Old 07-05-2018, 10:45 AM   #29
RallySTI
Drives: 2013 Subaru BRZ
Yes, once we receive the new updated bearing from NTN all our (EXEDY) clutch kits will have the updated bearing included except for the twin plate, it uses a different bearing.
RallySTI is offline   Reply With Quote
The Following User Says Thank You to RallySTI For This Useful Post:
Irace86.2.0 (07-05-2018)
Old 07-07-2018, 12:50 AM   #30
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
Just an update, which I also posted on my build tread...
--Buy the snout if your TOB fails or looks anything like this:
Not only was the surface texturized with melted plastic/delrin (whatever the backing on the TOB is made of), but it also had a palpable step off and taper to the ends where material was worn away.
The Following User Says Thank You to Irace86.2.0 For This Useful Post:
dowroa (07-07-2018)
Old 07-07-2018, 08:07 AM   #31
dowroa
Old Guy
Drives: 16 STi, 22 MX-5 RF BBS, 04 OBS RPA
What I find slightly funny about the above is the fact the snout is removable now.
If anyone has owned an older Subaru, you may be familiar with the snout kit which had a snout that would fit over the original with a larger I.D. bearing.
So, to combat the same problem of a wearing snout, we now have replaceable snouts. However, it seems we have the same low durability of the OEM bearing and snout.
Ha!
dowroa is offline   Reply With Quote
The Following User Says Thank You to dowroa For This Useful Post:
Irace86.2.0 (07-07-2018)
Old 07-07-2018, 09:46 AM   #32
Irace86.2.0
Ha!
True but even if the new TOB lasts another 60-100k miles then that is like 10 years for me so a new snout isn’t so bad.
dowroa (07-07-2018)
ACT Clutch Kits Scion FR-S/BRZ 2013+ Now In Stock, Free Shipping! at SubiPower.com SubiPower.Com Transmission and Driveline 36 11-10-2015 09:51 AM
ACT CLUTCH Introduces New FRS / BRZ Clutch Kits & Flywheels !!! Zerolift Transmission and Driveline 3 12-09-2013 11:05 AM
Clutch Masters Clutch and Flywheel Kits for FR-S and BRZ available at Redline360 Redline360 Transmission and Driveline 2 07-30-2012 10:01 AM
Clutch Masters Clutch Kits | Island Import Performance IslandImportPerformance Transmission and Driveline 1 07-20-2012 12:06 PM
