Old 06-29-2018, 10:57 PM   #1
dynomite619
dynomite619's Avatar
Drives: 2016 subaru brz insta@black.xira
gauge issue
soo all sudden my gauge dash stop working i replace the 7.5 fuse and it blows try 10 it blows,try a 15 and it blows idk what the issue is but i need it cause i cant use my turn signal and the alternator not charging battery
dynomite619 is offline   Reply With Quote
Old 06-29-2018, 11:21 PM   #2
Brz_racer
Drives: Subaru BRZ
My bet is on the alternator, probably has a short internally and is causing the problem.
Brz_racer is offline   Reply With Quote
Old 06-29-2018, 11:28 PM   #3
dynomite619
soo removing the connections on the alternator and retrying the fuses again would eliminate the shortage ?
Old 06-29-2018, 11:32 PM   #4
Brz_racer
Drives: Subaru BRZ
Yeah that's what I would try, if it doesnt blow the fuse you know you have a failed alternator
Old 06-29-2018, 11:41 PM   #5
Whatever it is, I wouldn't keep putting bigger fuses in the slot …. or you will find the problem, when something starts smoking...
Like suggested, you may wish to check the alternator.
https://www.aa1car.com/library/battery_runs_down.htm
Then, I would look for a short … what is the last electrical thing you did with the car??
Old 06-29-2018, 11:45 PM   #6
dynomite619
the alternator is disconnected the fuses keeps blowing . i have a volt meter install and it reads 11.5 when car is running last electrical thing i did was install car audio amp
Old 06-29-2018, 11:49 PM   #7
new2subaru
Weight Weenie
Drives: 15 FR-S
The fuse blows because you're drawing too much current. Putting a larger one in is only going to damage something or cause a fire. Stop doing that...
Chances are something went wrong with your install and you have a hot wire grounding out. That would be my first guess.
Whatever you did, undo it, and see what happens.
The Following User Says Thank You to new2subaru For This Useful Post:
humfrz (06-30-2018)
Old 06-30-2018, 12:52 AM   #8
The battery should read more than 12 volts. When the alternator is working, it should read about 13.5 volts at the battery.
Yep, it sounds like you have a dead short in that circuit.
Did you install the amp? If so, like suggested, you may wish to check your work. If someone else installed the amp, I'd suggest you take it back to them and ask them to sort it out.
That ought to keep you busy tomorrow ..
Old 06-30-2018, 01:33 AM   #9
dynomite619
well everything i install i undid nothing is connected to anything in the amplifier or capacitor the battery is a yellow optima the car cranks and runs just no dash indication i have a push start and i click it first time and it turns on the radio and i click it again and i hear the fuse pop ..
Old 06-30-2018, 02:03 AM   #10
Brz_racer
Drives: Subaru BRZ
What fuse exactly is it that keeps popping?
Old 06-30-2018, 02:04 AM   #11
Well, OK. Which fuse keeps blowing, more importantly, what other accessories does that fuse control?
Old 06-30-2018, 11:38 AM   #12
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
This is going to be a PITA but either you need to check every cable coming from the cluster yourself or take it to a reputable shop that does it until you/they find the grounded cable.
Old 06-30-2018, 11:50 AM   #13
Brz_racer
Drives: Subaru BRZ
Get a code reader and check for codes too, might be surprised and find something there
Old 06-30-2018, 01:07 PM   #14
dynomite619
Im already a step ahead remove the gauge cluster disconnected and put fuse in and still pop im try code reader
brz
AEM Oil temperature gauge and pressure gauge with pods. mtsound Engine, Exhaust, Bolt-Ons 2 08-24-2017 01:55 PM
Innovate MTX-A boost gauge issue (solved) go_a_way1 Electronics | Audio | NAV | Infotainment 10 10-06-2016 08:08 PM
Defi Oil Pressure Gauge and Cravenspeed Flexpod Gauge Mount Install and Review Tye300 Cosmetic Modification (Interior/Exterior/Lighting) 10 05-22-2015 01:48 PM
Gas Gauge Issue Jruex22 Scion FR-S / Toyota 86 GT86 General Forum 12 04-04-2013 11:28 PM
Ecutek gas gauge issue fixed maj75 Engine, Exhaust, Transmission 1 03-23-2013 12:49 PM
