#15 | |
Drives: 2013 frs
I heard the video but that’s all that came to mind Sent from my iPhone using Tapatalk |
#16 |
Drives: 2014 Scion FR-S Monogram( Asphalt)
Alright, I put my stock exhaust with muffler delete on and the noise went away. Which means it definitely was part of the spec d exhaust. I am now working on isolating whether it was the resonator in the midpipe or the exhaust tips.
#17 |
Update. I isolated the snapping to originating from the spec d resonator. I will now weld my stock resonator onto the spec d Exhaust and see if that fixes the issue.
| The Following User Says Thank You to BloodyshoedFR-S For This Useful Post: | humfrz (06-30-2018) |
#18 |
Drives: 2013 frs
That’s weird, double check see if it has any cracks. Or shake the resonator to see if it’s coming apart internally before you start cutting and welding
#19 |
Yeah that's what I thought to but everything looks good except for a small dent in the resonator. The welds are good and not cracked, and nothing shakes or rattles. Honestly I think it's just a poor quality resonator.
#20 | |
Drives: 2013 frs
Could be, see if you can get a vibrant resonator or something not stock to match diameter of the new exhaust better if it doesn’t match up or straight pipe that bitch lol Sent from my iPhone using Tapatalk |
| Transmission Noise in Neutral @ Cold Start | Jackal84 | Issues | Warranty | Recalls / TSB | 57 | 03-01-2021 03:21 PM |
| Cold start up popping noise | Weeber | Issues | Warranty | Recalls / TSB | 51 | 09-23-2016 12:54 PM |
| Perrin CBE crackling noise during cold start | tracerit | Engine, Exhaust, Transmission | 8 | 02-26-2015 03:43 PM |
| Rubbing noise on cold start only in reverse? | brsaresmgs | Issues | Warranty | Recalls / TSB | 2 | 01-18-2015 07:15 PM |
| Cold Start Clunk Noise | Luckrider | Issues | Warranty | Recalls / TSB | 6 | 11-28-2013 05:02 PM |
