KW coilovers and camber (without camber plates)
Figured someone else might find this useful eventually...
If you want good useful camber up front, but don't want camber plates, you can get ~ 3.8* by using the SPC lower bolts, stock lower bolts in the upper hole and maxing out the negative amount in the slotted upper hole on the strut. Another benefit to this combination is you can max out the camber on the upper hole, then use the lobed bolt to dial it back very easily. A lobed bolt in the upper hole doesn't work in the slot to easily dial back camber.
| The Following 4 Users Say Thank You to wparsons For This Useful Post: |
#2 |
Drives: 2013 Raven FR-S
This is interesting info. I've thought about trying it before but was afraid having a crash bolt on top and a lobed camber bolt in the bottom might not be strong enough or could slip. With just the 14mm crash bolt on top I get about -2.5 max camber.
#3 |
If the upper bolt is going to slip, it's going to slip towards more camber (loosen off the bolts with the weight of the car on the wheels and it goes max camber), that's why I maxed out the upper and used the lobed lower bolt to dial it back.
I bet with the stock upper bolt in place it would still get to about -3 or -3.1*.
#4 |
I'm going to try this to get my front camber to -3.5. Which SPC part number did you use for the lower hole? Want to make sure it fits.
#5 |
Country Boy 4 Life
I have tried:
Lower oem bolt in upper hole and 14mm SPC (81305) in lower hole. 14mm SPC (81305) in upper hole and oem lower bolt in lower hole. 14mm SPC (81305) in upper hole and SPC 12mm 81250 in lower hole. 12mm SPC 81250 in upper hole and 14mm SPC (81305) in lower hole. 14mm SPC (81305) in upper hole and 14mm SPC (81305) in lower bolt in lower hole. Am currently using: Lower oem bolt in upper hole and 14mm SPC (81305) in lower hole. I never had any of the bolts move after TQ them down to spec.
I LIKE TIRES! |
#6 |
#7 | |
SPC 81305 Upper and lower on mine are torqued to 100ft/lbs, the SPC spec is 97, but whatever
| The Following User Says Thank You to wparsons For This Useful Post: | smg1138 (06-27-2018) |
#8 |
Hey, what endlinks are you using? I just installed the SPC 81305 in the lower hole and was able to get -3.5 degrees up front. Only problem is now the bottom of the strut is hitting the endlink when turning near full lock. I'm thinking the lobed bolt must have changed the angle of the strut in relation to the endlinks.
#9 |
This is what it looks like when the steering wheel is turned to near full lock. The bottom of the shock body is making contact with the endlink. I think maybe some adjustable endlinks that could go a little longer would fix it.
#10 | |
Stock, no clunks but haven't looked for signs of rubbing.
#11 |
Well, it's a moot point now anyway. The SPC camber bolts already slipped and hosed my front camber bad. Went to -4.3 FL -3 FR after they slipped. Decided just to re-install the 14mm bolts in both holes and max out the camber at -2.8. That will have to do until I can get some camber plates.
#12 |
Drives: 2014 GT86
smg1138: have you tried old trick of using loctite/fingernail polish/paint to "glue" bolts in place? For some it worked and they said bolts never slipped for them.
#13 |
Drives: 2013 Toyota 86
This thread on nasioc suggests strongly not to use aftermarket camber bolts at the top of the front, however your suggestion is to use the lower oem bolts at the top. Is this still not sacrificing strength as the lower bolts are thinner than the upper ones?
https://forums.nasioc.com/forums/sho....php?t=1590221 |
#14 | |
That's what I did, but they still slipped. I used the OEM 14mm bolt on top and the SPC lobed camber bolt on bottom. Not really sure why they slipped because I gave the alignment tech the torque specs for both bolts. |
| WTB: Camber plates for ST coilovers | Stealthy | Want-To-Buy Requests | 1 | 04-21-2016 07:57 PM |
| *BRZ Part Out* RCE T2 coilovers w/HVT camber plates | xDanger_208x | Brakes, Suspension, Chassis | 3 | 04-02-2015 06:53 PM |
| FS BC BR Coilovers & Oni Camber Plates | SLICVIC | Brakes, Suspension, Chassis | 0 | 03-01-2015 02:10 PM |
| FS: KW V3 Coilovers w/ Vorschlag Camber Plates | rever5e | Brakes, Suspension, Chassis | 10 | 12-30-2014 06:24 PM |
| FS: Coilovers W/ Camber Plates $575 | Amir Ghadiri | Brakes, Suspension, Chassis | 8 | 03-11-2014 02:22 AM |
