | Engine, Exhaust, Transmission | 69 | 07-26-2013 04:20 PM |
| Anyone have a stock tune from Visconti? | Bleevin | CANADA | 3 | 07-03-2013 01:01 AM |
| My Initial (all stock) BRZedit tune | mad_sb | Engine, Exhaust, Transmission | 6 | 02-16-2013 12:20 PM |
| Save stock tune with ecutek? | gdrider77 | Engine, Exhaust, Transmission | 7 | 01-06-2013 12:50 AM |
