Old 06-04-2018, 02:51 PM   #799
NJUL9925
Drives: 2013 FRS
Hey guys I have a V1 and need to do the SC oil change on it. I dont have my manual however and cant find one except for the install manual on the V3 from ft86speedfactory.
It does not offer much help in terms of showing a procedure to doing this oil change safely.
-does anyone have a link where I can download the V1 manual or other reference to use?
also has anyone done it that can give advice on this?
thanks !
NJUL9925 is offline   Reply With Quote
Old 07-07-2018, 01:35 AM   #800
killsafkat
killsafkat's Avatar
Drives: 2013 GT86
Anyone using an aftermarket intake or induction box with their v2 or v3?
killsafkat is offline   Reply With Quote
Old 08-01-2018, 11:09 AM   #801
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
So how is everyone's reliability holding up?
MS, CSCS, TSAC-F, CPT
Old 08-07-2018, 11:31 AM   #802
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
Hey, are you thinking on this supercharger? The one I tested once had the HKS kit. It was the basic one and made 240 @wheels. Very very strong result ...
Old 08-12-2018, 05:53 AM   #803
killsafkat
killsafkat's Avatar
Drives: 2013 GT86
Originally Posted by Andew727 View Post
go with a Tial QRJ full recirculating BOV. i have one on my car with a high boost pulley. sounds amazing, looks better, and in my opinion performs better than the bypass valve.
pictures on my IG: andyb727
ill have videos up soon once i fix the crank pulley pin that i bent.
Which spring did you use with ur tial qrj?
Old 08-13-2018, 03:42 AM   #804
Trap63
Trap63's Avatar
Drives: Brz WRB - Europe LHD
Now on test! I install a new wider restrictor of 41 mms of diameter vs the stock one of 39.
Car gains much more reactivity on medium –low range and from initial logs I see a medium range of +20grs air, a need of +6/7 of fuel in comparison with stock configuration of HKS V2.
It’s mandatory to revise all parameters first of all DI+PI and to better balance engine load.
I think that this is the best mod for upgrade HKS V2 without exceed and no need to change fuel pump and injectors.
Tune suite: Ecutek RaceRom10, 100 RON fuel only.
To cut with laser a new Iron Aisi304 restrictor I paid $10,00 (if someone wants I get the file for laser cutting).
Inviato dal mio SM-G960F utilizzando Tapatalk
Trap63 is offline   Reply With Quote
Old 08-13-2018, 09:50 AM   #805
Yobiwan
Yobiwan's Avatar
Drives: Toyota 86 Turbo, Lexus NX300H
you can go to 43~44mm on stock MAF sensor & injector .
(max boost is about 11.5)
I use 45.5mm now with stock injector, pump & STI maf sensor.
max boost is about 12~13 depends on IAT & altitude.
good luck !
2012 Toyota 86 6MT / 11:1 CR block by Outfront / SBD500x Turbo 17PSI@93gas /Avo 2.5 overpipe+Avo 2.5 catted frontpipe /MAP 3" CBE/ Tein Mono sport / STI brembo Front /OS技研 LSD/SSR GTX01 18x9.5
Yobiwan is offline   Reply With Quote
Old 08-13-2018, 10:03 AM   #806
Trap63
Trap63's Avatar
good luck !
hi mate do you have part no. of sensor? thx
Old 08-13-2018, 10:27 AM   #807
Yobiwan
Yobiwan's Avatar
Here
http://www.ft86club.com/forums/showthread.php?t=106496
Old 08-27-2018, 05:04 AM   #808
phlipsyde
Drives: 2013 Whiteout FRS
Hey guys, I have the v3 kit and love it. Two questions for someone seasoned - any idea why I see -11 vacuum at idle instead of 20ish? This is the reading from my OFT. second, how do I attach a Tial QRJ to the HKS manifold? I'm having a tough time finding the base that fits. I emailed Tial but haven't gotten a response. Thank you!
phlipsyde is offline   Reply With Quote
Old 09-05-2018, 01:02 AM   #809
johl
johl's Avatar
Drives: toyota 86
What headers and front pipe is everyone running?
I’m concerned once the standard headers are removed I will experience a terrible rasp in the exhaust. Does anyone have an ACE header and catted front pipe with the hks supercharger?
johl is offline   Reply With Quote
Old 09-05-2018, 02:03 AM   #810
Trap63
Trap63's Avatar
I run on Tomei EL and Tomei overpipe with HKS Spec L Ti.
very low sound and no resonance. Only very high Db level @160Km on highway
Old 09-05-2018, 03:37 AM   #811
johl
johl's Avatar
Drives: toyota 86
I was actually just looking at your engine bay. That is exactly what I want to do. It looks almost factory when it is painted black.
I was hoping it was possible to keep the exhaust a little on the quiet side with no annoying rasp or drone so that is good to hear. Thank you
Old 09-14-2018, 08:28 PM   #812
FT86Z
Drift noob
FT86Z's Avatar
Drives: 2015 BRZ Sport-Tech CWP 6MT
Differences between HKS supercharger kits
Hello FT86'ers,
I am shopping for my first supercharger and I have been researching the HKS V3 kit which I believe is the 12001-KT003. On the HKS JP website theres also the PRO 12001-AT009 which says its to be discontinued as per the site, and the GT2 PRO 12001-AT012 kit:
https://www.rhdjapan.com/hks-gt2-sup...t-zn6-zc6.html
Pricing is not too much different between them all and I was just wondering what the main differences are. Also, any reviews or comments regarding the flash editor if I were to get one with it?
Thanks in advance for the info.
FT86Z
藤原とうふ店
FT86Z is offline   Reply With Quote
Kraftwerks Supercharger Owners Thread projek_01 Forced Induction 4310 04-07-2025 01:12 PM
P&L Turbo kit Owners thread Hawaiian Forced Induction 73 07-07-2018 02:31 AM
Five Axis Edition FR-S Owners Thread digital_assassin FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 563 07-08-2015 09:22 PM
**Offical 213/323/626/818 owners thread** mr. slim Southern California 71 10-07-2013 12:58 PM
Supra Owners Build Thread BoostJunkie Other Vehicles & General Automotive Discussions 164 03-12-2012 09:37 AM
