Old 06-28-2018, 11:07 PM   #15
sid94
Drives: 2013 frs
Originally Posted by BloodyshoedFR-S View Post
Well I'm happy to say that definitely is not the noise I am hearing. I posted a link to a YouTube video of the noise. Could you take a look at it? See if maybe it reminds you of anything?
I heard the video but that’s all that came to mind
sid94 is offline   Reply With Quote
Old 06-30-2018, 04:53 PM   #16
BloodyshoedFR-S
Drives: 2014 Scion FR-S Monogram( Asphalt)
Alright, I put my stock exhaust with muffler delete on and the noise went away. Which means it definitely was part of the spec d exhaust. I am now working on isolating whether it was the resonator in the midpipe or the exhaust tips.
BloodyshoedFR-S is offline   Reply With Quote
Old 06-30-2018, 06:19 PM   #17
BloodyshoedFR-S
Update. I isolated the snapping to originating from the spec d resonator. I will now weld my stock resonator onto the spec d Exhaust and see if that fixes the issue.
The Following User Says Thank You to BloodyshoedFR-S For This Useful Post:
humfrz (06-30-2018)
Old 06-30-2018, 07:00 PM   #18
sid94
Drives: 2013 frs
That’s weird, double check see if it has any cracks. Or shake the resonator to see if it’s coming apart internally before you start cutting and welding
Old 06-30-2018, 07:06 PM   #19
BloodyshoedFR-S
Yeah that's what I thought to but everything looks good except for a small dent in the resonator. The welds are good and not cracked, and nothing shakes or rattles. Honestly I think it's just a poor quality resonator.
Old 06-30-2018, 07:38 PM   #20
sid94
Drives: 2013 frs
Could be, see if you can get a vibrant resonator or something not stock to match diameter of the new exhaust better if it doesn’t match up or straight pipe that bitch lol
Transmission Noise in Neutral @ Cold Start Jackal84 Issues | Warranty | Recalls / TSB 57 03-01-2021 03:21 PM
Cold start up popping noise Weeber Issues | Warranty | Recalls / TSB 51 09-23-2016 12:54 PM
Perrin CBE crackling noise during cold start tracerit Engine, Exhaust, Transmission 8 02-26-2015 03:43 PM
Rubbing noise on cold start only in reverse? brsaresmgs Issues | Warranty | Recalls / TSB 2 01-18-2015 07:15 PM
Cold Start Clunk Noise Luckrider Issues | Warranty | Recalls / TSB 6 11-28-2013 05:02 PM
