Old 07-09-2018, 03:34 AM   #15
Kodename47
Kodename47's Avatar
Drives: UK GT86
Originally Posted by Spec C Wannabe View Post
Anyway with does POL stand for?
Primary Open Loop. The main fueling table. It's actually just an enrichment table verses stoich AFR. If you look at the calculation of the table it is just a fuel adder, but it's standard to convert this to a target AFR value as it's easier to understand.
.: Stealth 86 :.
Kodename 47 DJ:
Old 07-09-2018, 06:48 AM   #16
freerunner
freerunner's Avatar
Drives: GT86
Originally Posted by Kodename47 View Post
I wasn't implying your scale that you did was off. Just pointing out that you could "fix" your issue by simply changing the O2 sensor scale. From my findings the scales posted on here or in any tunes are not perfect. I have definitely found a variance and are also different to EcuTek's verified scale as well. The OEM sensor can only really be used as a generic indication to what's going on. A little bit of variance is to be expected.
It was the right decision in the end, though. All the wild and controversial fuel trims stopped to occur. The final fuel trim now settles after a very short amount of time. And it only changes due to weather and or fuel conditions. That's nice to have. And I learned something while having a great time.
I spent ages fine tuning my MAF to the most commonly used O2 scale from on here. Went to the dyno and I was running so lean (like 0.5-1 AFR leaner) on the tailpipe O2 and my AFR curve was nothing like that in my logs.
That's scary.
freerunner is offline   Reply With Quote
Old 07-11-2018, 02:16 AM   #17
freerunner
freerunner's Avatar
Drives: GT86
Damn, I surrender. Placed an order for a wideband sensor yesterday.
I'm going to try @ztan 's method of installation:
http://ft86club.com/forums/showthread.php?p=2147132
Question for those who have flex fuel kit stlgrym3 Engine, Exhaust, Transmission 5 07-06-2018 11:47 AM
Fuel injectors question. Border7 Forced Induction 44 05-06-2016 11:30 PM
How to correcting a scuff mark?? ARTBRZ Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 15 01-26-2015 11:33 AM
Product Review: Adam's Paint Correcting Polish DetailersDomain Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 0 08-22-2013 01:19 PM
Correcting drive ratio for accurate speed AlexTheGreek Engine, Exhaust, Transmission 25 12-05-2012 01:13 AM
