Old 06-27-2018, 05:34 PM   #15
max20s14
Drives: 14' Raven M/T - 02' is300
Correct, it holds 7psi for most of the RPM range, and starts to taper slightly up top.
This is mainly dependent on the wastegate and boost controller setup. I have a GReddy T518Z (GReddy specific version of a Mitsubishi 18g turbo), that results in that behavior. With the boost controller, I can, if I wanted to, force it to hold the boost pressure flat all the way up to redline.
Do you have any opinions on using rom raider/OFT for a turbo
max20s14 is offline   Reply With Quote
The Following User Says Thank You to max20s14 For This Useful Post:
AreteAuto (08-07-2019)
Old 06-27-2018, 06:11 PM   #16
mrloko
Drives: 2017 Subaru BRZ
based on that information mike, would the turbosmart blowoff valve that comes standard on the JDL kit behave in this way? this is assuming of course there are no leaks and everything is connected okay
mrloko is offline   Reply With Quote
Old 06-27-2018, 08:37 PM   #17
CSG Mike
CSG Mike's Avatar
BOV =/= Wastegate/boost controller.
It'll depend on the turbo you choose.
mrloko (06-30-2018)
Old 06-27-2018, 08:38 PM   #18
CSG Mike
CSG Mike's Avatar
You better know how to tune your own car!
Old 06-27-2018, 09:57 PM   #19
max20s14
I tuned my old s13 with an sr20det with an apexi SAFC and a afr guage lololol
Old 06-28-2018, 10:30 PM   #20
sid94
Drives: 2013 frs
You’re in for a hell of an experience if you’re comparing this to your s13 lmao
I’ve owned plenty 240s and this is no 240 when it comes to tuning. Throw most of the knowledge you had out the window cause it’s a whole new ball game with this engine
sid94 is offline   Reply With Quote
The Following User Says Thank You to sid94 For This Useful Post:
CSG Mike (06-29-2018)
Old 06-29-2018, 10:15 AM   #21
max20s14
well damn. I forgot this thing has DI and port injectors - thinking out loud, maybe I should just buy a Silva K's with an sr20det already in it from an importer since we can do that now and keep the frs NA
Old 06-29-2018, 10:48 AM   #22
sid94
Drives: 2013 frs
Now that sounds like a good idea!
Old 06-30-2018, 02:46 PM   #23
mrloko
I had a brainfart, sorry about that. I meant the wastegate, if a turbo system has boost creep would you get rid of it by getting a bigger wastegate?
Old 07-01-2018, 05:16 PM   #24
CSG Mike
CSG Mike's Avatar
Depends on the reason for boost creep.
Boost Issues on Stock Internals mcrane Forced Induction 17 02-15-2017 12:36 PM
Digital boost gauge w/ vent pod grim speed boost controller Meetjoeblack Engine, Exhaust, Bolt-Ons 0 03-09-2015 01:27 PM
DI pump Internals SkullWorks Issues | Warranty | Recalls / TSB 60 10-30-2014 02:23 PM
Engine internals before FI? Rejor11 Forced Induction 14 06-04-2013 05:18 PM
How about them internals nytfury Engine, Exhaust, Transmission 5 08-27-2012 07:23 AM
