| Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) Everything related to the mechanical maintenance of the FR-S and BRZ |
Coolant level dropping & Dirty coolant
Hi,
Understand BRZ/86 have this coolant level droppping issue, (quite a fair bit of discussion on coolant level from google) On my 2017 BRZ, the coolant has dropped from exactly the Full level to Low level after 4mth of usage. I do not observe any visual leaks or any over-heating issue. I'm fine to top-up the coolant if there's no other side-effect. But on my previous 3 rides (all 9yr old), 2 of them suffer from blown gasket. So obviously i'm rather worried if this symptom of coolant dropping is an early sign that i'm going to get another pre-mature blown gasket ? (if they really evaporate off, does it make more sense to top-up distill water rather than coolant ? i suppose too thick a coolant isnt that optimal, esp for a all-year summer country) Also, there's once i sucked out some coolant as the level was an inch higher than Full after servicing. I notice there are some sediment floating in the coolant that i sucked out. For an old vehicle i believe this is normal, But is this normal for a 10mth old BRZ ? Regards ! |
#2 |
Mine doesn't use coolant although I have seen talk of some using coolant. Whatever you do though, don't top it off with water. A little water isn't going to harm you but it's too hard to keep track of how much water you have added over time and you don't want to dilute it too much. The coolant is critical in preventing corrosion. Pure water is extremely hard on the cooling system and pump.
| The Following User Says Thank You to ermax For This Useful Post: | Overdrive (07-13-2018) |
#3 |
Oh, I reckon if you keep the coolant level in between the lines, your car will be OK.
humfrz |
#4 |
The Dictater
Drives: '13 Red Scion FRS
What evaporates is the water in the coolant, so if it's just evaporation from the overflow, distilled water is what you should add.
BUT if there are any leaks, you should add a mix of coolant and water (usually comes pre mixed). Mine uses about half the overflow tank in a year I think. I've had to top it off twice. My coolant isn't dirty though. It should still be under warranty right? Take it to the dealer and let them deal with it (no pun intended... Originally at least ).
#5 |
Drives: 2017 Subaru BRZ PP WRB
Apparently some evaporation is “normal” for Subarus. I reported the coolant loss to the dealership when I had a WRX and the tech said that it was just evaporation from the coolant reservoir and that they all do that. Two previous Subarus that I owned (WRX and Outback) both had a small amount of coolant loss in the first 10k miles or so and I just topped it off a time or two and had no issues with either vehicle.
#6 |
Drives: 2017 86 6-Speed
Keep in mind some of it is expansion and contraction too. Look at the level on a cold morning, then drive the car for a while and look again. It moves up a good ways on the reservoir.
2017 86 set up for CS STX autocross
#7 |
If it mysteriously loses coolant over time, it's because the system cannot maintain pressure. There are always hot spots along the coolant path. If pressure bleeds off, those hot spots will start to sizzle and keep sizzling until the rate of boil comes to equilibrium with the rate of leakage.
If coolant loss is not accompanied with a lingering smell of antifreeze, it is almost always due to a leaky check valve in the radiator cap.
#8 | |
The Dictater
| The Following User Says Thank You to Spuds For This Useful Post: | Teseo (09-24-2018) |
#9 |
The Fail Boat
Drives: CWP S.B.
Our car runs really hot, so it's normal that you see a drop in coolant lv.
Just rememeber to check it once in a while and when you have to drive long trips. 600km + |
#10 |
I beat the piss out of mine. I've added coolant once in five years. It's not normal to lose coolant. It is, however, acceptable to some.
I have never allowed a system to simmer off coolant.
#11 |
Famous Potatoes
Drives: '15 ultramarine
3.5 years, same coolant.
#12 |
The Dictater
5 years, 2 top offs, running fine
#13 |
#14 | |
6/22/12-2/6/24
To quote myself:
| The Following User Says Thank You to Bonburner For This Useful Post: | Overdrive (07-13-2018) |
| Low Coolant level @ 20k? Help.. | Jfheisenberg | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 35 | 10-29-2021 12:01 PM |
| Low coolant level? | brzzy | Engine, Exhaust, Transmission | 7 | 04-11-2016 02:16 PM |
| Coolant loss - Void Warranty/ Edit: coolant flush question | BRZach | Engine, Exhaust, Transmission | 15 | 01-02-2016 08:21 PM |
| Should I be concerned with coolant and oil level? | B-R-Z | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 18 | 01-28-2014 12:03 AM |
| Coolant level when cold | GloriousJ | Scion FR-S / Toyota 86 GT86 General Forum | 3 | 05-29-2013 08:03 PM |
